Old 01-12-2015, 09:56 PM   #15
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Even including the cost of a flare tool and a tubing bender, running steel tube is almost always cheaper than running good hoses, and is always better than the crap hose that typically comes with cooler and remote filter kits.
Plus it can look really nice if done well.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 01-12-2015, 10:17 PM   #16
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Transmission Cooler
Bending metal has a learning curve. So time is also cost. I agree with you, otherwise. Ditch the cheap hose and head to NAPA for high pressure reinforced hydraulic hose. Avoid tight bends. That's about it. Lasts easily as long as metal but without fatigue or rust.
Old 01-13-2015, 05:47 AM   #17
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by PaulnGina View Post
Thanks, Bob. I'll track it down.
Where are you in the Buffalo area? I have an aunt that just moved from her home of a million years in Cheektowaga to Alden to live with my cousin. Dad's side of the family is from the Sherman area SW of Buffalo.
Hoover Beach 15mi South of Buffalo on Lake Erie.
Originally Posted by Jammer View Post
Worm-drive clamps should never be used on transmission lines because they don't provide enough clamping force, leading to leaks. Machine screw clamps are available and are the more suitable clamp to use.
Originally Posted by slowmover View Post
I go to NAPA for the high dollar reinforced hose and build them into harnesses following factory routing. Install and remove as a set, no snaking of lines. Use cushioned Adel clamps less than every foot. And I used Magnefine filters for both fluids.
However done it isn't cheap but worth the trouble.
Thank's......boy am I dumb.
Glad it only lasted 11 years.
Old 01-13-2015, 06:41 AM   #18
1953 21' Flying Cloud
Atlanta , Georgia
Wow. Thanks you guys. You've confirmed a lot of what I was researching and even helped me with some things I had not even thought about. Stronger hoses and deeper transmission pan seem like a great ideas. We may not always be driving through the Rockies, but I want to make sure we get up and over!
I already need to replace my radiator so I'm gonna be getting the biggest I can fit (G20 is pretty tight under the hood) and then I was thinking of adding on the cooler. Crazy?
handrew is offline   Reply With Quote
Old 01-13-2015, 08:03 AM   #19
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Radiator should have integrated trans cooler tank. Added cooler is downstream. I used strap or brackets to affix cooler to sheet metal, not radiator. In front of fan. PS cooler on low pressure return line and off to if radiator face. So cover for solo winter driving. Filters affixed to fender liner.
Another HD fluid upgrade is to use coolant to warm and cool engine oil by use of a fluid/fluid heat exchanger at oil filter mount. As with ATF tank in radiator, engine oil is warned faster than normal operation, and heat spikes are controlled under high loads. Corvette and other examples from 80s and 90s.
Fit issues include sometimes a shorter oil filter not to mention protection of coolant lines.
Old 01-13-2015, 08:11 AM   #20
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Transmission Cooler
Robert, I wasn't saying anyone is dumb, I was just offering a bit of advise based on my own (bad) experience.
When I was younger I have installed some like products "out of the box" with less than stellar results.
It sucks to spend a day installing a kit that ends up being unreliable and messy.
I am glad yours worked out well, that just hadn't been my experience.
Old 01-13-2015, 08:34 AM   #21
I didn't say you said I was dumb, I said 'boy am I dumb', based on my experience.
Old 01-13-2015, 08:34 AM   #22
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Transmission Cooler
And he doesn't live in the heat. Gaskets, weatherstripping and underhood rubber lives forever up there in WNY. Probably has the OEM A/C system on his Suburban.
Old 01-13-2015, 08:41 AM   #23
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Transmission Cooler
Thats cool Robert, I just didn't want any hard feelings, that certainly was not my goal at all.
I guess my point was that the makers of these kits often put crap hoses in their product.
When I was in my twenties I had a truck that I installed an external filter and oil filter on. It blew a hose and sprayed oil on the hot exhaust before the kit was a year old. Somehow, fortunately, the billowing cloud of smoke didn't catch fire.
This was one of those learned experiences that seemed important enough to pass on.
Too often a person feels obliged to use the stuff that is thought to be "engineered" to work with their product. Not always a great idea.
Old 01-13-2015, 09:02 AM   #24
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Here's a picture of my external spin-on filter. I got the kit from Summit Racing. This is on my 2008 F-250, but I also added one to my wife's Lincoln LT truck, similar to an F-150, only had to attach it below near the bumper.
Name:	2008 F-250 External Tranny Filter 001 (Small).jpg
ID:	230352   Click image for larger version
Name:	2008 F-250 External Tranny Filter 002 (Small).jpg
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Opinion please, on transmission cooler.. kidsgone Tow Vehicles 7 01-30-2010 10:50 PM
Transmission cooler 2008 Suburban. adonh Tow Vehicles 39 09-02-2008 10:25 PM
aux transmission cooler? nickglase Mechanics Corner - Engines, Transmission & More... 10 04-08-2007 10:37 AM
Transmission cooler thenewkid64 Mechanics Corner - Engines, Transmission & More... 13 11-10-2003 09:37 AM
