Old 12-02-2008, 12:33 PM   #1
64GlobeTrotter68Overlande
man7sell's Avatar
1964 19' Globetrotter
1969 27' Overlander
Snohomish , Washington
TV Jag XKR??
OK so we own a perfectly sensible 2002 Jeep Cherokee V8 as a TV. But I have a 2000 Jaguar XKR 390 HP twin supercharged rag top and it's silver. Anyone thing it would tow my 68 19' Airstream?
man7sell is offline   Reply With Quote
Old 12-02-2008, 12:44 PM   #2
cameront120's Avatar
1972 25' Tradewind
It has the power for it.
North Vancouver, BC
Old 12-02-2008, 01:10 PM   #3
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
The trick will be finding someone willing to engineer a hitch with a capacity sufficient to handle the tongue weight and GTVW. Your vehicle was not thought of as a tow vehicle by its designers so necessary accommodations were not made. Not saying it can't be done. It'll be custom every step of the way... bet it'll look wicked cool, too. Good luck!
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 12-02-2008, 01:39 PM   #4
Road Ruler's Avatar
Images: 38
Oh my, an XKR!
A few years ago there was a late model Jag sedan at the Toronto RV show. It was on display with a big Airstream connected.
If anyone could make the XKR work as a TV it would be the folks here in Ontario who specialize in such combinations. This is forum member Andrew T's Airstream dealership....
Andy Thomson
Airstreamer since 1968
Can-Am RV Centre
The Towing Specialists
London, Ontario.
www.canamrv.ca
Old 12-02-2008, 03:36 PM   #5
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Yeah go for it... it will look so cool, Wish I had a hitch on my jag..
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 12-02-2008, 05:18 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Wish I had jag on my hitch. Are you listening Santa?
Lumatic is online now   Reply With Quote
Old 12-02-2008, 05:24 PM   #7
purman's Avatar
1968 28' Ambassador
Those are hard to fit in the stocking, but fit well in the garage.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 12-02-2008, 05:34 PM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
Obviously, you have not seen my garage. I couldn't even fit a MG Midget in there. Haven't had a car in it for years. It's all full of Airstream parts.
Old 12-02-2008, 05:35 PM   #9
BWH-Utah's Avatar
1965 22' Safari
Salt Lake City , Utah
Sounds like it could be fun, hair blowing in the wind. My first car was an MGA what a blast. BUT
Some things to consider:
weight of TV (Jag XKR = 4021 lbs) - it's nice to have that about the same as the trailer. You should be OK here.
wheelbase (Jag XKR = 102 in) - according to this site that should be OK for a 19 foot trailer.
RV Towing Tips - How long?
transmission - The jag certainly has a tranny strong enough for a 390 hp V8, but how about duty-cycle. There is a difference between running hard (full throttle) up through the gears then leveling off at cursing speed, and pulling a trailer hard hour after hour. That might require a transmission cooler at a minimum.
frame stiffness - The Jag being a rag top has to have all its frame stiffness in the uni-body below the doors, unlike hard tpos that gain a lot of stiffness from the roof. Don't know how to advise you on this, but you should look into it especially if you are planning on using an equalizer hitch, which is a good idea with any TV that is not clear over-kill.
Good luck,
BWH
BWH-Utah is offline   Reply With Quote
Old 12-02-2008, 05:35 PM   #10
Road Ruler's Avatar
Images: 38
If Santa was smart he would turn in the sleigh for an XKS. With 390 horses the reindeer could be turned out to pasture and Santa could be home by midnight with the nights work all wrapped up.
Old 12-02-2008, 05:45 PM   #11
Road Ruler's Avatar
Images: 38
Good luck,
BWH
Good points BWH. A vehicle that sized is heavy considering it has a pile of aluminum in it. That bottom sub frame must be substantial. Some investigation needs to go into the tranny durability issue but based on other car based vehicles we know about that are towing Airstreams one might suspect (no sure though) that if would probably be fine with the cooler.
The other issue is the turbos. If only needed for short bursts no problem but I doubt if they are designed to run continuously. "hot hot hot"
Old 12-02-2008, 10:03 PM   #12
purman's Avatar
1968 28' Ambassador
Yeah, my detached garage is starting to be like that too.. Thank goodness I still have the attached 2 car and my Barn..
Hey, I should buy a couple more AS to fill them up with....
The Jag goes in the detached garage, but won't fit right now... and it's starting to snow at night... Better get a cover for it.
Sounds like you need a garage sale...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 12-03-2008, 06:02 AM   #13
man7sell's Avatar
1969 27' Overlander
Wow lots of good (and fun) feedback. I will have to look into any Jag limitations. There are no turbo, just full time twin intercooled superchargers. They do run hot hense the intercoolers and cool hood vents.
Then my other TV is a 1945 Tugboat called Steel Drum. 439HP Catapillar. Think Airstream on a barge
Old 12-03-2008, 09:04 AM   #14
purman's Avatar
1968 28' Ambassador
Airstream boat house, Now that could be cool, pull up to the dock hook up the Jag and off you go...
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
