Old 02-21-2013, 05:07 PM   #1
beetlebob's Avatar
2015 30' Classic
Green Cove Springs , Florida
Thumbs up Using a Ford F650
OK Getting a lot of different answers so I will put this out and see what happens. We want to boondock and stay out for weeks at a time. With that I am thinking of building a Ford F650 . Smallest with factory air ride. I will put a Reading enclosed service box on it to store all the extras I "think" I will need. Extra H2o,generator,full solar system(say 4 panels and everything needed to make it work,maybe a washer and some of those portable coolers/freezers that I saw at the RV show. Now this will be a lot of weight so I feel a 650 should handle this and still have power to pull a 31. Everyone is saying I will destroy the trailer with this much truck. Now with air ride and a air ride hitch how much dama ge could I do ?????. I saw somewhere where someone uses his service truck to pull Airstreams to fix without any problems. I am a newbe want to be and can use all the input I can get to do this right the first time. Will be selling everything to make this move. See the world with your house what more can you ask for. Can you get a stornger frame or make it stronger? Hope you all see what I am thinking and anything you can add will be helpful.
beetlebob is offline   Reply With Quote
Old 02-21-2013, 05:36 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Stand by for lots of "opinions". Personaly to me it seems like over kill.
MICHAEL
Old 02-21-2013, 05:51 PM   #3
1986 31' Sovereign
Miami , Florida
Gotta agree with AWChief, seems like overkill. Unless you are planning the rig to be a "bug out" vehicle in a doomsday scenario.
Mike
Old 02-21-2013, 06:40 PM   #4
nilesrob's Avatar
Marietta , Georgia
Images: 12
I am not technically qualified to answer this. My first reaction is, boo yeah, like to see this bad boy! In truth, I think you may have length issues when trying to fit into campsites, and while I do not understand "air ride" I suspect the strength of the suspension of an F650 may have rivets popping out of your Airstream. Still, sounds intriguing!
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 02-21-2013, 07:50 PM   #5
panheaddale's Avatar
1964 26' Overlander
1968 30' Sovereign
somewhere , Tennessee
FINALLY somebody on this forum has some great ideas about a tow vehicle. You are definitely overkill but you wont ever have to wory about being overloaded. Your tow vehicle is not going to change the way your trailer rides down the road. It doesn't care whether you are towing it with a yugo or your F650 there is no way to damage your trailer with what you tow it with.The trailer has its own suspension and is independent of your tow vehicle. " REMEMBER JUST BECAUSE YOU CAN TOW IT DOESN'T MEAN YOU CAN STOP IT OR CONTROL IT" you my friend can do all the above. Kudos to you for your choice of tow vehicles.
panheaddale is offline   Reply With Quote
Old 02-21-2013, 08:27 PM   #6
Kyle401's Avatar
1969 27' Overlander
SW , Missouri
I'd definitely want an Airsafe hitch with that set up.
Kyle401 is offline   Reply With Quote
Old 02-21-2013, 09:48 PM   #7
Harry W's Avatar
1978 31' Sovereign
Scottsdale , Arizona
While the trailer wheels have their own suspension, the hitch is responding to the TV's suspension. There are numerous threads on front shell separation due to stiff TV suspension.
Harry W
4CU Charter Member
AIR # 13858, WBCCI # 2420
Harry W is offline   Reply With Quote
Old 02-21-2013, 10:25 PM   #8
Livingston , Texas
Go for it! And then we can say a beetlebob and his money are soon parted! Buy the truck and all those freezers and generators, hook up the ol' 'Stream and head down the road. Then kiss goodbye to the frame on the Airstream! Go For IT!!!! Over Kill is a drastic and sad overstatement!
Why not mount the airstream on the bed of the truck? At least THAT wouldn't completely destroy it!
pattydoug is offline   Reply With Quote
Old 02-21-2013, 10:36 PM   #9
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
It's a ridiculous setup.
Rephrase the question to "What tow vehicle, hitch, and Airstream do I need to see the world, and boondock for weeks at a time?"
There are Airstreamers on this forum doing that every day.
doug k
Old 02-21-2013, 10:43 PM   #10
You won't pop any rivets.
I tow with a 1 ton dually with nothing more than the ball. Absolutely no problems for over 15,000 miles now.
Previously had a 3/4 ton SRW with anti sway/weight distributing hitch---contrary to popular opinion, this set up was a much rougher on the trailer with routinely thrown cushions, open cabinet doors, etc.
Load the truck the way it's meant to be loaded and go. You won't need a fancy hitch either.
random 17 is offline   Reply With Quote
Old 02-21-2013, 10:52 PM   #11
dkottum's Avatar
You may be lucky enough to never have to make a quick emergency maneuver at 65 mph.
doug k
Old 02-21-2013, 10:54 PM   #12
doug k
Actually, I have.
Old 02-22-2013, 12:00 AM   #13
Bigjohn59's Avatar
1966 26' Overlander
1978 31' Sovereign
Glenburnie , Ontario
Go for it, I'd like to see an air ride airstream trailer too!
Bigjohn59 is offline   Reply With Quote
Old 02-22-2013, 05:34 AM   #14
beetlebob's Avatar
2015 30' Classic
Thanks for all the input. Hope to get more. Never thought of being a doomsday prepper. Not a bad idea if you think about it. The wheel base is the same if not just a bit longer than a XLT 350 with crew cab,so leangth is not a issue. Since it is commercial it is built to last say 500,000 + miles, so should be the last truck I buy before I can not longer drive because I will be say 100 years old. Also it is nice to have the money to spend.What I am wondering is when so many people say they are damaging there trailers with a 3/4 ton truck what are you doing to your trailers???? With air ride and air hitch I think almost no ride from truck should be transfered into the trailer. What say all you out there using a 1 ton to pull. I say use what you have. Pulling is good stopping is better.
Ford F150 3.5L Eco Boost tlcbuilder Tow Vehicles 601 05-19-2014 08:05 PM
Ford 150 EcoBoost experience GaRoc On The Road... 5 11-17-2011 04:59 AM
No more Toyota vs. Ford Threads!!!! Denis4x4 Tow Vehicles 1 08-23-2011 07:12 AM
Ford 250 4x4 diesel mileage GaRoc Mechanics Corner - Engines, Transmission & More... 3 08-10-2011 07:59 AM
