Old 03-07-2013, 05:57 PM   #1
Lexington , Kentucky
Tundra Towing 30' Classic?
We are considering trading our Flying Cloud 25FB for a new 30' Classic. The trailer weight will be going from around 6,000 pounds loaded to around 8,000 pounds loaded. We pulled our FC25 with ease with our Tundra 5.7l Double Cab. Will this truck safely handle the 30' Classic? We can't afford to trade-up to the Classic if we have to get a bigger tow vehicle.
wlanford is offline   Reply With Quote
Old 03-07-2013, 07:29 PM   #2
5T5
2004 28' Classic
2006 22' International CCD
Saskatoon , Saskatchewan
We pull our 28' Classic with a 2008 Tundra Double Cab and have had no problems with this combination.A fellow Airstreamer pulls a 34' and says he has no problems either.
Kim
5T5 is offline   Reply With Quote
Old 03-07-2013, 07:34 PM   #3
1986 31' Sovereign
Miami , Florida
I have pulled my 31' almost 50000 miles with a Nissan Titan which has similar power with no problems and your Tundra has heavier duty brakes. Think it will be no problem.
Mike
Old 03-07-2013, 07:39 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have a 25FB that tips the scales at 7400#. If yours really weighs in at 6000# fully loaded, I would love to know your secret. Do you have any furniture in it?
Brian
SuEllyn & Brian McCabe
Old 04-02-2013, 06:35 PM   #5
Irwin , Pennsylvania
30' Flying Cloud with Toyota Tundra
We have a 2010 30' Flying Cloud that tows fine with a 2011 Toyota Tundra Double Cab SR5 (5.7l, 4WD, tow package, AT). We just came back from two months in Florida (1100 mile tow each way) and everything worked fine. The trailer was pretty well loaded for the trip down (about 7500 lb) and the truck was at GVWR (7100 lb). The GCWR for our Toyota is 16,000 lb. A few things make life better. 1) put Firestone Ride Rite air springs on the rear to take the extra tongue weight (the rear springs on the Tundra are soft and no amount of weight distributing hitch adjustment can get the rear ride ht. correct w/out the air springs), 2) put adjustable rear shocks (like Rancho's) so you can control the bouncing with the heavier total rear spring rate, 3) put the pull-out tow mirrors on (with the convex bottom) because the AS is really wide!, 4) pick your towing speed (with cruise control) so the transmission doesn't hunt; it depends on how hilly and how much head wind. We usually tow on interstates between 60 and 67 mph. We get 10 to 11 mpg consistently. If you try to run at 70-75 mph you will need to tow a fuel tanker also.
I'm going to look into an aux. gas tank so I don't need to tank up so often (every 180 to 200 miles leaving some gas in the tank for an emergency).
Watch out that a 30' Classic can be a lot heavier than a 30' Flying Cloud (10,000 lb vs 8800 lb fully loaded).
Good luck.
evanscn is offline   Reply With Quote
