Old 06-11-2004, 09:00 AM   #1
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
Trailer wgt, tow ability for next TV
Below is the weight of a 2005 28' CCD w/max fluids and options. I did not add supplies/groceries, all the personal stuff for living/camping. I'm getting a new tow vehicle and trying to determine which engine to go with. The 2005 Suburban 2500 4WD with quadrasteer has a max trailer wt. of 7,300 lbs. Subtract the weight below and that gives me a margin of 584 lbs for the supplies, etc. before I've hit the max wt listed for that Suburban and the CCD as well. I can get a larger engine (8.1 liter, more gas) and then I have 9,900 lbs towing capacity. I realize I won't be towing with full tanks, but any advice on whether the bigger engine ($1,000 option) is necessary to tow this would be most welcome. Thank you.
Trailer Base Wt 5,461
Convection Microwave 47
Entertainment Package 40
Skylight-galley w/shade 11
Spare Tire w/bracket 64
Stoneguard 3-pc 41
Vent w/thermostat bdrm 11
Window awnings 100
Wrap protectors 28
Propane tanks full 60
Water tank full 273
Black/Gray tanks full 560
Guinness 20
Cargo- all other ?
TOTAL 6,716
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 06-11-2004, 09:21 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I do not have a TV anymore, I am in a MH, but you asked.............
FWIW I have never heard anyone complain about having too much horsepower when towing.
The additional 1K will likely pay off in lower long term maintenance costs (engine will not have to work as hard) and also be a more relaxing vehicle to tow with.
If you are planning on crossing the rockies you will lose a fair amount of HP as you climb so having extra to start with will help.
If you suffer form the typical affliction we all seem to have and decide to go longer (upgrade) you will be able to keep the same TV, minimizing the upgrade costs.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-11-2004, 09:34 AM   #3
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Just my 2 cents.....I would and did go with diesel...GMC K2500 Duramax Crew Cab, with hard shell tonneau cover. I get 20 mpg solo and 11 towing a 31 ft Airstream at 70 mph.
The tow vehicle hardly knows the trailer is behind it.
Diesel is cheaper than gas.
Diesel engines last better than gas.
Diesel engines operate more economically than gas miles per gallon.
Like I said....just my 2 cents...
dscluchfc is offline   Reply With Quote
Old 06-11-2004, 09:43 AM   #4
Tin Hut's Avatar
diesel
Unfortunately, diesel is not an option in the Suburban for the near term and we need the Sub for hauling family, dogs, etc.
Old 06-11-2004, 09:44 AM   #5
Over59's Avatar
Putnam , Connecticut
Images: 37
To bad GM doesn't put an oil burner in the Subs anymore or let you get the Quad with an 8L. Don't see how you would be happy with 6L and that much weight off the flats. The Ford Excursion, which I think is being discontinued, does have a diesel option.
Actually I think you end up spending less with the 8L because you cann't get the Quad steering which is about 1200 plus another 1200 or more for the suspension upgrade, no?
Over59 is offline   Reply With Quote
Old 06-11-2004, 09:46 AM   #6
Images: 55
Tin Hut,
ALWAYS opt for the larger engine! You can never have too much power! Besides, as mentioned already, it will make your towing experience that much more relaxing.
Tripp
Tripp is offline   Reply With Quote
Old 06-11-2004, 10:04 AM   #7
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
I looked VERY hard at the Ford Excursion with the PowerStroke Diesel engine.
The decision to go with the Duramax 4 door 4x4 pickup was twofold:
1) I figured that people in leathered comfort, and the cargo in back made sense.
2) I rationalized that a 4x4 diesel pickup would have more value in resale in farm country much moreso than a used SUV with 300,000 miles on it.
I know that there are some options in bed shells that utilize a connection between the cab and bed shell by replacing the back window with this connection to make the bed area available to the cab passengers. Many rodeo people use such customizing optional equipment for the road.
You might want to investigate such options for a pickup, and you might seriously investigate the Ford Excursion with the diesel option...I very nearly bought one of those.
Old 06-11-2004, 10:28 AM   #8
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Tin Hut!
TOTAL 6,716
I don't think that you would ever regret going with the larger motor. While both of my most recent GM tow vehicles pre-date the current redesign, there are evidently some similarities. My current tow vehicle is a '99 K2500 Suburban with the 7400 VORTEC and 4.10 Differentials with the heavy duty 10,000 pound trailer towing package - - it is a fantastic towing rig and now has more than 129,000 miles with only regular service and a few minor maintenance issues (one set of brakes, 2 sets of tires, idler arm, tie rod ends, lower ball joints, and a water pump) it has been a superb vehicle that has met my every expectation.
The Suburban was preceeded by a '95 K1500 Z-71 Chevrolet club cab pickup. It had the 5.7 Liter V8 with 3.73 differentials, and a 6,500 pound trailer towing package. This tow vehicle rated next to the bottom in terms of satisfactory performance - - only my first new tow vehicle (a Pontiac Bonneville) was less satisfactory than the pickup (I am not nor ever will be a fan of pickups). The truck was at its limits with the Overlander (6,100 pounds gross weight), and it gave me a terrible fright going through the Eisenhower Tunnel on I-70 when it was down below 20 MPH in first gear - - it was traded immediately upon return from that trip!
I believe that you would find the C/K 2500 Suburban with the 8100 V8 to be a fantastic tow vehicle. If the currrent models are anything like my experience, the larger engine with get far better towing mileage than the smaller engine - - my 7400 VORTEC exceeds the fuel economy of the previous K1500 pickup under all conditions by at least 2 to 4 MPG.
Good luck with your decision!
Kevin
Kevin D. Allen
AIR #827
Old 06-11-2004, 11:13 AM   #9
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
I'd say if you tow a whole lot, the bigger engine, definitely.
If you tow only sometimes, then the bigger engine will eat a lot more gas if you're using it as a daily driver.
If you want to go by the 20% rule, then you have no choice but to get the bigger engine.
What's your mileage ratio solo vs. towing?
How many miles total a year do you drive?
Where do you normally go when you do tow?
I think this would be an important consideration with the current trend of rising gas prices.
Uwe
www.area63productions.com
Old 06-11-2004, 11:42 AM   #10
Big Dee's Avatar
2004 30' Classic
San Jose , California
Images: 24
I'll tell anyone who will listen: Quadrasteer ROCKS!
If you tow, Quadrasteer ROCKS DOUBLE!!!!
There is simply nothing like it. You guys have no idea what a difference it makes. I will never buy another truck without it!
Just my 2 cents.
"It's the journey."
NorCal Fall Rally, Jackson Rancheria, October 7-9 2011 Click here for more info
Come rally with us.
Big Dee is offline   Reply With Quote
Old 06-11-2004, 08:22 PM   #11
Mariner's Avatar
Trailer weight, trailer towability
Hi Tin Hat,
I must concur with most of the other posters. You really cannot have too much truck!!
I went from a 1/2ton to a 3/4 tone, thinking I had all I would need. Well, guess what, I now have a 1 ton dually and prefer to driving that to a car!
You can get a crew cab with a long box. That will give you more than a suburban will. You can also get this vehicle with a diesel (my engine of choice - looooong story) or a big block gas engine.
Obviously you will go with what you feel good about. Whatever you do, do go with just enough. Guanrateed, a few years from now you will be wanting to upgrade or getter a bigger unit. Having more than you need now will save you money in the future. A bigger engine will oly be idling (or almost) towing your unit. A smaller engine will most likely be working very heard, and as a consequence, burning a lot of fuel. My 2002 Dodge 3500, dually, auto, 4x4, long box gets around 20 mpg without towing (and it is not broken in yet) and towing I would guess 14 mpg.
Go with what you feel comfortable with. Be safe and enjoy your trailer.
Mariner
Mariner
1987 Avion 34V travel trailer (the other cigar tube).
2002 Dodge CTD 3500 Dually, Auto, 4x4
1986 F250 T/C 6.9 Diesel, LB,S/C,4x4,Auto
Mariner is offline   Reply With Quote
Old 06-11-2004, 08:24 PM   #12
Mariner's Avatar
Hi Tin Hat,
Obviously you will go with what you feel good about. Whatever you do, don't go with just enough. Guaranteed, a few years from now you will be wanting to upgrade or geta bigger unit. Having more than you need now will save you money in the future. A bigger engine will only be idling (or almost) towing your unit. A smaller engine will most likely be working very hard, and as a consequence, burning a lot of fuel. My 2002 Dodge 3500, quad cab, dually, auto, 4x4, long box gets around 20 mpg without towing (and it is not broken in yet) and towing I would guess 14 mpg.
Mariner
Mariner
Old 06-11-2004, 10:18 PM   #13
Tin Hut's Avatar
tow
Thanks all. I think I will go with the 8.1 liter engine and give up the quadrasteer option since you can't get it with the larger motor.
Old 06-11-2004, 11:15 PM   #14
jordandvm's Avatar
2017 28' International
Western , Oregon
Images: 58
I have a Chevy 2004 Avalanche 8.1 L 320 hp 3/4 ton. Am pulling a 22' CCD and am real happy!. Yes, 12mpg is average (not towing), but I'm am at the pinnacle of my life, ready to retire, and have been driving 6cyclinder small pickups for the last 25 years. I figure I deserve it !
I have an Excel worksheet that I've used to calculate my tow capabilities, which has been quite helpful (not subject to salesperson bias). Can't post this in this thread, but would email you the worksheet if you are interested.
Good luck!
Jim & Cheryl
2017 28' Signature CCD
2017 GMC Denali HD Crew Cab 4x4
Blue Ox Sway Pro Hitch
WBCCI #3538
jordandvm is offline   Reply With Quote
Tow Chief Trailer Hitch rwriii Hitches, Couplers & Balls 12 09-03-2011 09:20 AM
Lost the ability to see attached photos pienjim Forum Admin, News and Member Account Info 23 12-08-2009 10:48 AM
Suburban ability question Goin camping Tow Vehicles 18 06-01-2008 09:22 AM
what to charge to tow a trailer zoeb nj Tow Vehicles 9 04-18-2008 08:17 AM
Tow trailer wiring? Krazykraut Mechanics Corner - Engines, Transmission & More... 1 12-23-2002 09:34 AM
