Old 11-15-2013, 02:23 PM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
TT Weight Specs
Where can I find the weight specs for the various AS TTs? Not just the new units (presumably available on the Airstream site) but, for example, the difference between a 2006 Classic and a 2010 Safari?
I have a spreadsheet that I put TV (GVWR, Max Tow, FAWR, RAWR) and TT characteristics (Dry/Shipping weight, Cargo Capacity, GVWR, tongue weight, tongue distribution) into and it checks trailers for compliance and margins on axle and gross limits for the TV.
But I need specs on older TTs to use it.
Al
Old 11-15-2013, 02:26 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
You can find Airstream's floorplans and specs including optimistic estimates of trailer and tongue weight on their site but the information is more complete in some years than others.
— David
Old 11-15-2013, 02:30 PM   #3
Wayward's Avatar
Cary , North Carolina
Here they are up through 2003.
Now where could I find a spreadsheet that I could put in TV (GVWR, Max Tow, FAWR, RAWR) and TT characteristics (Dry/Shipping weight, Cargo Capacity, GVWR, tongue weight, tongue distribution) into and it checks trailers for compliance and margins on axle and gross limits for the TV? That would be cool.
AS Trailer Weights.pdf
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 11-15-2013, 08:50 PM   #4
Denis4x4's Avatar
Durango , Colorado
Published weights and real world weights are considerably different. I suspect that you're setting up a spread sheet to find the optimum trailer/TV combination. For instance, will the weight for a particular TT reflect a full tank of water or not. And so on.
Denis4x4 is offline   Reply With Quote
Old 11-15-2013, 09:36 PM   #5
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Here's a pdf file I found on the AS site:
http://www.airstream.com/files/libra...c5c1005fbf.pdf
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 11-17-2013, 11:01 AM   #6
My TV/TT Rating Workbook
Thanks to everyone for the data. In response to a request, here is a copy of the workbook I generated. As stated in the Notes tab, it is a work in progress. I have not found an error in a while but that does not mean there aren't any. Use this at your own risk!
I think the notes page explains how to use it adequately. I left the data for my truck in the TV tab. You can enter yours as appropriate.
If you find an error or think of a useful enhancement, let me know.
Al
Old 12-13-2013, 09:15 AM   #7
Error found and corrected
I found an error in the alternate cargo calculation area. It was working until I improved it :-)
Sorry for any inconvenience, but as I said in the notes, there may be more.....
Here is the updated workbook.
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 12-13-2013, 10:00 AM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
When you visit the Airstream website and click "compare" it will show all the models, weights, and tongue weights.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
