06-07-2010, 06:51 PM
woodbridge
, Ontario
Trailblazer
Hi all
New here, so please be patient. We are considering a 25 Airstream. Our tow vehicle is a 2008 Chevy Trailblazer 4.3 inline 6. It is rated at 5500lbs. We would use a hensley if needed. For certain an equalizing hitch, Are we getting in over our heads at the 25 foot length?
06-07-2010, 07:58 PM
1961 19' Globetrotter
Southern
Before my currant tow vehicle a 1/2 ton pick-up, I had a 07 trailbrazer and towed my 61 globetrotter with it. It towed it fine but I would not have ever towed anything bigger with it. I think the 19 foot was about enough for it. This was my experience and I am sure u will get many opinions. Welcome aboard!
Jill
06-07-2010, 08:33 PM
2019 27' Tommy Bahama
London
, Ontario
Hi Smeds?
We have a Trail-Blazer in our fleet at the moment so you are welcome to come test drive it with a 25'. You definitely need a hensley and a tire size change would help but otherwise a great drivetrain.
Andrew T
Andrew Thomson London, Ontario
"One test is worth a thousand expert opinions." Tex Johnston, Boeing 707 test pilot
06-07-2010, 08:37 PM
1962 16' Bambi
2001 31' Limited
1985 29' Sovereign
Jenison
, Michigan
Howdy to all........NO WAY......a 25' with a Trailblazer. I think the trailer is going to be WAY TO HEAVY. We pull our 62 Bambi with a 06 Trailblazer and once in awhile it gets a little questionable..... that's not a very nice feeling! I feel you will be asking for trouble.
I'm sorry to disappoint you!
06-08-2010, 07:27 PM
woodbridge
, Ontario
Thanks for the input. I will look for a 20.
06-12-2010, 05:07 AM
Montreal
, Quebec
Ye have little faith
You'll find the contributors in this forum live in two very different camps when it concerns recommended tow vehicles.
There is the vast majority who believe bigger is the only way to go.
Then there is the small minority who get kicked around here who think they can tow with smaller SUVs / minivans.
One thing is for certain, I don't think you'll ever see anyone switch camps
Since you're a proclaimed newbie, why not be open minded and try both.
You are very lucky to be not far from CanAm in London. The owner, Andy, is IMHO a true hitch guru. What does it hurt to TRY.....
And yes, I do live in that small second camp; which I'm sure you'll see lots of posts calling me mis-guided
But hey, I've got big shoulders.
Make up your own mind by trying. At least then you can form your own opinion.
Ron
Montreal, QC
2017 Classic
4 Flexible 100w Solar Panels
3000w Magnum Hybrid Inverter
1000 Amp Hours Lithium Battery
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax
Hensley
06-12-2010, 06:17 AM
1971 31' Sovereign
1967 22' Safari
1958 22' World Traveler
Pardeeville
, Wisconsin
What year of trailer are you considering? The newer trailer of a given length is going to be much heavier than an older one. (generally speaking!)
Jay (KB8VMO)
WBCCI #10917
AIR #32349
TAC #WI-2
06-12-2010, 06:50 AM
St. Catharines
, South Western Ontario
Agree! what a great opportunity for a newby. Can Am has the vehicle you own and will connect it with the size of trailer you are considering. Take it for a test drive. It doesn't get any better than that.
Note that a heavier dual axle Airstream may tow as good or better than a lighter single axle Airstream.
06-12-2010, 06:51 AM
1966 24' Tradewind
Chicago
We pull our 1966 24' Tradewind with our 2005 Trailblazer ext, does an awesome job!
Happy Trails!
06-12-2010, 07:59 AM
2004 25' Classic
Prescott
I'm not familiar with the laws up your way, but here you have to be careful in regards to what is legal according to what the TV is rated for. That would be my #1 concern and what I would look at first. I use an Infiniti QX56 that is more than enough for what it can tow, but it is the tongue weight that I have to be very concerned about to stay within what the vehicle is rated for.
Julia & Bob
W/ Deedee & Boo
AIR #30685
06-12-2010, 08:07 AM
I have a 2004 25 Safari which I tow with a 2000 diesel Excursion.
Unloaded weight of my Safari is 5000 pounds. GVW of the trailer is 6300. Real world towing weight with fluids, propane, t.v.'s clothing, ect. is proabably close to the GVW
I would wager that you would be unhappy towing my trailer with your Trailblazer. I tow in the mountains where you would be towing bog slow up the hills with the engine racing and getting pushed all the way down the hill by the trailer.
You didn't say what model Airstream you are considering. Perhaps some of the older trailers weigh less. I know the Classics, Excella's weigh about 1000 lbs more than the Safari so you would have a bigger problem with one of those.
The other thing you should consider is the gross combined vehicle weight of your Trailblazer which is on the door jam. All Manufacturers', not just Chevy, play a game with tow ratings. The tow rating is based on a ridiculously low tow vehicle weight, often only two passengers and a tank of fuel. The weight of the combined unit determines its performance. By the time you are ready to hit the road, you would be seriously overloaded with my trailer.
Since you are now looking at trailers, consider a lighter one.
06-13-2010, 12:51 PM
2019 22' Sport
High River
, Alberta
There is no legal issue in Canada and the US. Only two jurisdictions address this at all, to my knowledge. California says you can't tow a trailer weighing more than 6000 lbs with a tow vehicle of less than 4000, and Saskatchewan says you can't tow a trailer that is heavier than the GVWR of your tow vehicle, unless it's a fifth wheel or you use a weight distributing hitch. Then the maximum trailer weight is 2x the TV's GVWR(!).
Other than that, yes, you want to be careful not to overload the TV with tongue weight. That shouldn't be an issue for a Trailblazer with a 25' Airstream
06-13-2010, 02:41 PM
St. Catharines
Back in the sixties My dad towed 15 and 16' TT's in month long vacations with 4 in the family.
With a trailer length of 25' there is a lot of room to load stuff in the trailer.
We do this now keeping the TV within the axle load ratings. Works great for us.
