Old 10-15-2016, 07:47 PM   #15
2016 30' International
Florence , Alabama
Ram 2500 6.7 you can't go wrong.
joshjack is offline   Reply With Quote
Old 10-15-2016, 08:09 PM   #16
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We are on another cross-country trip with our FC25 and Ram EcoDiesel right now, hard to imagine a nicer overall towing combination, rock solid on the road in all weather, road and traffic conditions and remarkable economy, a nice handling and comfortable daily driver as well. This is our second Ram 1500, last one a Hemi. That was a good truck as well for this purpose.
Doug and Cheryl
Old 10-25-2016, 01:33 PM   #17
2016 27' Flying Cloud
Quebec , Quebec
Images: 8
Originally Posted by Milo1952 View Post
I will be purchasing a late model FC 25'. Considering purchasing ram 1500
eco-diesel short bed as TV. Also considering Jeep Grand Cherokee
diesel. Can-Am does not like the jeep.
I am open to all suggestions. Would like to stick with diesel. this will be
my first TT. Newbie
RAM is a better choice because you will get a better payload. Towing a AS25 or any larger AS will drive you at the limit of the payload capacity of a Jeep if you load it with more than two people.
Toutsi 1957 is offline   Reply With Quote
Old 10-26-2016, 10:33 AM   #18
VernDiesel's Avatar
Dayton , OH, 2017 33' Classic 8,561 dry
Milo you will be gold with that setup but set up right the diesel jeep should be also as others have done this with good results. I would want the LS differential with a 2WD. fwiw many grades out west require tire chains on 2WD when the flashers are on due to road conditions at the higher altitudes.
My 3.92 gear Big Horn QC 6.4 bed 4WD is rated to tow 8,800. Its GVWR is 6,950 as delivered weighed 5,501 so say 1,450 payload. But I've been on state scales near the 7,800 combined axle weight and the truck would climb decend handle & stop well. In fact safely useing tune with brake, no sway WDH, & axle to frame airbags well & better tires. For safety I do watch to not exceed individual axle & CVWR.
It sure is an efficient engine. Three years running now a Wards top ten engine award winner. Have over 233k on mine now well over half of which with a trailer in tow. Repairs a light switch at $104 & a lift pump at $158. Happy streamin
Transportr AS & TT Mfg 2 dealr RAM EcoD factory brake controller tow mirror hitch camera & receiver 1,290/12k, No sway WDH, Rapid adj hitch, axle 2 frame air bags, tune w turbo brake, SLT Grill, 31.9" load tires, Max ED tow 9,200, GCAR 7,800, Max Ram 1500 GCVW 15,950, Axles steer 3,260 drive 2,540
VernDiesel is offline   Reply With Quote
Advice needed, and perhaps a tip or two. Curtis-79MH Airstream Motorhome Forums 12 06-26-2007 01:43 PM
Advice for long term trailering Cheryl Full-Timing 49 07-29-2004 01:58 PM
Ladder Advice ViewRVs General Repair Forum 11 10-10-2002 10:51 PM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 07:01 AM
Advice please - Travels, Flags, Fuel and Caravans NickSowter On The Road... 6 06-27-2002 10:04 AM
