Old 01-05-2009, 07:02 AM   #43
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Do conduct a search on "Ham" or "Amateur Radio" - there are several threads on here regarding using the aluminum bullet as a ham shack. Issues like antenna mounts, through-hull fittings for coax, etc.
And there's one big difference between trailers and ships: ships are a lot like airplanes ... when the space starts to seem small, it's darned hard to go outside for a hike! But with a trailer, they're meant to take to places where you WANT to be outside in the first place, so at least in good weather, the interior size is not too important.
AirsDream is offline   Reply With Quote
Old 01-05-2009, 08:33 AM   #44
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
In good weather on my boat I jump in the water, or walk along the dock, beach or make friends on the boat next door and hop aboard there.
>>>>>>>>>>>>>>>>Action
Old 03-12-2009, 03:54 PM   #45
holland , Michigan
Originally Posted by hampstead38 View Post
Oh, I imagine you can convince your wife... if anything ever happens, however, your wife will be obligated to remind you that she told you the 28' trailer was too big. Don't worry, though, she'll only remind you for the time you own the trailer or the rest of your natural life, whichever time period is greater.
My stock advice, husband to husband. It's not about convincing; it's about listening. Whatever you eventually decide, I suggest it will go better if you give your wife a full opportunity to discuss all of her hopes and fears. Whatever you decide, it will be as a couple.
Lets trade wives, mine thinks the 28 is too small!!
safari 28 is offline   Reply With Quote
Old 03-13-2009, 09:36 AM   #46
pixiehat's Avatar
1974 27' Overlander
Grants Pass , Oregon
Actually, I think the fellow that suggested "listening" had the key to an easy, relaxing drive.. Whatever decision you make, if it's made as a couple, will contribute to the "easy, relaxing drive"
regards
Lee
Originally Posted by Road Ruler View Post
The key to an easy, relaxing drive is the in the connection hardware, setup and adjustments.
Very few combinations have this done optimally and most are done poorly.
A high end hitch like the Hensley would give you added safety and drive ability.
Hensley Arrow - Trailer Towing Safety
pixiehat is offline   Reply With Quote
7 Way Trailer Cord aname4me Electrical - Systems, Generators, Batteries & Solar 6 03-09-2011 11:20 AM
Help...need to inspect a trailer in Florida! AirHog Networking 3 01-17-2011 04:56 PM
TowMaster range E trailer tire tvanwave Tires 8 01-14-2011 04:50 PM
Is it ok to plug in small oil/radiator heater? LawChick Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-10-2011 12:45 PM
Airstream in Sunset Article on small homes carnegie1935 Off Topic Forum 0 01-04-2011 12:13 PM
