Old 06-11-2012, 03:56 PM   #547
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
I drive my '68 Dodge Dart convertible as a regular driver, and the fun outweighs the doubtful brakes and twitchy handling. Regarding airbags, I would not be typing this if I had been driving my Dart last week, when a brand new Camry driven by an elderly driver pulled in front of me from a stop, about 100' ahead. Things happen pretty fast at 45mph, I t-boned her, her airbags went off, mine went off and we're mostly okay, my car is totalled. I was sitting in the Dart afterward, imagining what my would have hit, with just a lap belt. Yuck.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 08-10-2012, 09:42 AM   #548
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Originally Posted by Action View Post
[Snip] Get an entire high mileage (100k miles) doner vehicle that was rear ended and the sheet metal is ugly. You will pay more for low miles and you can cut some of the cost by getting one that has high miles. Face it what ever you do, if you put 50,000 miles after the modification that would be huge so you don't have to spend money on low mileage. And much modern stuff has a expected life of 200,000 miles.
Getting an entire ride means you have all of the engine management pieces. Wiring, sensors, vacuum lines and related parts. Those items will stop your engine and can run a fortune in nickel dime costs. (That's why there are wrecking yards in business!) In addition you might consider taking the front braking, steering and suspension from that ride. At least you have an engineered system...
Good advice, thanks to all who weighed in.
After doing much research (in conjunction with a local hot rod builder) we've decided to mate the Town and Country to a 2004 Durango with the 5.7L Hemi. It was rolled on its roof at -30 mph, creating the unique opportunity for a well-maintained 80K donor vehicle... at 1/3 the price.
I like the notion of keeping it's "soul" in the Mopar family, and I'll probably get big karma points in the recycling department.
The original frame on the wagon is shot after 60 years of road salt and corrosion; putting a newer motor/trans into this old car was only going to prolong the issue.
This Durango has the correct width, length is off by 1" or so, and is a boxed frame derived from the Ram. All non-body parts are in great mechanical condition. We'll simply (yeah, right) mate the old body to the intact Dodge chassis. Everything from 12v wiring to the AC compressor should be able to be reused, I suspect.
Nothing about the running gear will need to change except the wheel size, and perhaps adding airbag suspension, but not sure we'll need to. I imagine we'll also weld on a beefy receiver while everything's in pieces -- I'll consult with Can/Am about maximizing its strength and weight distribution.
Looking forward to all that. Until then, it's all still just make-believe in the driveway...
bredlo is offline   Reply With Quote
Old 08-10-2012, 10:08 AM   #549
Road Ruler's Avatar
Images: 38
Wow wow wow.....what a sweet project. Please post pics when it is all done.
Old 08-26-2012, 08:37 PM   #550
kevinkatz's Avatar
1965 17' Caravel
Curtis Wright
san marcos , Texas
Images: 38
Send a message via AIM to kevinkatz
cool 68 galaxie 500 big block
Classic Car Liquidators 1968 Ford Galaxie 500 big block - $6,999
found this on craigs list in houston. seems like it would be great. would need to add disc and power brakes. not that big a deal. what do yall think? i am not yet in the market and dreaming so feel free to jump on it.
kevinkatz is offline   Reply With Quote
Old 08-26-2012, 08:53 PM   #551
Central , Mississippi
That vintage has a huge rear overhang...
Not ideal for draggin around a trailer...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 09-04-2012, 08:32 PM   #552
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
1972 f350
Here's the ole Ford hooked to the Tradewind. A short jaunt up to Williams from Kingman, about 150 miles, most of it on Route 66. The last 30 miles or so are on I-40 with a 6% grade as you leave Ashfork. I was in 3rd gear all of that hill @ about 40MPH. On the way home the new points (400 miles on them) closed up and presented a few challanges. but other than new Chinese parts the trip was great. I must install A/C before next summer!
ID:	167484   Click image for larger version
Fortune cookie say....."Prudence keeps life safe, but does not often make it happy."
Diesel1 is offline   Reply With Quote
Old 09-04-2012, 10:30 PM   #553
nomad3622's Avatar
2011 23' International
Tafton , Pennsylvania
I have a 23 ft Serenity. I ran across a very nice 1949 Ford F1(1/2 ton) pickup. With the proper WD hitch, do you think it could function as a tow vehicle, safely, for short trips?
nomad3622 is offline   Reply With Quote
Old 09-05-2012, 11:01 AM   #554
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Yeah...we have a '71 Buick Centurion. The looong rear overhang is the max for our '66 Trade Wind. I use 1000# wdh bars and still need to carefully load the trailer with most of the weight over the tandem axles. Sure does tow great though!
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 09-05-2012, 11:04 AM   #555
FreshAir's Avatar
1966 24' Tradewind
My first car was '48 Ford. The '49 truck flat head V8 might not have enough torgue to safely tow your 23' based on my stock '48.
Neil
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 09-05-2012, 03:07 PM   #556
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
There is an aftermarket electronic ignition applications where you can retain the stock look of the distributor. Pertronix is one found here Ignitor You will have to be a little creative in hiding a few pieces. Ford offered another at one point through the Motorcraft line. A direct replacement of the breaker point plate and slip over rotor wheel using some of the existing distributor wiring. This will be hard to find as it was not marketed very well and had low sales. I have snagged a couple of early (first generation) factory (Ford) electronic ignition systems for future needs should that occur.
>>>>>>>>>>>>>Action
Old 09-06-2012, 09:07 PM   #557
Diesel1's Avatar
1967 24' Tradewind
>>>>>>>>>>>>>Action
Thanks for the info. I shall look for the Motorcraft version you speak of. I have considered a Duraspark but am not that impressed.......
Old 09-07-2012, 12:35 PM   #558
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I have done a DuraSpark and it did not have the same OEM look that I wanted.
There is not any Motorcraft conversion kits on ebay at the moment. And they are rare. There is this piece that is close.
ELECTRONIC IGNITION FOR FORD "FE" MOTOR ACCEL CAP MOTORCRAFT | eBay
I am assuming you have a 360/390 in that 350. Or an FE block. If you order a distributor make sure the measurement of the old old matched the new one. The hole is all the same for most distributors even in other Ford blocks. The length of the body does vary even in the FE engine block.
>>>>>>>>>Action
Old 09-08-2012, 12:01 PM   #559
Globie64's Avatar
Images: 18
Thanks for posting the pic of the '72 F-series- I found a campground receipt from 1975 in our trailer, and the listed tow vehicle was a '72 F-series. I always wonder what the original owners towed with when I see an old trailer.
Old 09-08-2012, 12:31 PM   #560
Road Ruler's Avatar
Images: 38
Neil
I had a look underneath a 2011 Mustang Convertible GT(410HP) the other day. Ford uses a couple of extra frame members that help support the rear body structure by boxing that area. They run underneath the rear end. Seems like a good idea. Pics...
Name:	Mustang conv 013.jpg
ID:	167727   Click image for larger version
Name:	Mustang conv 015.jpg
