Old 02-25-2011, 07:58 PM   #1
wendywoods's Avatar
2010 28' International
Somewhere , Mostly California
Truck tire recommendations?
We have a Dodge RAM 2500 truck in need of a new set of tires to pull our 28-foot Airstream - would like to know the best tires for the job. Appreciate recommendations. Thanks! Wendy
wendywoods is offline   Reply With Quote
Old 02-25-2011, 10:55 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
Personally, I've been very pleased with Michelin LTX AT radials; I get about 50K miles on a set w/ our 7000 lb 4x4 truck. The right tire for your application depends a LOT on the kinds of use to which you put the truck - heavy hauling, high speed highway use, lots of off road, etc.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 02-26-2011, 05:52 AM   #3
Danbury , Connecticut
Check what Consumer Reports says.
charliejw is offline   Reply With Quote
Old 02-26-2011, 05:59 AM   #4
mbmbstreamer's Avatar
2006 25' Safari SS SE
1969 27' Overlander
Martinez , Georgia
I love my LTXs. Finishing my second set on a RAM 2500 with 117000 miles (almost all towing). Had a pair on a Grand Cherokee and got 105,000 on them.
I think they are being updated by Michelin (MS2) but I will buy another set!
Matt
WBCCI # 3518
TAC# GA-6
mbmbstreamer is offline   Reply With Quote
Old 02-26-2011, 08:00 AM   #5
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
While just about every manufacturer has a solid selection of hearty load-range appropriate tires for a 2500 series truck, the most important part is what you do with your truck. If all you do is dry weather towing on highways, a non-aggressive tread design will run the most quiet, steer the smoothest and give the best fuel economy and tread life. If it's a 4X4 truck and most of your driving is on snow covered or muddy roads, then a good aggressive tread would be the smartest choice. In between? There are mid-range tread designs for some occasional poor road conditions.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 02-26-2011, 08:35 AM   #6
1963 19' Globetrotter
Moline , Illinois
My 2004 2500 Ram came with Michelin LTX/ATs , ran the first set 92,000 and could easily have run another 10,000 but replaced due to age. My second set has 38,000 on them and they are barely wearing. Good all around use tire. I spend a lot of time in 4 wheel on the farm and they even work well there.
63air is offline   Reply With Quote
Old 02-26-2011, 10:35 AM   #7
wendywoods's Avatar
Michelin LTX/ATs seem to be the way to go. We expect once we go full-time to get as far away from snow and ice as we possibly can! There won't be a lot of high-speed driving and probably minimal off-road adventures. Thanks for the recommendation!
Old 02-26-2011, 10:55 AM   #8
Incorrigible
Ike T's Avatar
1976 Argosy 24
-- , Georgia
Another vote for Michelin LTX/ATs if you are staying on the pavement. We're pleased with this tire model.
Tim
1976 24' Argosy
1973 International Harvester Travelette 1210 4x4 'Bernard' 164" WB
1997 Georgie Boy 30' SuperDuty v10
Ike T is offline   Reply With Quote
Old 02-26-2011, 11:33 AM   #9
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
I switched from Bf Goodrich to Michelins this year on my F250 work truck and my Excursion this year. The Michelins are 100 times the tire. I wish I made the switch years ago.
2005 Ford Excursion V-10
Reese Trunnion Bar with dual cam sway control
Prodigy P3 brake control
seldencove is offline   Reply With Quote
Old 02-26-2011, 11:41 AM   #10
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
We replaced the OEM (junk) Load Range C Goodrich tires on our Tundra with Michelin LTX/AT2 Load Range E 40,000 miles ago. They wear well, have great traction in snow, ride well. Michelin has different versions of their LTX tires. I thought these were the best deal because we do a lot of driving and they would last a long time since the LR E has deeper tread. The AT means "all terrain". The LTX M+S is a mud and snow tire, but the AT2 is also but has a more aggressive tread. If you don't drive a lot, the non-AT2 LTX may be a better deal because I don't think they will last quite as long.
You can check Michelin's website for specs and how long they expect a specific tire to last. My experience is they last longer and have good traction even when the tread is getting down to replacement time.
I've looked at Consumer Reports tire ratings and have never heard of some of the tires they rate highly. They seem oriented towards car tires anyway. Tire Rack has customer ratings on its website and Michelin rates very high.
Many Forum members seem to be Michelin fans. When we replace the Marathons that are standard on recent trailer models, many of us go to Michelins even though we have to buy 16" tires and new wheels. We are also pleased with the Michelin LTX's on our Safari.
Gene
Old 02-26-2011, 03:15 PM   #11
Halimer
2006 25' Classic
New Hyde Park , New York
My vote is for the Michelin LTX MS/2. I have the MSs on my F350 2wd it is used for towing. I have used them in the snow with a Shurtrax bladder(ShurTrax Traction Control System for Full Size Pickup) in the bed. With all the snow that we have had in NY I have not had a problem or have been stuck. I have 38,000 miles on the tires(12K going to Alaska in 2010) and still have plenty of tread. Next set will be the MS/2's.
Mark
halimer is offline   Reply With Quote
Old 02-27-2011, 08:16 AM   #12
JFScheck's Avatar
Rockville , Maryland
Images: 33
Michelin's on all my cars have been my tire of choice - the MS/2 LT has gotten good reviews!
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 02-27-2011, 10:05 AM   #13
SteveH's Avatar
Common Sense , Texas
I've had real good service from my Michelin LTX M/S, and no problems. They are a little pricey, but so far worth the money.
Regards,
Steve
Old 02-27-2011, 10:13 AM   #14
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Another vote for Michelins.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 10:02 AM
How do you cover the back of your truck? aname4me Tow Vehicles 34 03-01-2011 12:36 AM
Truck Shells and MPG Secguru Tow Vehicles 25 02-20-2011 04:57 AM
Correct Tire Pressure on Tow Vehicle Jim Pona Tow Vehicles 4 02-01-2011 10:37 AM
TowMaster range E trailer tire tvanwave Tires 8 01-14-2011 04:50 PM
