Old 01-22-2015, 08:53 PM   #1
Tom and Phyllis
Lucky Tom's Avatar
2009 23' FB Flying Cloud
Tuscaloosa , Alabama
Usage rate for DEF
I have finally located a site than attempts to predict how much DEF an engine will use.
Default dosage rate is 3% DEF per every gallon of diesel fuel based on engine manufactures suggestion.
This is the website. Hope it helps, so we can carry enough of the stuff with us.
Diesel Exhaust Fluid - DEF - DEF Usage Calculator
On their web site put in the distance and the average mpg and it will figure the amount you will need based on 3% rate of infusion. If you can find out if your engine uses a different rate you can change the 3% to whatever.
Tom, Phyllis, and Snowy, the white Siberian Husky
2009 23ft FB Flying Cloud
2015 Ram 2500 Cummins Turbo Diesel Crew Cab
LD Valley w/ 800 lb trunion bars
Honda eu3000is generator
Lucky Tom is offline   Reply With Quote
Old 01-22-2015, 08:55 PM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Why do you want to carry more than maybe 2.5/gl carton?
Old 01-22-2015, 08:59 PM   #3
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Since the stuff is available everywhere, I don't know why you would want to be caryring extra.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 01-22-2015, 09:11 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The DEF tank holds plenty...for any trips... we can find it in most places... If headed to the deep dark area, load up..
When Warranty expires, it would be a shame if the def stuff fell off on the road somewhere..
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-22-2015, 09:26 PM   #5
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Good strategy. I fear the engine shut down mode but one small jug would hold you over a few hundred miles...
I can never tell how long it's going to last. When I'm towing it seems to use more. I filled it up the end of the summer and it still says it's "ok" (really wish it gave a %age remaining...).
SteveSueMac is online now   Reply With Quote
Old 01-22-2015, 10:00 PM   #6
2016 30' Classic
Erie , Colorado
3% rate is double my usage rate. Probably accurate for a semi.
GMC 2500 Duramax has been running right at 1 gal per 1,000 miles.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 01-23-2015, 09:45 AM   #7
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Did an 8500 mile trip last summer, did replenish the DEF tank a few times (RAM has a gauge like the fuel gauge, so not hard to know when to refill). Usage rate varied based on terrain. Going through the Rockies used more DEF (and diesel!) than the flatlands. It is available just about everywhere -- if they sell diesel fuel they have DEF (my experience anyway). You can also get it -- sometimes on special -- at AutoZone or Walmart. Not a big deal.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 01-23-2015, 10:09 AM   #8
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Ford 6.7 averages 13.7 MPG towing 30' AS and uses less than a gallon of DEF every 1,000 miles. I carry 2.5 Gallons just in case, more camping neighbors have used it than I have.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 01-23-2015, 11:19 AM   #9
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I am averaging 1200 miles to the gallon. It is readily available at truck stops, many at the pump, any auto parts store, sam's club and walmart. It has a shelf life of 2 years or less depending on storage temperatures.
When i got the 13 Ram I bought a 2.5 gallon jug and carried it around for over 6 months so now I buy as needed.
If you do a Google search you can find out how to read the date code on the Peak Blue Def boxes which seems to be the most common brand
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-23-2015, 01:43 PM   #10
gecko's Avatar
2009 28' International
Pacific Palisades , California
Def for Sprinter
We tow with a 2013 3500 Sprinter that has a 5 gal DEF tank. We get almost exactly 10K miles out of the tank--2,000 miles/gallon of DEF. The Sprinter allows 16 starts after the warning, and because the DEF is so wildly available--autoparts stores, and every truck fueling spot--we've ceased to worry about it!
gecko is offline   Reply With Quote
Old 01-23-2015, 01:53 PM   #11
dznf0g's Avatar
Oswego , Illinois
DEF usage is a function of fuel usage. As such, miles per gallon of DEF isn't accurate for comparison. Gallons of fuel per gallon of DEF is the correct "gauge". Anything that causes fuel mileage variation will distort a miles per gallon of DEF analysis. Idling, towing, solo, mountains, wind.....etc.
There's really no need to carry any. On GMs, a readout comes on at 1000 miles left, 600 miles left, 200 miles left....and a couple others as you are about to run out. (I've never run it below 200 miles left message. I think the messages are explained in the owner manual.
-Rich-
Old 01-23-2015, 02:03 PM   #12
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have a 2011 Chevrolet 3500 Duramax with 80,000 miles on it. I have been averaging 1,000 miles per gallon of DEF used. I keep a log on when I last added DEF. I have found the DEF warning feature on the vehicle to be completely unreliable. My driver information center indicator has been showing that I have a 460 mile DEF range for the last 30,000 miles. It has been to three different dealers and none have been able to correct it.
Brian
SuEllyn & Brian McCabe
Old 01-23-2015, 02:06 PM   #13
dznf0g's Avatar
Oswego , Illinois
will PM you, Brian.
-Rich-
Old 01-23-2015, 07:51 PM   #14
2012 30' Classic
Homosassa , Florida
My 15 Silverado 2500 duramax has 17000 miles on it mostly towing. When I'm doing 14-1700 mile tows I pick up a carton at Walmart and usually add it on the road somewhere when refueling. When it gives me a percent left I add the 2.5 gallons as the percent seems to go down more quickly than I would expect. Otherwise I never carry DEF with me. Always check the date code.
Tater is offline   Reply With Quote
Diesel/DEF mileage. ROBERTSUNRUS Tow Vehicles 28 03-19-2014 11:47 AM
DEF Fluid eliasurbina Sprinter and B-van Forum 8 11-23-2013 11:29 AM
Def aa9zz Sprinter and B-van Forum 4 10-03-2013 11:34 PM
Diesel Exhaust Fluid (DEF) Brentsouth Sprinter and B-van Forum 17 04-13-2013 02:18 PM
Hi-Def on the road????? FlaAirstream Full-Timing 2 11-26-2007 06:30 PM
