Old 05-19-2015, 01:28 PM   #1
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Tundra 5.7L Maintenance
My 2010 Tundra 5.7L 2wd is at about 56k miles. I'm leaving for a trip out to Utah in June so I'm thinking about getting it serviced before the trip.
I'm going to have the oil changed, AT transmission fluid changed as per the Toyota maintenance guide Special Operating Condition plus have them inspection the brakes, belts etc.
I'll check the air filter and cabin air filter myself.
Anything else I should have them check? There is something in the maintenance guide about re-torqueing the propeller shaft bolt.
Thanks.
Kelvin
Old 05-19-2015, 06:41 PM   #2
2005 19' Safari
GLENDALE , AZ
Re: Toyota Tundra periodic maintenance
At 60-65,000 miles, we had these additional services performed on our 2008 Tundra (Crewmax, 5.7L, 2WD):
  • Replaced serpentine belt = $120 parts + $80 labor. Note: Recommended for desert southwest heat and dusty conditions.
  • Flushed power steering fluid & rack (fluid dirty and contaminated) = $124.95.
The following dealer-recommended service was DECLINED:
  • Decarbonize intake manifold, valves, injectors, etc. with "carb cleaner-type additive" = $237.88.
Note: I think retorquing driveshaft bolts is included in BLUE SERVICE, if you have this done. However, this is from memory; and I'm not absolutely sure.
Old 05-20-2015, 08:04 AM   #3
KJRitchie's Avatar
2008 25' Classic
I'm the 2nd owner and its a Toyota certified preowned purchase. Should I get the brake system flushed and refilled? The owners maintenance manual doesn't show this on the list.
Kelvin
Old 05-20-2015, 09:05 AM   #4
aquinob's Avatar
Portsmouth , Virginia
Flushing the brakes isn't a bad idea. On Mercedes is a requirement every two years, Toyota, not so much. Brake fluid is hydroscopic, meaning picks up water and over time that can contribute to corrosion in internal connections and parts.
I would also look at getting the cooling system checked and flushed if it hasn't been done yet. And a looksee at the belts and check for any leaks and it should be good to go.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 05-20-2015, 01:20 PM   #5
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Don't shoot me for not having a Toyota, but check the service interval of the rear diff fluid. I would change it if it's coming up.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 05-28-2015, 09:42 AM   #6
KJRitchie's Avatar
2008 25' Classic
Got the Tundra serviced at the local Toyota dealer. Oil changed, auto transmission flushed, rear differential oil, brake system flush. Everything seems to be in order for my trip to Utah next week.
Air filter is clean and I replaced the cabin air filter myself.
Kelvin
Tundra 22' INTL CCD temcotom On The Road... 2 03-09-2004 10:41 PM
Tundra Double Cab donreitz Tow Vehicles 15 03-05-2004 01:31 PM
Toyota, 4x4, V-8, Auto, Tundra pick-up Fogducker Tow Vehicles 13 01-28-2004 07:48 PM
Airstream for Tundra? RAC Tow Vehicles 8 10-27-2003 11:31 PM
Towing with a Tundra JimC Tow Vehicles 37 08-03-2003 09:00 PM
