09-04-2011, 05:47 PM
2006 30' Classic
Yonkers
, New York
TV F450 & 30 Ft 2006 classic. Overkill ?
To the TV gurus on this forum:
I tow with my F450 Harley Davidson ( a.k.a the beast) and have been reading about overkill, AS frame separation & TV / TT wt ratio for the past 18 months.
Need all of your opinion/s on below options: a) Soften the F450 ride with kelderman air ride or Sulastic rubber spring. b) Replace the TV with GMC 2500 Dmax, 3500 Dmax SRW or 3500 GMC daully.
c) I love F350 but dealer think that I will experience same rear end bounce as in F450. d) reduce the F450 leaf spring to F350 spring configuration. MPG is also a consideration.
I use Hensley on the 30 ft classic and have 100gal aux tank & Honda generator, total of 11,000 LB plus about 500LB wt of people & camping gear = approximately 11,5000 LB.. Last inspection today revealed zero crack or bend on the frame and rivets are in place . Prevention is better than cure so ladies and guys of the AS Forum and Truck enthusiast , let it rain and thank you for your anticipated great expertise. ( F450 is 18 months, 15,000 miles , also $15,000 to replace/ trade)
09-04-2011, 05:58 PM
2011 27 FB International
Leesburg
, Virginia
Does it bounce that bad? My 250 with x springs doesnt unless the road is real apbad and im going real fast.
Keep in mid a "loaded" 3/4 ton probably wont have much over 2000lbs carrying capacity. You have 750lb hitch and 1500Lb of stuff in TV. You would be cutting it close on a 3/4 ton.
Or take the advice of getting a 1/2 ton (or smaller) loaded 2250lbs on its 1500lb capacity is somehow better/safer?
2011 int 27fb serenity
2011 f250 CC 6.2L
09-04-2011, 07:49 PM
2006 30' Classic
Yonkers
, New York
Bounces when empty off pavement-which is expected but I'm not worried about when empty. It's the vibration it transfer to the AS that I'm worried about . Thanks for your feedback.
09-04-2011, 07:55 PM
Oswego
Short answer....YES....3/4 ton is perfect for the Classic 30'. Sorry, but I've worked the other way. Several 1/2 ton platforms upward. Not necessary in any way, shape or form to go heavier.
Edit: Unless it's a 30' slide....then MAYBE a 350/3500, depending on bed load....never a 450/4500.
09-04-2011, 08:01 PM
1967 24' Tradewind
1975 31' Sovereign
Estancia
, New Mexico
Check out an Air Ride for Air Safe hitch for stiff suspension TV
09-04-2011, 08:02 PM
2010 31' Classic
Common Sense
If it were mine, and I liked the truck and I did not really need the weight capacity of the F450 for other things, I'd go to a junk yard and get some F250 rear springs, and change them.
But, I do stuff like that.
"The further a society drifts from the truth, the more it will hate those that speak it." George Orwell
In the past: '73 20' Argosy, '74 24' Argosy, '75 23' Avion, '63 24' Airstream, '78 24' Argosy, '75 23' Airstream, '01 25' Airstream, '04 28' Airstream
09-04-2011, 08:12 PM
Oswego
Uh, if you ABSOLUTELY cannot trade, I'd go Air safe hitch before I'd mess with the rear suspension. Way more technical/safety issues with that route.
09-05-2011, 05:45 PM
2006 30' Classic
Yonkers
, New York
Thank you for the responses.
09-06-2011, 08:10 AM
Vintage Kin
Corpus Christi
The Kelderman Air Ride is the way to go, IMO. Your truck, your trailer, your gear and your passengers will all benefit. An F450 is a "big" truck for any travel trailer of this type so I assume it has duties beyond just towing a TT. Plus, the KAR is a big re-sale plus: very well-known and well-engineered.
I'd also consider the R4Tech system (and use the 9000's on the front as well).
I'd go with Centramatics (or BalanceMaster [driveshaft also]) all around on TT/TV wheels, too.
Cutting NVH to a minimum seems of obvious benefit.
Hensley Arrow. 15-cpm solo, 25-cpm towing
09-06-2011, 08:25 AM
The AirSafe hitch is exactly what you need.
It will very effectively isolate your towing Beast from the towed Beauty via the Firestone air bags located on the ingeniously designed hitch.
If you look on the AirSafe site, it will describe all the benefits. These attributes are exactly what you and your Airstream need. I say this after five years of using my AirSafe from coast-to-coast.
12-25-2011, 04:33 PM
warwick
, Rhode Island
hi i just got a 2011gmc 1500 xcab with a 5.3l v8 and 3.42 gears 6speed tran
will i be able to pull a 2005 30 ft classic with it thanks for any help
12-26-2011, 07:43 PM
Oswego
It'll pull it, albeit slowly. You will be over GCWR and probably RGAWR if you put much of anything in the truck. Won't be satisfactory in the mountains and just OK on the flats. Been there, done that with an Avalanche which had same powertrain as your truck.
-Rich-
12-26-2011, 11:44 PM
2011 23' FB Flying Cloud
Perry
For those using the "Airsafe" system: Do you also have a weight distribution and or sway control?
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
12-27-2011, 05:37 AM
2008 27' Classic FB
Burkburnett
The Air Safe cushions the vertical movement at the coupler. The need for weight distribution and sway control is unchanged based on the TV/TT combination. If anything, the Air Safe moves the ball further away from the rear axle of the TV theoretically increasing the need for sway control.
I use the same WD hitch and sway control as before. The primary difference I've experienced is a noticeable reduction in the harshness of freeway hop on concrete highways when towing.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
| Thread Tools |
| Display Modes |
