Old 03-08-2016, 07:18 AM   #715
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
A smaller gasoline tank is not as worrisome as a small diesel tank when out in the hinterlands.
My 2012 Cummins manual states up to 5% bio-diesel in a pinch. The Big 3 truck stops placard their pumps with "Up to 20% bio-diesel" at a higher price and less energy per gallon.
I seek out Chevron and Shell for diesel as usually they have plain diesel. I have been surprised a few times in Oregon and Texas when they have only bio-diesel.
Old 03-09-2016, 07:24 PM   #716
2003 25' Safari
Grayling , Michigan
larger fuel tank
Originally Posted by GettinAway View Post
I don't think Toyota has ever addressed the size of its fuel tank. I wish they would, but I wouldn't make that a big factor in selecting a truck.
Mine has the e85 flex fuel option. Knock on wood, I've never had a problem, and have been getting 17-19 mpg, with more power than I need.
I'd like to get over 20 mpg. Don't know why, it's just a number.
The 2016 Tundra 5.7 with the tow package comes with a larger fuel tank (I think 36 gallons) and a built in brake controller (at last) though with a full tank of gas the towing rating decreases. Glad to hear you have done ok with the flex fuel engine. I have had mine in three times for related problems. Makes me wonder if gasoline really has more than 10% ethanol than advertised
cando is offline   Reply With Quote
Old 03-10-2016, 03:39 AM   #717
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Yes, the 2016 has a larger (36? 39? gallon) fuel tank, built in trailer brake controller, and the headlights can be aimed to account for tongue weight on rear bumper so you are not blinding oncoming drivers.
Still the only truck I will own.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 03-10-2016, 05:44 AM   #718
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
Well, they've changed the three things they needed to in order to make the perfect truck.
I love mine. I've read on the tundra forum though, where some of the e85 models really do have problems. Less than 10 mpg.. I keep knocking on wood with that one. It's difficult to find gas without the corn..
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 03-10-2016, 06:50 AM   #719
switz's Avatar
2014 31' Classic
Images: 8
Higher prices for the modified gas and less BTU energy output per gallon, so the real cost of decreased milage is never talked about.
The corn lobby wins for now, but the water used to grow corn is not sustainable long term as the water supply is diminishing world wide.
Old 03-11-2016, 05:08 AM   #720
GettinAway's Avatar
There are a few big ethanol plants near my farm. The amount of steam going up in the sky, seen at night, is amazing. It looks like a lot of energy to make that steam, and the water used, makes me think this whole ethanol thing wouldn't be happening without federal subsidies. Amazing amount of corn used also.
2011 FC 23FB
Old 03-11-2016, 07:17 AM   #721
CaptMac's Avatar
2014 25' FB Flying Cloud
Asheville , North Carolina
Well, We went looking at new Tundras today, now that we are both retired thinking we would simplify our lives and have one vehicle instead of having a separate tow vehicle. We were surprised at the cargo capacity of only 1175 pounds, we love the truck (crew cab limited) but how do you make it work, with just the two of us the trailer and the hitch weight we seem maxed out.
I read somewhere that the WD hitch puts some of the hitch weight back on the trailer if so how much? I thought it just evened the weight on the truck.
CaptMac is offline   Reply With Quote
Old 03-11-2016, 09:26 AM   #722
nickclifford's Avatar
1972 31' Sovereign
felton , California
methanol
here's a thought-provoking documentary on this subject
nickclifford is offline   Reply With Quote
Old 03-11-2016, 09:26 AM   #723
1972 31' Sovereign
felton , California
you can watch on netflix
Old 03-11-2016, 09:29 AM   #724
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
If you must abide by load capacity rating, then you have to manage the loads you carry. Figure 20% of hitch weight will be put on the Airstream axles. A late model Airstream 25 has a maximum total weight of 7300#, you need 10% on the hitch for stability, so 730#. We modified our Airstream 25 and adjust loading to stay near that hitch weight. We carry little gear in the back of our truck, and that gear forward of the rear axle, to assist the weight distribution hitch. We have upgraded tires on our Airstream (and can run on three in emergency according to the Owners Manual) so the spare tire is not needed as old Airstreamers often traveled. There are things you can do.
Some of us greatly prefer the ride and handling of lighter duty tow vehicles. Due to the great towing characteristics of Airstream trailers compared to anything else, they work very well for us Airstreamers; most probably not well for a typical box trailer of the same weight.
Tow vehicle ratings are not a dead end. They are a starting point.
Doug and Cheryl
Old 03-11-2016, 04:42 PM   #725
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, if you didn't already buy this truck, keep looking. When I bought my 2014 F-150 there was a fancy F-150 on the show room floor; It had a 1,065 lb payload. This was un-acceptable to me. The truck that I bought has a payload of 1,745 lbs. My trailer's tongue weight takes about 900 lbs of my payload leaving me room for 845 lbs.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-11-2016, 05:10 PM   #726
m.hony's Avatar
2013 30' Classic
Weight distribution might transfer 200#-400# back to the trailer axle/
Not enough-
TAC #MS-10
Airforums #70955
Old 03-12-2016, 12:43 PM   #727
gpt
sequim , Washington
my 2008 tundra was a very comfortable ride, extended cab. my 2010 tundra, crew cab, was most uncomfortable. i got rid of it pretty quickly. now i really don't understand how folks can report 20mpg as the very best i ever did, not towing was 16 mpg. both trucks were 4x4s which i am sure did make a difference.
i ended up with an F350 diesel. i added a 50g aftermarket fuel tank. i no longer worry about load or towing capacities. not towing, 20-21 at hwy speeds. towing the 25', 13.5-14.5 mpg at hwy speeds.
folks, when you post up numbers, it would be very helpful if you clarify if you are driving a two wheel drive truck or a 4x4. thanks.
gpt is offline   Reply With Quote
Old 03-12-2016, 06:18 PM   #728
m.hony's Avatar
2013 30' Classic
15 mpg on 2 wheel drive Tundra...
TAC #MS-10
Airforums #70955
toyota tundra, tow vehicles
Toyota Tundra rochar3 Tow Vehicles 140 09-13-2014 08:54 PM
Toyota Highlander as a tow vehicle? hellonewman! Tow Vehicles 6 07-13-2007 07:59 PM
Toyota Sequoia as Tow Vehicle Thegman Tow Vehicles 12 10-13-2006 11:15 AM
New Toyota FJ Cruiser as a tow vehicle? chickin Tow Vehicles 10 10-01-2006 10:15 AM
Old Toyota V6 Pickup as a Tow Vehicle? geokid1 Tow Vehicles 10 04-02-2004 06:44 PM
