Old 12-30-2006, 11:26 PM   #15
Motoman's Avatar
2005 25' International CCD
1960 18' "Footer"
Riverside , California
KYB are good shocks but in my experience too stiff. Air bags help support weight but not dampen the suspension movement. Bilsteins are the only choice. Most factory off-road suspensions, Toyota, GM, Dodge Power Wagon, etc. use them. I have had them on Two Saabs (factory installed on our Turbo), two Jeep Cherokees and one Dodge pickup.
Don (KD6UVT) & Gail Williams
What do you want to be in life, a spectator or a participant?
SNU #157
FCU #004
Motoman is offline   Reply With Quote
Old 12-31-2006, 12:01 PM   #16
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Originally Posted by Silvertwinkie
Didn't know they made shocks.
How do you like your Mag-Hytec diff cover Craig?
The Edelbrock shocks have been around for a few years and have special valving. You might look up their info. Bilsteins have always been good as many early Chevy Z71 truck owners have found out.
The Mag-Hytec diff cover is one of the smartest additions you can make for a towing vehicle. Once you replace it, it is so easy and quick to drain the fluid at the intervals you feel comfortable with. To borrow an advertisement phrase, "It's so easy, even a cave man can do it." Thanks Geico.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 07:15 PM
63 TW shock Moonshot Shocks 5 08-26-2002 09:24 AM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
Replacement shocks rdm Mechanics Corner - Engines, Transmission & More... 16 04-24-2002 08:13 PM
