Old 02-03-2011, 08:28 PM   #1
1998 25' Safari
Buda , Texas
TV for 1998 27' Safari?
Local AS dealer says my 99 1500 silverado 5.3l gas 3.42rearend with factory tow package and 241,000 miles on it will pull my "new" AS without a prob. I was about to buy an 07 2500 duramax with 125k mles on it, but now wonder if I should switch to the 3/4ton diesel.
Please help me with this decision
Jerryb1973 is offline   Reply With Quote
Old 02-03-2011, 09:21 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I towed my 31' Excella with my 2000 Silverado 5.3L w/tow package on several 700 mile each way trips from NC to Florida without any problems. However, when I tried the Blue Ridge Parkway the brakes got hot going downhill. The engine was barely sufficent and the transmision overheated going up. And I was geared lower at 3.73. If you stay in the flat lands you should be ok with the 1500. I suggest not going to the high hills if you use the 5.3L gas 1500 Silverado. If I remember the max tow capacity was just over 7,000 lbs.
I have used a 2500 Duramax. It will definitely do the pulling job, but you should look at some of the threads in this forum about tow vehicles that are too heavily sprung and cause damage to the structural elements of trailers.
I now tow with a 2010 Silverado 5.3L gas 3.42 rear end with a six speed trans. It will take my 25' Safari over the Appalachians with ease.
Hope this helps!
Old 02-04-2011, 06:05 AM   #3
1998 25' Safari
Buda , Texas
So, the only difference between your 10 and my 99 is the 6 speed transmission. Your saying that difference makes taking steep grades easy?
Old 02-04-2011, 08:34 AM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
My 2000 was a 4 speed.
My 2010 has the 6 speed. Yes, it makes all the difference. Did you see the current thread about 6 speeds?
Video - Successful Axle Job on 1964 Safari JitneyBead Axles 10 05-21-2012 09:07 AM
1962 Safari numbers jaclaw Airstream History 5 01-18-2011 07:48 PM
2004 Safari leaking around bathroom vent fan DJW Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 01-03-2011 04:12 PM
