Old 09-22-2017, 08:07 PM   #1
nickclifford's Avatar
1972 31' Sovereign
felton , California
Tundra / truck gear box gearing question ...
hey folks,
got a strange question here ... I need to back up my trailer onto a new parking pad I've cut out on my lot, it's about a 20-degree slope maybe .. kinda tricky given how low these trailers are but here's my question ... are truck or specifically Tundra gearboxes beefy enough & geared to push backwards 5,000 lbs and with a significant strain, being that it's being pushed uphill?
the reason I'm asking is that previously I owned a Lexus RX330 and would reverse my popup onto my driveway, about a 25degree slope and clearly the gearbox didn't like it ..!
Alternatively, guess i could invest in a front hitch and try pushing it up ..
I can get a local tow company to do but would cost $200!!
thx
nickclifford is offline   Reply With Quote
Old 09-22-2017, 08:10 PM   #2
1972 31' Sovereign
felton , California
Old 09-22-2017, 08:12 PM   #3
1972 31' Sovereign
felton , California
And btw. Can't regularly tow up and then back into parking place due to space constants. I have to back right in.
Old 09-22-2017, 08:13 PM   #4
1972 31' Sovereign
felton , California
Here's a better picture showing what I'm working with. Click image for larger version
Old 09-22-2017, 08:13 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
Should be no problem.
CRH is offline   Reply With Quote
Old 09-22-2017, 09:01 PM   #6
65CV's Avatar
Western , Massachusetts
Had to back uphill out of a one lane road in Vermont after discovering that the bridge washed out. Not sure of the slope, but it was steep enough that I had to go into 4 wheel drive to back up the steepest part. Tundra was just fine. (5.7L with tow package)
65CV is offline   Reply With Quote
Old 09-23-2017, 08:20 AM   #7
Byron Center , Michigan
If you have 4wd putting it in low will make the incline a breeze and reduce the lugging on transmission.
YippieKiYa is offline   Reply With Quote
Old 09-23-2017, 09:24 AM   #8
Mollysdad's Avatar
I can't imagine it being a problem.
The Tundra is not being asked to lift 5000 pounds, just roll it.
Old 09-23-2017, 09:30 AM   #9
Totally agree.
Old 09-23-2017, 10:34 AM   #10
wavelength's Avatar
1999 25' Excella
Western Springs , Illinois
The Tundra will handle in fine. I have a 2007 4x4 and I have backed loads heavier than that up hills. I would be concerned with bottoming out the trailer on the steep incline
wavelength is offline   Reply With Quote
Old 09-23-2017, 11:37 AM   #11
coveredwagon's Avatar
LOS ANGELES , California
I live on a tiny, winding hillside street in Los Angeles. I regularly back my 25' Airstream into my driveway. It's not easy, because of the curves but my 2008 Sequoia handles it just fine. The transmission is heavy duty.
coveredwagon is offline   Reply With Quote
Old 09-23-2017, 04:34 PM   #12
2007 27' International CCD FB
San Diego , California
No problemo. It will put some load and heat into the torque converter for sure. But that's what it's designed for. And is no worse for wear than taking off from a light at full skunk.
It won't change your situation, but having low range is a huge benefit for situations like this. Much more fine speed control without lurching. I use it often to get situated and park in various spots.
2007 27FB Ocean Breeze "See Turtle"
2009 Lexus LX570
pteck is offline   Reply With Quote
Old 09-23-2017, 11:52 PM   #13
Ronman's Avatar
2007 27' Safari FB SE
Rancho Murieta , California
4:10 gears and in reverse should be a piece of cake!
Ronman is offline   Reply With Quote
Old 09-24-2017, 12:51 AM   #14
1972 31' Sovereign
felton , California
Great advice here, thanks .. my Lexus probably just had a regular sedan gearbox and really couldn't handle the weight of backing my pop-up camper up a steep driveway. It would smell of burning rubber or whatever ! So my bigger issue is just making sure I don't bottom out, will have to use wood under the trailer wheels probably.
Gearing up for a cross country trip Golden Girl Member Introductions 11 06-22-2015 04:48 AM
I have 3 boxes of assorted parts from my airstream 59 Tradewind, I would like to sell by the box for 300.00 per box or best offer per box betsy Airstream Classifieds 0 09-19-2014 12:01 PM
310 engine change diesel to gas, gearing question tevake Mechanics Corner - Engines, Transmission & More... 4 10-11-2013 06:16 PM
Newbie gearing up for spring AppleStreamr Member Introductions 20 03-10-2010 06:14 AM
