Old 10-14-2011, 07:30 AM   #29
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I use the tow/haul mode whenever towing the Airstream. I believe that it is better for the transmission. I have done this with the Suburbans and their gasoline engines , and with the new Duramax. I realize that the fuel mileage may suffer slightly, but a few cents saved on gas is easily trumped by an $5,000 transmission repair.
Brian
SuEllyn & Brian McCabe
Old 10-15-2011, 01:09 PM   #30
Hodum's Avatar
1995 34' Excella
Corinth , Mississippi
Headed to the mountains Monday, so i'll be able to tell you a little more about The new truck and it's tow and hall in a few days. But with the 400HP diesel engine it is not going to be short on lugging power, especially when you consider the 800 lbs. ft. torque that this engine boasts. The 2006 F-250 with 6.0 diesel handled my 34 footer just fine in or out of tow and haul, but I usually ran in T&W for the trans. sake. The new 2011 truck has a oddity rear axle ratio, 331.1. I am interested to see how it reacts to towing.
Why settle for anything less?
1995 34ft Classic Excella 1000
2012 Kings Ranch F-250 FX-4, 6.7 diesel, 6 speed auto trans.
TAC # MS-8
Hodum is offline   Reply With Quote
Old 10-15-2011, 03:53 PM   #31
Et Cetera's Avatar
Lynn , North Carolina
IMHO, speaking as a 30 year transmission re-builder,
Most late model overdrive type automatic transmissions use clutches that are almost one half the size used for direct drive (3rd gear) for overdrive. Thus you are using half the total friction surface of direct drive that was only designed/intended to drive the weight of the TV along after it had reached highway speeds. This feature let the manufacturers reach increased mileage numbers, keeping the government and customer happy.
Adding an AS that weighs as much or more than the TV to this clutch pack (overdrive) puts a major strain on the clutches resulting in increased heat generated and if carried far enough clutch/transmission failure.
You might be able to get away with this practice (towing in OD mode) if your TV had plenty of power and you were in flat country, buy why risk it?
Transmissions are expensive to repair.
The reason you have tow/haul or od off as a selection is to prevent this problem. I would advise anyone towing/hauling anything of more than nominal weight to use these features to avoid future failures.
Et Cetera
Et Cetera is offline   Reply With Quote
Old 10-17-2011, 03:14 AM   #32
Flying Cloud STEVE
2010 25' FB Flying Cloud
Carrollton , Texas
Always good to have the sage advice of experts helping me better understand the "why" of tow/haul. Thanks.
Flying-Steve is offline   Reply With Quote
Smallest towing vehicle ? youngh Tow Vehicles 14 08-29-2011 08:09 AM
Passenger van as tow vehicle? DanielB Tow Vehicles 51 05-30-2011 11:02 PM
Tow Vehicle - Toyota Highlander regan458 Tow Vehicles 6 05-13-2011 08:38 PM
Honda EU2000i Vibrates in eco mode only? Patriot666 Mechanics Corner - Engines, Transmission & More... 11 05-10-2011 07:55 PM
Tow Vehicle for 27' Overlander pyrenees Tow Vehicles 9 05-06-2011 08:18 PM
