Closed Thread
Old 07-09-2015, 01:32 AM   #295
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
jcl ,
The letters CGVWR mean Combined Gross Vehicle Weight Rating .
That means the weight of the 2008 Honda Odyssey and the 34' Airstream in this case can not exceed 8,410# according to the 2008 Honda Odyssey owners manual .
Unfortunately Andy's rig weighs 13,000# and that my friend is 4,590 # heavier then the CGVWR or about the same as the unladen weight of another 2008 Honda Odyssey .
What part of this don't you and Andy understand.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline
Old 07-09-2015, 04:15 AM   #296
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by Moflash View Post
A 2012 on up 3/4 or 1 ton rides smother than a maxed out 1/2 ton.I know as I have had them all.
Originally Posted by BoldAdventure View Post
How about one that isn't maxed out?
I can only speak to my 1995 & 2006. Our 06 2500 is equipped with Autoride, electromagnetic shocks front and rear, no auto leveling.
It handles better and has a much smoother ride than our 95 2500. Loaded or empty. (LT265/75/R16 Michelin)
Neither Burb caused any trailer damage.
ROBERT CROSS is offline
Old 07-09-2015, 04:21 AM   #297
2014 27' FB Eddie Bauer
Orleans , Ontario
Hello, I've learned quite a bit from this discussion, from all parties who clearly are passionate about their positions. Just to throw another number into the mix, the government of British Columbia uses all of the same guidelines but adds another. In BC, the tow vehicle cannot exceed the weight rating (which of course includes any weight transferred by the hitch but which does not include the weight of the trailer itself. The trailer must also remain within it's own axle weight ratings. In addition, and this is the number that seems to be interesting, BC recommends 1 horsepower per 150kg of weight in the complete rig. So in the case of the Honda Odyssey - unless a lot of horsepower has disappeared - there should be no issues as he must have at least 93 HP (at least if my math is correct - which can be suspect as an Arts major) to safely pull his rig and I suspect that most of the original 200+ HP is still available in his engine. http://www.th.gov.bc.ca/cvse/referen...info_sheet.pdf
Shawn & Kara
Hamish is offline
Old 07-09-2015, 04:24 AM   #298
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Two Airstream rollovers in a month
Will a one ton truck stop trailer sway?
If my truck is not "trail rated" does this mean that I may not take it off the pavement?
Sorry guys. There are a lot of people who think adding up weight that does not even rest on a tow vehicle makes all the difference in the world regarding safety, but it does not.
There are countless safe miles driven where vehicle of less than "3/4 ton" have performed quite well.
I find it a bit irritating when a person, or even worse, when a mob of people emphatically state a thing is "unsafe" where it is demonstrated that it is safe by the experience of countless people. (They are all liars or just stupid I am sure)
For crying out loud, you guys have even convinced a BAMBI OWNER that he needs a at least a 3/4 ton truck... Lol, SERIOUSLY?
I am sorry folks, even if you do read all 927 pages of your ridiculously mundane and boring government/lawyer mandated owners manual, that does not make you a towing expert.
Now, are all of you "1/2 ton deniers" going to pitch in and help the afore mentioned Bambi owner buy his "necessary" new Kodiak tow vehicle?
J. Morgan is offline
Old 07-09-2015, 05:24 AM   #299
Thumbs up
J.
Point well taken...but some us don't opt for 3/4 'cuz of towing ability but payload capacity.
In our case, GVAR's give us the ability to load as needed,(for us), and still have the wiggle room to have what I consider a satisfactory safety margin.
25' Classic
Burb
DW
Dog
Boat
Hensley
& Lotsa stuff
Old 07-09-2015, 05:49 AM   #300
Gainesville , Florida
Mo flash, please don't confuse these people with logic truth!
xrvr is offline
Old 07-09-2015, 07:36 AM   #301
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Give me a break.
We bought our Ram 1500 for its safe and controllable handling in emergency maneuvers with and without the Airstream attached, more than adequate braking ability, excellent towing stability (which is a matter of hitch setup, suspension, and tires, not size), very comfortable ride, easy daily driving and maneuvering, and less top heavy making it less likely to roll over and less likely to crush the cab and injure us if it does. It's also less rolling mass to stop quickly when you have to.
If you must travel heavy then you must have a heavy duty truck. Unfortunate choice if overall safety is the concern. If you can manage your gear and weights you can travel and daily drive a variety of light duty trucks, vans, and SUVs that are better suited for the safety and well-being of the passengers as well as others on the roadway.
Doug and Cheryl
dkottum is offline
Old 07-09-2015, 07:41 AM   #302
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
at risk of hijacking/trolling this thread...
Andy, I'd love to see CAT slips on your rig.
boondockdad is offline
Old 07-09-2015, 08:10 AM   #303
Oh my....well, at least it's my 'unfortunate choice'.
Old 07-09-2015, 11:00 AM   #304
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Originally Posted by dkottum View Post
Give me a break.
Who recommended a short box regular cab 2wd 1/2 ton for your application?I just can't imagine some one recommending this for a 25ft Airstream TV.
Moflash is offline
Old 07-09-2015, 11:08 AM   #305
jcl
Vancouver , British Columbia
Originally Posted by Glenritas View Post
jcl ,
I can't speak for Andy, but I understand just fine what Honda means. They are using the term to define a tow rating. I don't know where you get the term CGVWR, since you quoted the Honda owner's manual as your reference, and that manual calls it GCWR. The term is commonly used for commercial vehicles which require licensing for the combined tow vehicle and trailer weights. It is another way of stating the tow rating, one that easily allows a manufacturer to reduce the tow rating by the effect of payload in the tow vehicle.
You still haven't answered the original question in response to a claim you posted some time back:
On this side of the US boarder (sic) it is unlawful to exceed the tow rating and will get the lawyers involved in case of an collision
We all agreed that GVWR, axle ratings, and tire ratings have legal significance. It appears we are still waiting for the reference that in the US, a tow rating (or a combined vehicle weight rating, effectively the same thing) has legal significance for non commercial vehicles. Perhaps your republic regulates tow ratings, I don't know. But it seems a stretch to claim that such a law applies to all of the US.
Out of interest I did look up the California motor vehicle laws. I found a reference to non commercial towing for RV trailers over a certain weight. The requirement was that the tow vehicle weigh at least 4000 lbs. So there is one legal requirement.
Cheers
Jeff
jcl is offline
Old 07-09-2015, 12:28 PM   #306
Glenritas's Avatar
1969 25' Tradewind
Jeff there are 50 states on this side of the us border. All have laws and regulations as do all your Canadian Provinces .
I am not going to search through any of them for you.
Bottom line is Andy's rig is way beyond the factory specs . See pages 396 - 408 in the 2008 Honda Odyssey owners manual regarding towing http://techinfo.honda.com/rjanisis/p...8/HJ0808OM.pdf
That will contribute to Andy's down fall as a defendant in a civil or criminal case. Believe me when I say the lawyers will have a field day. They will look at every law , search the internet and any other resource they have up their sleeve.
At this point I'm done . My Point has been made deal with it.
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
Old 07-09-2015, 01:49 PM   #307
2015 16' Sport
Portland , Oregon
Thanks all again for this thread. It motivated me to research all the capabilities and options of my tow vehicle. I'm pleased to be well guard-banded but will still be even more careful.
leedav is offline
Old 07-09-2015, 04:28 PM   #308
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
I use a short bed regular cab truck to tow my 31 footer, I am perfectly comfortable driving at highway speeds and even with one hand most of the time.
It stops, it goes, it handles, and it steers,,,,, really well thank you very much....
Closed Thread
Just saw two Airstream motorhomes inside of two minutes tevake Classic Motorhomes 8 10-31-2014 12:30 AM
"Alice" Month Two on the polish. zagarino Cleaning, Stripping & Polishing 3 05-08-2012 08:13 AM
Two 12V vs. two six volt batteries spat61 Land Yacht/Legacy Motorhomes 37 04-22-2010 11:50 PM
Two plus two cello The Pet Forum 1 09-26-2006 02:00 PM
Two 6 volts or Two 12V series 27 LI Pets Electrical - Systems, Generators, Batteries & Solar 0 09-07-2006 06:06 PM
