Old 12-03-2008, 10:03 AM   #15
newbie
audiobox's Avatar
Fort Wayne , Indiana
I had a '59 Jag Mk IX for a while in the late '60s when I lived in LA . I had a fantasy a few months ago about how cool it would be to upgrade the drive train of one of these great cruisers and pull a small airstream. They've got the wheelbase, frame and weight. But it would be a project, for sure.
Here are some specs: http://en.wikipedia.org/wiki/Jaguar_Mark_IX
http://www.septaudio.com
audiobox is offline   Reply With Quote
Old 12-03-2008, 11:55 AM   #16
1975 27' Overlander
High River , Alberta
Originally Posted by BWH-Utah View Post
transmission - The jag certainly has a tranny strong enough for a 390 hp V8, but how about duty-cycle. There is a difference between running hard (full throttle) up through the gears then leveling off at cursing (cruising?) speed, and pulling a trailer hard hour after hour. That might require a transmission cooler at a minimum.
My guess, based on some aerodynamic assumptions and running numbers through an online aerodynamic drag calculator, is that towing an Airstream at 60 mph requires about the same horsepower as solo cruising in the 90-100 mph range. Easy running for any well-designed car.
AlbertF is offline   Reply With Quote
Old 12-03-2008, 12:27 PM   #17
TinLoaf's Avatar
2006 25' Safari SS SE
Trenton , Illinois
Images: 22
My little Jaguar X-Type with the tiny 2.5 liter has a tow rating of 3,400 pounds. It's probably not out of the question, although I can't recommend it.
Steve
TinLoaf is offline   Reply With Quote
Old 12-03-2008, 04:27 PM   #18
Road Ruler's Avatar
Images: 38
Interesting Jag TinLoaf. Here are the specs on your X-Type....
Exterior Length: 183.9 in. Width: 70.4 in. Height: 54.8 in. Wheel Base: 106.7 in. Ground Clearance: 6.1 in. Curb Weight: 3428 lbs. Interior Front Head Room: 37.8 in. Front Shoulder Room: 54.5 in. Rear Head Room: 37.5 in. Rear Shoulder Room: 53.7 in. Front Leg Room: 42.4 in. Rear Leg Room: 34.4 in. Luggage Capacity: 16 cu. ft. Maximum Cargo Capacity: 16 cu. ft. Maximum Seating: 5 Performance Data Performance Acceleration (0-60 mph): 7.9 sec. Base Number of Cylinders: 6 Base Engine Size: 2.5 liters Base Engine Type: V6 Horsepower: 192 hp Max Horsepower: 6800 rpm Torque: 178 ft-lbs. Max Torque: 3000 rpm Drive Type: AWD Turning Circle: 35.7 ft.
It is Interesting that we towed our 23' Airstream with a Nissan Van that had 150HP/180Tq and it weighed 4,200lbs. Your 2.5 V6 Jag has a better power to weight number. The X is also based on the European Ford Mondeo format which in Europe has a 5,000lb tow rating. The X could possibly be quite a good TV.
Old 12-03-2008, 04:49 PM   #19
Images: 59
Originally Posted by man7sell View Post
. . . Then my other TV is a 1945 Tugboat called Steel Drum. 439HP Catapillar. Think Airstream on a barge
That sounds downright callipyginous!
Old 12-04-2008, 06:54 AM   #20
64GlobeTrotter68Overlande
man7sell's Avatar
1964 19' Globetrotter
1969 27' Overlander
Snohomish , Washington
Now Mark, did you know my last boat, a 42' sailing cutter with a canoe stern was called Callipygian?
man7sell is offline   Reply With Quote
Old 12-04-2008, 12:41 PM   #21
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Hey, I've seen your trailer! I bought my aluminum tanks from the gentleman from Anacortes... he proudly showed me his trailer.. and his workshack with old Dodge slant 6 motors in it. Neat guy.
Enjoy the trailer, it seemed pretty neat when I saw it.
Marc
Old 12-04-2008, 03:16 PM   #22
Images: 59
Maybe you're more famous than you thought.
