Originally Posted by SKEETER
...I have been searching for exactly the kind of information you posted...
u r welcome skeeter, and the info posted by everyone else in that thread has helped me too...
the review by others and council from all the wise folks here can be very reassuring OR
distressing enough to prompt changes, which is a good thing
IF you wanna post your data
there or ask questions
there go for it...
since more people are subscribed to that thread, it's likely more will see your data and questions there.
but someone will see it where ever u put the info...
I presume that I should do my weighing with myself and wife in the cab?
YES it helps to have the occupants IN the tv during weights....
because 200-400 lbs between the tv axles matters...
i just did a fresh batch of weights 4 days ago, with several reweighs,
and the scale operator recorded some with me in and some with me out...
the 240 lbs of variance drives me wacky and but the scale operator was careless and they are IN CHARGE...
along with people/dogs on board, i've been told to do the measurement with the engine running, so i do....
and some scales require u to drive on/drive off to reset the platform,
the last one i used did not, which made reweighs much quicker and easier...
so ask about this up front along with the reweigh fees (usually a buck, but) the last stop was 3$ per...
cheers
2air'
