Old 11-13-2010, 01:24 PM   #43
1975 27' Overlander
High River , Alberta
Originally Posted by dznf0g View Post
You're missing the point completely. GVWR, GAWRs, and cargo capacity changed (in this specific case) which has an effect on trailer weight limits to reach GCWR. I have never seen a MFR. approve of a change in GCWR by an upfitter.
Again, my point is any modification by an OEM approved final vehicle manufacturer must meet FMVSS (I realize you're in Canada, but I think you will find regs. very similar up yonder) and be recertified. This is about the CERTIFICATION process and not my individual label. I was just showing a final vehicle manufacturer certification and the absence of the OEM label for understanding and clarification
Individuals can do what they want, but if a MFR. doesn't approve of a mod for an approved upfitter, it is not suitable from an engineering or safety standpoint.
We have "CMVSS" in Canada. For the most part it seems to be a direct copy of FMVSS, with some differences such as requirements for daytime running lights and 5 mph bumpers.
Is the calculation of GCVWR actually regulated in any way? I think you need to answer that question first. I believe that you will find that it isn't, unlike GVWR. I note that only GVWR is shown on the label in the photo.
AlbertF is offline   Reply With Quote
Old 11-13-2010, 01:42 PM   #44
dznf0g's Avatar
Oswego , Illinois
It is regulated from the standpoint of DOT inspections on commercial trucks over 10,000lbs GVWR. If you're over GCWR (per mfr. spec) on the scales, you're grounded and fined. (This 10,000lb level is new, used to be higher).
FMVSS only requires label to have tire pressures, and size, GVWR, GFAWR, GRAWR, and VIN.
For private vehicles, it's not until you have a wreck or other liability situation that you're exposed to problems.
Look, here's the bottom line.
1) Can anybody show us a statement from any DOT saying it is ok to exceed GVWR, GAWR, GCWR or max trailer weight?
2) Can anybody show us the same from ANY Mfr. as well as a statement that their warranty is valid for affected components if these specs are exceeded?
3) Can anybody show us the same from an attorney stating that there is no liability for operating a rig exceeding these specs?
Show me these things and I'll eat a whole pie of crow.
Old 11-13-2010, 01:51 PM   #45
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Who cares? Not I. Let's talk towing.
Doug
Old 11-13-2010, 01:53 PM   #46
dznf0g's Avatar
Oswego , Illinois
Doug
We are. We're talking about towing 8000# with a car rated for 3300#.
Old 11-13-2010, 03:32 PM   #47
dkottum's Avatar
We already know why we can't do it. Now let's go back to how we can.
Doug
Old 11-13-2010, 05:52 PM   #48
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Originally Posted by Andrew T View Post
for example even impared drivers have insurance coverage.
Andy...I don't think so...not here in the US.
I understand you want to sell hitches...but that is just not true...you're intoxicated...you're on your own Bud...better review a (US insurance) policy before you make a statement like that.
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 11-13-2010, 07:53 PM   #49
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Hi Vinnie
I appreciate your insite into the drivetrain, what did the engineer feel was the weak link? It would be unusual for a company like Volvo to equip a vehicle with a drivetrain that is not up to its engine capability espessially when you consider the Turbo can pump a lot more power through this drive train.
For this customer another vehicle is not an option they don't have a driveway to leave a suburban in so they must have a low profile tow vehicle and prefer a wagon. These days that is a pretty short list and it is hard to beat a Volvo wagon. We have other customers with the XC70, some of them tow trailers consdierably harder tow than the Airstream and so far we have not had any issues.
I understand the XC70 uses the Ford / GM joint venture 6 speed that is used in the Flex and Enclave. We have about 40 customers now using this tranny many with larger trailers with larger engines with no issues at all. Volvo's were actually the very first smaller cars we ever set up, I guess because their owners were so dedicated to them. I remember putting hitches on them in the early 70's. Since that time we have set up a lot of different Volvo's for customers and we have just never had any durability issues with any of them.
The European towing spec has been the same for every Volvo model since the 70's even thought the cars have dramatically improved over that time. The big issue with European specs is that they use no weight distribution let alone a Hensley, primative mechanical brakes and their trailers have more aerodynamic drag than an Airstream. Their trailers are light but not necessarily easy to tow. You also see solo Volvo's in Europe cruising at speeds well over 100 MPH, I always figured this was much harder on the car than towing a 60 MPH. I think is one reason why European cars seem to have so much overbuild in them. On the other hand you rarely see one in Europe that is not impecably maintained.
For those who are worried about insurance, tow ratings are not legal number they are a recomendation only. Again some vehicles with very high tow ratings are very unstable vehicles putting a trailer on them does not make them better. Should I recomend a vehicle to a customer that I know is less stable and less safe just because a marketing department pulled a bigger number out of the hat? Once an insurance company makes the decision to cover you they have to do so, they can elect not to cover you again after and incident, for example even impared drivers have insurance coverage. Again in 33 years of doing this we have never had a customer have an insurance issue.
Hi Andy..
The GM transmission has been a disaster for Volvo. Volvo is standing behind the unit well after the warranty period however the same reconditioned unit is going back in. Lets cross our fingers on that one. The transmission the XC70 uses is aisin. Like the GM, it is a very compressed unit stuffed into a small area. Towing an 8000 pound trailer with a combined weight of possibly 12000 pounds? The engineering staff feels this will be the weak point.
I have seen your work and I am a fan of the hitch designs and setups... so exceeding the towing capabilities is one thing but 2 1/2 times the tow capacity? To me thats the issue. The owner does not seemed concerned about the wear and tear so thats fine. Afterall its just a car and we have dozens more on the lot.
Do you offer professional driving classes with your installations? It might be a good idea to have the owner go through some basic road course situations. We offer this with the purchase of our vehicles out at Infinity raceway. People are amazed at what their vehicle can do in a controlled environment but also understand how to handle their car in a bit of a panic. It might be the responsible thing to do for your client.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 11-13-2010, 08:33 PM   #50
_
at least 2x a month for many many years...
threads about marginal or inadequate potential tow vehicles appear here...
in years past the mods and senior members were more than willing to point out the issues...
and describe exactly how ridiculous most of those combinations might be...
as mods they were allowed to post using words like 'troll' or 'crazy' or dangerous...
but times change here.
some of the older threads worth looking at are here...
http://www.airforums.com/forums/f463...f150-7593.html
http://www.airforums.com/forums/f463...dstar-849.html
http://www.airforums.com/forums/f463...epid-3636.html
there are literally 100s of them but the windstar threads are especially relevant.
since not long ago most of those w'stars driven in the northeast and rust belt...
were found to have rusted/defective axles and suspensions about to fall apart.
the recall affects 100s of thousands of these things after a few 100 did lose axles...
imagine what might have happened IF many of them were used for towing.
_________
the volvo in question has axles rated to 2800 lbs and 2600 lbs.
the volvo in question has a gCvwr of ~7500 lbs (less than the trailer solo)
the payload is 1200 lbs (less than the tongue and hitch combined without people)
and so on...
'towing capacity or rating is not a legal/official determination but axle rating and gCvwr are.
using the newly formulated SAE towing tests/standards, TOYOTA has RErated their trucks...
this has resulted in DErating by 400 to 1000 lbs on the newest t'dra.
_________
there is a concept in public health called herd immunity, google it.
basically herd immunity means that if MOST of a population are protected via immunization,
those FEW who don't immunize (for what ever reason) will be protected by the 'herd' of immunized folks around them.
we may NEVER read about accidents or vehicle failures that originate at canAM...
because their pool of rv'rs (even 40 years worth) is tiny relative to the larger world of rv'rs.
the shop owner claims that no 0ne using one of his favorite C rated tires (in D rated applications) has ever had an issue...
in fact no one has ever had a flat using the tire.
how amazing is that?
as we all know 1000s of rigs go down the road every day with dangerous, broken or improperly hitched trailers...
and seldom do those folks suffer.
the lack of braking down or crashing is not proof of right.
___________
there was an infamous doc early in this century who developed a cure of male impotence.
he and his clinic became WILDLY famous, so much so that he may have been elected governor...
IF all the write in votes had been honestly counted.
his "cure" was totally bogus and yet 1000s of men and their wives offered testimonial to the good.
it was in the early days of radio and he had his own radio show, then his own radio tower and station.
this was just like NOW in terms of discovering the value of direct media to promote a business.
he was doing media politics before anyone else even knew it was happening.
the now internet is a radio tower with 2 way links and webbed party lines.
when the establishment tried to control this guy, restrict his license and curtail his BIZARRE medical cures...
he simply moved the radio tower to mexico,
amped up the power and broadcast right back to the same american midwest audience...
it's an amazing story really,
and the average person jmay ust love an antiestablishment rebel...
John R. Brinkley - Wikipedia, the free encyclopedia
The Story of John R. Brinkley
The Best Darn Story Of The Whole 20th Century
________
for those that don't get it, here is just ONE of the points...
these threads are simply advertisements.
they are basically viral postings/exchanges and do everything that viral media intends...
but without having to pay for the airwaves or air space.
sometime the o.p. isn't even aware that's it is viral...
till the 2 sides start REplie'n
_________
unfortunately a few totally naive folks may get sucked into the vortex and become customers.
that is after all the entire purpose behind viral media.
most see/realize the ridiculousness of some of these towing combinations...
even if welding makes them possible.
_________
liability IS an issue, there are NO shops doing this stuff in the us of a, like there were 40 years past.
the states all have basic statues on a few of the Noncommercial towing issues...
but largely it's left up to the LEO to interpret and determine what is safe or UNsafe.
that is gradually changing.
what is also changing is how/if/when the a/s MOTHERSHIP becomes responsible for the actions performed by one of it's dealerships.
in days past they could have legitimately claimed NOT 2 know what is being done...
but now, with everyone knowing that the CORPORATE folks read and use this social/political/advertising knowledge sharing stuff...
it would be very hard for them (a/s corp) to claim they are UNaware of some of these grossly inadequate towing combos.
this eventually connects them (a/s corp) to the rigs and merchant welding those rigs and selling the streams.
once aware of some of the many rigs set up which violate most of the accepted towing standards...
a/s becomes a partner in these rigs by suppling the streams for sale.
pleading ignorance or non involvement is about to vanish.
__________
100s of us here (that's all that really left, still using this outdated forum tool) care and know some of these rigs are silly.
but the single best thing everyone can do who has concerns about marginal or grossly inadequate rigging combos...
is to simply ignore the post/thread or rigging combo question.
sure we care and certainly some of the combinations are wildly dangerous...
but most folks choosing to avoid public health issue (like immunizations) are protected by the herd...
even when their personal actions or behavior is dangerous.
so by ignoring and not posting even a sensible reply...
it will be as if no one was listening when doc brinkley signed on with the goat gland hour of radio...
forget about the popup ads or sidebar ads,
it is the posts/threads that are blatant viral adverts we should avoid.
cheers
2air'
Old 11-14-2010, 08:19 AM   #51
dkottum's Avatar
So the world is indeed flat,
those who have sailed to the edge
have disappeared never to be heard of again.
And he who doubts
is but a crook.
Give me a break.
Old 11-14-2010, 09:28 AM   #52
Road Ruler's Avatar
Images: 38
Originally Posted by Airslide View Post
Hi Andy..
Vinnie
With all due respect, by your statement your giving the impression you think Andy's combinations are difficult to drive and control. The complete opposite is in fact the truth. This is one of the characteristics that folks don't seem to understand.
Regardless of weights and numbers many of these special combination will out perform a traditional truck base combination in every way.
KEY STATEMENT........If you ever have the chance to test drive a Can Am set up as many of us have done you would understand.
Old 11-14-2010, 09:49 AM   #53
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Question Why aren't travel trailers made like a wagon?
Obviously any commercially made vehicle is designed to support its own weight, and any travel trailer can support its own weight. So why don't they put the axles on travel trailers in front and back instead of in the middle with the front one's steerable like a kid's wagon? There would be no need for WD as each would carry only its own weight. It seems to me like that would work fine as long as the braking system and front axle steering was designed properly.
Ken
Old 11-14-2010, 10:02 AM   #54
withidl's Avatar
2002 31' Classic
Houston , Texas
Ken
The assembly would be difficult to back up and there are probably other controlability issues. The common carriers do pull two trailers, the 2nd of which is a FULL trailer, but they are traveling dock to dock where there is a "mule" to deal with the full trailer upon arrival so backing is not an issue.
withidl is offline   Reply With Quote
Old 11-14-2010, 10:27 AM   #55
Ag&Au's Avatar
That brings up another question.
If a computer can take care of all the stability issues of a F-22 supersonic fighter and also a large cruise ship, why not a tow vehicle trailer combination?
Ken
Old 11-14-2010, 10:48 AM   #56
_
using the puter 2 control things has been available for 3-4 years...
with refinement each year, more control variables and wider offerings (trucks/vans/suvs n cars)
the hay wagon notion is proposed here occasionally...
here is one older thread with a link 2 another...
http://www.airforums.com/forums/f437...-tt-27629.html
cheers
2air'
tow vehicles
Airstream Tradewind Land Yacht 25' w/ 1999 Volvo V70xc Tow Vehicle sysgenss Tow Vehicles 9 03-10-2009 03:10 PM
Can a Volvo XC90 tow a Bambi CCD? Thehman 1997 - 2004 Bambi 8 08-15-2004 07:04 PM
Towing with a Volvo 59er Tow Vehicles 1 07-22-2004 01:19 AM
Volvo SUV & Bambi?? Roxie On The Road... 5 11-05-2002 07:09 AM
