Old 04-18-2009, 04:44 PM   #1
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Tranny guru's out there? OD slipping?
Well, my trusty '94 Dodge B350 (1 ton van) has starting making a "rubbing" type sound (sounds almost like a heavy belt slipping ..... low frequency noise + vibration) anytime the van's in OD, and torque is asked of it (going up a hill, accelerating firmly) from 45+ mph.....
At first I thought I had a loose tranny mount (it feels like the vibration is coming from right between the front seats), but I am noticing that it doesn't happen when the van's in 3rd, out of OD. I also wondered about my u-joints.. but both the tranny mount and u-joint would show itself in all gears, right? I don't get any drivetrain "thunks" from start, or on/off the throttle...
So is my OD slipping? Is this an "easy" (read 'cheap') fix? Is it the torque converter and not the tranny? And lastly, I need to leave in a month or so for our first rally, if I tow out of OD (like I always do), will the tranny survive the trip? Is it just an OD thing?
Anybody got a ballpark repair cost?
Thanks!
Marc
Old 04-18-2009, 06:22 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If your truck has a tack drive at a steady speed, 50 or so, up a straight hill. While watching the tack give it a little throttle, not enough to kick it down a gear. If the tack moves at all ahead of your road speed the converter is slipping.
How many miles on the trans? This should not happen with less than 100,000.
If the converter is slipping you should be able to install another one without a complete trans job. I would drop the trans pan and make sure there is no junk in there. Also if you can get someone to put a pressure gage on the trans to make sure the pump is putting out enough pressure to hold the converter lock on.
2004 Excursion 4x4
Old 04-18-2009, 08:32 PM   #3
Cincinnati , Ohio
Thanks!
Marc
Marc,
The OD gear itself won't slip (unless it's broken). Most likely the problem is the torque converter. However, it could also be the clutch pack, plugged valve body, or a bad bearing. Your best bet would be to take it to a good and trusted tranny shop. Don't take it to Aamco.
If this tranny has more than 80,000 miles on it, then I would suspect you are going to need a rebuilt trans.
If you have a large gas engine or the diesel in front of this tranny, then I would suggest a heavy duty valve body, torque converter and clutch pack.
Price is going to be determined by how much work you do. Are you going to pull it out yourself? Are you going to have the shop do all the work?
If you pull the tranny and take it in, you could get a rebuilt unit for $800 to $1200. Double that if you have the shop pull it out and put it back. If you want some heavy duty parts, then the price goes up more and quickly.
Good luck,
Woody
Woody.303 is offline   Reply With Quote
Old 04-18-2009, 09:57 PM   #4
Retired.
. , At Large
Marc, I'm sure you know you have a 518 transmission in your van, which is a 727 with an overdrive unit hanging on the back of it. The torque converter SHOULD lock in 3rd gear, with the overdrive off. If it does, try what Howie suggested to confirm it's in the torque converter. You should feel a kind of high-pitched shudder if the torque converter is slipping. If it only does this when the transmission is in overdrive, it is possible it has a bad bearing in the overdrive unit. This happened to our Dakota (also 518 transmission), as well as a fellow Club member with a newer Ram 2500 pickup.
Old 04-19-2009, 12:56 AM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Ford had some chattering torque converters and the fix was fresh trans fluid. Change all of the fluid and replace the trans filter. Give it 500 miles to stop; And if it doesn't stop chattering you will have to replace the torque converter. Trans service is vital. Could be the same with other brands.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 04-19-2009, 10:29 PM   #6
1975 Argosy 26
1963 24' Tradewind
Thanks guys... well... the van's a '94, and it does have 127,000 miles on it... so I can't complain too much... so I think I'll try changing the fluid and giving it a go... but I'm not so sure it will go away.
The van locks up fine in 3rd... it just "vibrates" or chatters in OD. I did notice a bunch of oil (old) that was sprayed up in a line just to the rear of the tranny, by the u-joint. I didn't think too much of it (just thought the rear seal might have leaked a tad on a towing trip)... and haven't noticed any oil on the ground. Maybe that's when the bearing went bad?
Anybody have some trusted tranny shops in the Seattle area they'd like to share with me?
I could pull the transmission... but don't have the time right now... I have been thinking of a new t.v. for some time too.... but the delimma is that my daughter will have a 20 mile drive to high school next year.. so I wanted a commuter car and keep the van (but it does need a new A/C compressor as well)..... need mpg and towing...
So... can I tow about 200 miles in a month with the tranny as is?
Marc
Old 04-19-2009, 11:09 PM   #7
Retired.
. , At Large
Marc
I would not advise it. Your transmission will likely not fail within a mile of your house, but more likely about mile 98 on the way camping. A tow truck for both the van and trailer will be expensive.
The oil you found toward the rear of the transmission could be from the vent at the top of the transmission, it would have blown out the vent if the transmission overheated.
A used transmission might be an option.
Old 04-20-2009, 06:03 AM   #8
richinny's Avatar
2011 34' Classic
with that rear seal leak it might indicate one other possibility. the tailshaft bearing might be going bad. given the history of Chrysler's lock-up converters, the converter is the likely cause.
ask the transmission shop if disabling the lock-up feature is possible to buy you a little time.
Ricky
Old 04-20-2009, 07:17 AM   #9
Retired.
. , At Large
Modern transmissions are designed for maximum cooling with the torque converter locked. It really would overheat in short order unlocked, and towing a trailer.
Old 04-20-2009, 07:29 AM   #10
HowieE's Avatar
Images: 12
Pac Trans in Yakima Wa fixed me up while on the road several years ago. I drove 250 miles to get there on a recommendation of a friend in Mt.
I would do it again. 509) 457-5005
They fixed the problem not created a bigger one.
That was over 100,000 miles ago
2004 Excursion 4x4
Old 04-20-2009, 07:30 AM   #11
"Cloudsplitter"
Marc
A reputable trans shop can "power flush" the system to remove all fluid from the cooler, lines and converter.
Old 04-20-2009, 07:39 AM   #12
1969 31' Sovereign
atlanta , Georgia
guages?
Are you running a tranny guage? That would provide an inexpensive way to collect relevant data.
Atlanta, GA + Steamboat, CO
1969 31' Sovereign
https://www.klendesign.com
nunya001 is offline   Reply With Quote
Old 04-20-2009, 08:36 AM   #13
87MH's Avatar
1978 31' Sovereign
Images: 292
Well, my trusty '94 Dodge B350 (1 ton van) has starting making a "rubbing" type sound ...so is my OD slipping? Is this an "easy" (read 'cheap') fix? Is it the torque converter and not the tranny? And lastly, I need to leave in a month or so for our first rally, if I tow out of OD (like I always do), will the tranny survive the trip? Is it just an OD thing?
I blew the tranny in the B-250 Dodge at about 90,000 miles – I purchased the Dodge with 35,000 miles on it. Almost all of the miles I put on it were towing some sort of trailer – after Katrina hit New Orleans in 2005 I made a round trip from Houston to New Orleans almost every weekend for about a year and a half. I was pulling a dual axle 18’ trailer about 60% of the time, a single axle 12’ trailer about 30% of the time, and no trailer the other 10%.
The Dodge has a 360 engine with a 3.73 rear end. Cost for a "heavy duty" rebuild (there are various grades of replacement parts) was $2500, including the installation of a temp gauge. The failure was quite sudden with no indication of impending problems. I had previously installed a tach just to look for tranny slippage, but there was none in this case - the actual cause for the failure was a seal leakage at the rear, causing all of the fluid to be lost. Again, this happened all of a sudden - no indication of a leak at all in the driveway prior to leaving for the trip.
Failure happened right at 60 miles into the trip - not a particularly hot day. First indication of a problem was smoke billowing out from the rear of the van - the result of the tranny fluid being thrown onto the exhaust system.
I had lost a Mark VIII tranny previously at 60,000 miles (gradual failure), a Lincoln Town car (company car, sudden failure, chewed up the clutches) left me high and dry in Venice, Lousiana at 45,000 miles, and a Taurus tranny (another company car) at 35,000 miles - oh, and the 345 MoHo - twice (http://www.airforums.com/forums/f156...saga-3428.html) - transmission failure can certainly occur at any time.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 04-20-2009, 11:02 AM   #14
1975 Argosy 26
1963 24' Tradewind
Well, I found a shop that I think I like... I'll let everyone know the damage...$$.... hopefully not too much...
Marc
Old 04-22-2009, 05:38 PM   #15
1975 Argosy 26
1963 24' Tradewind
Well, just to post the update. I don't have the van back yet, but the shop found the following, good and bad.
The good - for some reason, the driveshaft seems to have moved out of alignment, causing a vibration. They shimmed it and seemed to fix it.
The bad - the bellhousing, tranny case seal (I believe) is leaking under pressure. He mentioned that it may not be worth the money to pull the tranny to fix it, but, it could "blow out" with a rapid dump of tranny fluid if not fixed. Thinking of Dennis's post above... I didn't want to risk the transmission failing on a trip due to a seal, so, $1200 later (all new seals), it will be fixed.
Today they called to tell me that everything looks ok inside (bands, bearings, etc) - so all in all not too bad. I'll get another year or two out of it, so I can decide what the new (old) t.v. will be.
I'll find out if that vibration / sound really is gone after I pick it up tomorrow. Thanks for all the help!
Marc
Old 04-23-2009, 07:31 PM   #16
1975 Argosy 26
1963 24' Tradewind
Van's back, tranny is freshly serviced, sound is GONE! And, my wallet is 1,100 dollars lighter... but MUCH cheaper than a new transmission.. and should last for a while now too. You know, the shop could've told me that I needed a new one, or a complete rebuild, but they were completely honest, and friendly folks. Nice to see a clean shop as well. Two thumbs up for Kirkland Transmission!
Thanks guys!
Marc
Which Tranny? ArtStream Tow Vehicles 17 11-08-2008 09:29 PM
Slipping Fridge Panel ESCAPE POD Refrigerators 2 12-14-2007 11:18 AM
Tranny Shift smily Mechanics Corner - Engines, Transmission & More... 5 01-27-2004 08:03 AM
Tranny filter Orland Dewey Mechanics Corner - Engines, Transmission & More... 2 11-29-2003 07:58 PM
How to drop the tranny? (If I even need to) Impala SS Guy Mechanics Corner - Engines, Transmission & More... 13 10-06-2003 07:03 AM
