Old 01-05-2015, 04:55 PM   #441
Vintage Kin
Fort Worth , Texas
That's a damn big cat, brother.
Old 01-06-2015, 08:37 AM   #442
2016 30' Classic
Penn Laird , Virginia
Tundra as tow vehicle
I pull a 2008 25 foot International with a 2010 Tundra with the 5.7 liter engine. The tow haul mode should be used when towing or hauling a heavy load in the truck bed. It adjusts the points at which the transmission shifts. For example, with tow haul mode off you may start pulling up a hill and when reaching a certain speed the transmission would shift up, but very quickly it would have to shift right back down because it would sense it shifted too soon considering the extra weight. In tow haul mode, it waits for higher RPMs before shifting up. The lower gear selectors need only be used to hold back using engine breaking under extreme conditions when the smart transmission does not cause as much engine breaking as you would like.
evamcmahan is offline   Reply With Quote
Old 01-06-2015, 09:34 AM   #443
le mars , Iowa
I am wondering if the Tundra (with towing package of course) would be adequate to pull a 30 ft Classic. I understand there are a lot of variables to consider...but just curious is I am even in the "ballpark" considering the Tundra. We are "in the market" for a new AS...unfortunately, we also will be needing the tow vehicle. Planning on attending the RV show in Tampa in a week or so.
iowaal is offline   Reply With Quote
Old 01-06-2015, 12:22 PM   #444
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Not really, but she has plenty of room for her food, water, litter box, and lounging around.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 01-06-2015, 12:23 PM   #445
m.hony's Avatar
2013 30' Classic
Check out my rig in my profile and avatar- I'm gonna go ahead and say, "Yes, it's adequate."
TAC #MS-10
Airforums #70955
Old 01-10-2015, 02:13 PM   #446
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Whether the truck has enough power to pull a 30' is not the only question. The 30' has higher tongue weight and with other things in the truck, you may be well over payload. And more weight means more wear and tear on the truck.
Gene
Gene
Old 01-10-2015, 03:54 PM   #447
SteveH's Avatar
Common Sense , Texas
It probably is adequate in and around the Mississippi Delta country, but how will it be in the Rockies?
And besides, it definitely doesn't have enough power to be jacked up with big off road tires, and flying a huge Texas flag.
Regards,
Steve
Old 01-10-2015, 05:34 PM   #448
Vintage Kin
Fort Worth , Texas
Or carry the Kegarator plus three extra beer kegs like any real truck can do.
Old 01-10-2015, 05:57 PM   #449
SteveH's Avatar
You only carry three?
Regards,
Steve
Old 01-10-2015, 07:01 PM   #450
Vintage Kin
Fort Worth , Texas
Toyota Tundra as a Tow Vehicle
I travel solo. If I get a dog I guess I'll have to rethink it.
Old 01-11-2015, 09:34 AM   #451
sequim , Washington
i had a 2008 Tundra extended cab, which was one of the most comfortable riding trucks i have ever owned. this was before my AS but it had to be able to haul my 10k boat and trailer. there was no way this suspension was up to the task so i added air bags to be able to keep the boat trailer axles level.
then i bought a 2014 Tundra crew cab, virtually the same exact truck as the 2008, no upgrades, no changes from Toyota. same issues with hauling the boat and trailer. the transmission would hunt on even the smallest rises in the road, very annoying and the fuel consumption would break the bank. and for some reason, the once comfortable captains chairs where now only good for about 200 miles before my back made it clear it was time to stop.
when the AS came into view, i knew this truck, despite all the positives, was not going to be up to the task of long haul travel in comfort and without worry. so i shopped around looking for a 3/4 ton but instead got a great deal on a 1 ton Ford diesel. what a tremendous difference with this truck.
for a while i thought this truck was going to be overkill but with the first 900 mile swing we made, i now know i made the correct decision. over north cascades highway at the posted speed limit, down the steep E side, across the deserts of WA and into the side winds of the Columbia gorge, all handled by this truck with ease.
maybe Toyota will start upgrades coming to their iconic truck but right now, i would not be shopping for a Tundra given what other trucks are on the market.
reelfastgreg is offline   Reply With Quote
Old 01-11-2015, 10:27 AM   #452
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Tundras are long in the tooth and I don't like the new styling compared to my 2010 so if I need to upgrade in the near future for towing duties it won't be another Tundra.
Kelvin
Old 01-11-2015, 03:36 PM   #453
m.hony's Avatar
2013 30' Classic
Surely an upgrade is around the corner, but maybe not- look at the Tacoma-
TAC #MS-10
Airforums #70955
Old 01-11-2015, 04:01 PM   #454
Master of Universe
Gene's Avatar
Toyota usually upgrades around 6 years with a minor sheet metal change at about 3 years. The Tundra had some sheet metal changes at about 6 years, maybe 7. The dashboard was restyled and does look better. 2015 has much bigger fuel tank, but I'm unsure whether it is an option or standard. The biggest changes were huge price increases, but with car and truck sales way up, why not increase prices to capture the most you can get out of pent up demand?
Edmunds says the next major change is for 2018, 11 years after the first Tundra. They say fuel mileage will be improved, but they are way behind on that and will probably have a long road to re-build market share. They sell about 100,000/year—after almost 200,000 in 2007, sales have been much less.
This is the worst time to buy, but our Tundra is doing fine so no need to replace it. Whether we will wait 3 more years—or more likely 4 to wait for model change screw ups to be sorted out—is yet to be determined. We've had a lot of Toyotas, but Toyota just doesn't seem interested in this truck. It is a good truck, but getting dated. Reliability is important to us, so we'll see how the others are doing down the road.
Gene
Gene
Old 01-11-2015, 07:44 PM   #455
m.hony's Avatar
2013 30' Classic
With 44,000 miles, I might have my Tundra 15-20 more years or all of 'em-
TAC #MS-10
Airforums #70955
Old 01-12-2015, 05:15 AM   #456
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
Mine only has 26,000 miles on it. I bought it for retirement, which isn't expected for five more years. I'm planning on at least 15 more years total on it. But, then again, that's why I bought a Toyota.
GettinAway is offline   Reply With Quote
Old 01-12-2015, 10:35 AM   #457
Master of Universe
Gene's Avatar
You guys have to start driving. We have more than 98,000 miles, 50,000 towing from Alaska to Key West and much in between.
Here's a bit of a change of subject—I have always used full synthetic oil. Now Toyota recommends changing synthetic oil at 10,000 miles, not 5,000. I asked a service manager whether that meant I could change the oil in the Tundra at 10,000 miles like the newer Toyotas. Some new Toyotas come with synthetic, the '07 Tundra did not. He obviously hadn't a clue, so he just said stick with what the book says. But that begs the question—if synthetic oil is good for 10,000 miles, shouldn't it good no matter what vehicle it is in? Or does it get dirtier in an older vehicle? I have split the difference and will change it at 7,500 miles unless I am persuaded that is not ok. Persuade me (or not).
Gene
Gene
Old 01-12-2015, 11:00 AM   #458
SteveH's Avatar
"Synthetic" oil
This is probably more than you want to know about "synthetic" oil, but you would think synthetic oil would be some thing that was synthesized, but really it's not.
Other than additive "package" differences, all synthetic oil has a base of polyethylene glycol, and guess where that comes from.
Crude oil.
Regards,
Steve
Old 01-12-2015, 11:28 AM   #459
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I think the only thing Toyota has changed on the 5.7L is most newer models are FlexFuel. If you were to switch to synthetic after using normal oil is there a procedure you need to follow or does the synthetic mix OK with the residual standard oil? Just wondering if its worth the extra cost to switch to synthetic since the 5.7L takes about 7.9qts.
Kelvin
Old 01-12-2015, 11:29 AM   #460
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Gene
Hi, my wife's BMW has an oil change rate at 15,000 miles. Scary to me, but so far so good. I do 5,000 miles on the Lincoln.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
toyota tundra, tow vehicles
Toyota Tundra rochar3 Tow Vehicles 140 09-13-2014 08:54 PM
Toyota Highlander as a tow vehicle? hellonewman! Tow Vehicles 6 07-13-2007 07:59 PM
Toyota Sequoia as Tow Vehicle Thegman Tow Vehicles 12 10-13-2006 11:15 AM
New Toyota FJ Cruiser as a tow vehicle? chickin Tow Vehicles 10 10-01-2006 10:15 AM
Old Toyota V6 Pickup as a Tow Vehicle? geokid1 Tow Vehicles 10 04-02-2004 06:44 PM
