Old 12-29-2006, 08:22 PM   #1
1996 34' Classic
FordTruck's Avatar
1996 34' Excella
Locust Grove , Virginia
Images: 8
Question TV Shock replacement recommendations
All,
I've got a 2005 F-150 4X4 SuperCab with 5.4L and about 16k miles. The truck rides well but "floats" when going over undulating roads (surface streets and Interstate). I want to stiffen up the suspension and improve handling for both the TV and TT.
The local parts store recommends Bilsteins and says that there are very few choices for a truck this new. JC Whitney has a couple of options but I'd like to hear from anyone out there in AS land who has a recommendation.
FT
P.S. I've searched the threads here and most of the TV shock questions are a couple of years old.
FordTruck
2016 GMC 2500HD Denali (Betsy 4)
1996 34' Excella 1000 (Arvin3 as this is our 3rd AS)
2010 TREK 2.3
Fair is where they put ribbons on pigs.
FordTruck is offline   Reply With Quote
Old 12-29-2006, 08:28 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Bilsteins seem to be pretty good. A number of new trucks come with them from the factory and I have then on my sedan.
I got mine from shox.com at the time a few years ago, they had the best price on them.
Old 12-29-2006, 08:29 PM   #3
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Bilsteins.
Try shox.com
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 12-29-2006, 08:41 PM   #4
1960 24' Tradewind
santa barbara , California
The other option I would say is KYB, another great shock that has found its way from import racing in the 70s to mainstream vehicals of today .Carquest auto parts stores have drop Gabriel and now offer KYB for most all vehicals .
Scott
scottanlily is offline   Reply With Quote
Old 12-29-2006, 08:49 PM   #5
1971 31' Sovereign
Cleveland , Tennessee
I have replaced shocks on two of our trucks we use for towing with bilsteins. One a 3/4 ton the other a 1 ton and they helped alot but the old ones were wore out. I don't know how much difference you are going to noticed with new shocks with such few miles on yours.
Smuzz is offline   Reply With Quote
Old 12-29-2006, 08:49 PM   #6
Aluminut
2004 25' Safari
. , Illinois
Scott
Are the KYBs the adjustable ones?
Old 12-30-2006, 11:02 AM   #7
_
hi fordtruck...
the shocks may make a difference, but i'd do 2 other things first...
-check air pressure in the tires....what are you running?
just a few psi difference can be equated to higher spring ratings.
-add a rear anti sway bar with polyurethane bushings,
and consider a larger/stiffer bar on the front,
or at least change the bushings from rubber/butyl to polyurethane...
imo you will notice tire adjustments and the anti sway bars more than shocks and the modificationn is much easier to do...
i'm sure lots of guys on the ford truck forums have dealt with this issue too...
cheers
2air'
Old 12-30-2006, 12:50 PM   #8
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Rancho 9000s
Hey there Ford Truck,
You may wish to investigate the Rancho 9000, manually adjusted shocks with a lifetime guarantee. Once my factory shocks wore out on my previous TV, I installed the Ranchos. They worked great even though I didn't get to test out the lifetime bit. The only problem is getting under the TV to dial in the settings prior to towing the Airstream. Rancho also makes some that you can dial in from inside your TV, howeve; all the air lines, possibility of problems and added cost didn't seem practical to me. Once my current shocks get spongy I'll go back to the Ranchos. Bilsteins are a great procuct as well. Good luck with your decision and Happy Trails
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 12-30-2006, 01:27 PM   #9
S C Streamer's Avatar
1964 17' Bambi II
Santa Cruz , California
Images: 13
Rancho 9000 or Bilstein..
Hi FordTruck,
For non-adjustable I'd go with Bilstein...
For adjustable the Rancho 9000 work very well.
I used the Ranchos on my previous truck with a cab-over camper. I set them on soft (# 1) when the truck was empty, and on firm (# 5) when I hauled the camper. They really made a difference.
Mark
1964 17' Bambi II
2005 Dodge 2500 PowerWagon -5.7 Hemi
WBCCI #4207
AIR #11485
"you don't need a weatherman to know which way the wind blows" ~bob dylan
S C Streamer is offline   Reply With Quote
Old 12-30-2006, 02:11 PM   #10
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
I installed the Rancho 9000 adjustable shocks and a Hellwig rear sway bar. Ordered the shocks from Sam's Off Road - had a good deal, buy 3 get 1 free. The OEM shocks were junk. Big difference with the new ones. The jury's still out on the sway bar. I think any quality aftermarket shock will make a noticeable difference.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 12-30-2006, 02:21 PM   #11
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Have you thought about talking to a dealer or after market truck place about adding a leaf or two to the springs. May be a better more cost effective long term solution...?
Old 12-30-2006, 03:03 PM   #12
1964 17' Bambi II
Images: 13
IMHO, Air Bags are a good choice because you can let the air out for a smoother ride when your truck is unladen, and you can add air for better load handling. Air Bags will NOT increace your payload capacity.
I used Air Bags on my previous truck/cab-over camper with very good results.
Mark
1964 17' Bambi II
WBCCI #4207
AIR #11485
Old 12-30-2006, 07:47 PM   #13
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Edelbrock!
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-30-2006, 10:05 PM   #14
Aluminut
2004 25' Safari
. , Illinois
Originally Posted by davidz71
Edelbrock!
Didn't know they made shocks.
How do you like your Mag-Hytec diff cover Craig?
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 07:15 PM
63 TW shock Moonshot Shocks 5 08-26-2002 09:24 AM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
Replacement shocks rdm Mechanics Corner - Engines, Transmission & More... 16 04-24-2002 08:13 PM
