Old 04-09-2008, 09:25 AM   #1
Road Ruler
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Images: 35
TV's and Trailer testing from the UK
This is a cool glimpse of what is happening on the other side of the pond.
No WDH's are used as the tongue weights are light.
Towcar of the Year | Video Features | Videos | Auto Express
Old 04-09-2008, 10:01 AM   #2
SteveH
SteveH's Avatar
Profile:  2001 25' Excella
San Antonio , Texas
We were in England last year, and I did notice some rather small vehicles towing travel trailers, or what they call Caravans. The thing is, it's very different over there because they don't drive the distances we do, cannot drive as fast as we can on our interstate highways, and their "Caravans" are exceptionally light weight in comparison to the trailers we have in this country. Like you mention, they do not use weight distributing hitches either, but you do see tow vehicles that are very low in the rear. Another thing...in England they have a tax system on the truckers that virtually eliminates them from the highways on holidays and weekends. It is my opinion after seeing them, their rigs would be very dangerous in this country.
Old 04-09-2008, 12:59 PM   #3
Wayward
Wayward's Avatar
Cary , North Carolina
One must also keep in mind that the laws of physics are different over there. Applied in the US they would most certainly render such rigs unsafe on our highways.
2006 Safari SE FB
2000 F150 4.2L
Raleigh, NC
Old 04-09-2008, 02:05 PM   #4
SteveH
SteveH's Avatar
San Antonio , Texas
OK.....that's one that will have to be explained to me.
Old 04-09-2008, 02:32 PM   #5
Wayward
Wayward's Avatar
sorry - just kidding.
2006 Safari SE FB
2000 F150 4.2L
Raleigh, NC
Old 04-09-2008, 03:05 PM   #6
tinhutjohn
tinhutjohn
tinhutjohn's Avatar
Profile:  1974 29' Ambassador
London , Ontario
That's because it's in Imperial gallons and not US gallons. You measure weight in stone and distances in furlongs. As a result the laws of physiques do not apply the same way.
What's that?
I'm to shut my blow hole
Right-y-oh.
Sarge
74 Airstream Ambassador International
94 Burb Ontario plate "TIN HUT"
02 Jetta TDI
Logan the Large hairy Golden Retriever
It's a monocoque thing
You wouldn't understand
tinhutjohn is offline   Reply With Quote
Old 04-09-2008, 03:23 PM   #7
Road Ruler
Road Ruler's Avatar
Images: 35
I tend to agree Steve. The weak link in their combinations appear to be the Mickey Mouse connection. Light tongue weights, no wdh, and a crude clamping device that applies friction to the ball that acts as a stabilization, antisway solution.
Solve their connection issues and then no doubt we would have something.
The other issue the video shows is their light weight, box type trailers. Most with only single axle. With limited sway control they must get blown around a lot with crosswinds etc. Having a well designed aerodynamic TT like our Airstreams would have a huge advantage in that respect.
Even still with what they have to work with it is impressive to see that they handle and perform as well as they do.
Old 04-09-2008, 03:50 PM   #8
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
This is not actually far from the truth. It's more like they've applied the physics to use different proportions & weight distributions. Their tradition is to place the axle a bit more forward. Take note of the relative position of the single axles at Airstream-Europe. Then note the "nose weights" as a proportion to the curb weight (MIRO I think) at the link here. With the relative axle position long a tradition in the U.S., anything under 10% (and definitely 8% and below) can be a really goosey tow -- like throwing an arrow backwards. They're not right or wrong -- just different.
Airstreams already suffer by comparison to the huge American SOBs & 5th wheels, so market forces may be off-putting to Thor. These small European Airstreams would actually be fun to see on this side of the ocean. And the galvanized frames?!?!!!! But I suspect the narrowness wouldn't grab the U.S. psyche. It would take $4 a gallon gas to do that. Oh wait...
Old 04-09-2008, 04:49 PM   #9
AlbertF
Profile:  1975 27' Overlander
In the Kootenays , BC
I suspect the axles on the European caravans are moved forward precisely to reduce the "nose weight". Stability is function of design, and there's nothing magical about 10% - it's just required for typical North American designs.
The European caravans have the weight (mass, to use the technically correct term) concentrated very low over the axles, meaning that less tongue weight is needed to achieve acceptable stability. There are no slides to put weight up high or out toward the ends of the trailer, and water and waste tanks are small too.
This also helps to explain why it's possible to tow boats with 8% tongue weight, while toyhaulers with slides need 15% tongue weight (and at least a 3/4 ton truck to carry that 1200 to 1500 lb tongue weight too). With Airstreams, 11-12% tongue weight is probably quite acceptable in most cases.
AlbertF is offline   Reply With Quote
Old 04-09-2008, 05:12 PM   #10
CanoeStream
Images: 13
Exactly! A very good explanation -- worthy of karma methinks.
Old 04-10-2008, 12:12 PM   #11
Airstreamer67
Airstreamer67's Avatar
Profile:
I wish Airstream would offer a 27-foot trailer with a rating of 3850 pounds dry / 4818 pounds wet, in the US, as they do in Europe.
They used to. Then they got fat. Like the rest of us.
Maybe with $8 per gallon fuel, like over there, they will again. Although such a thought is difficult to ponder.
Airstreamer67 is offline   Reply With Quote
2 TV's, one HAHA? finalcutjoe Hitches 22 05-01-2008 12:58 PM
LCD TV's jcanavera General Interior Topics 58 11-19-2004 07:27 AM
Anchoring tv's and stuff Rog0525 Our Community 20 02-21-2004 08:16 AM
Tv's and such zduke4x Airstream Motorhome Forums 3 09-26-2003 08:43 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
