Old 12-07-2008, 01:22 PM   #43
Livingston , Texas
Originally Posted by Scotty Oh View Post
---While on the subject, if the tongue is a little high, should the tongue weight differ than when level or a little low?
With independent suspension, having the tongue a little high will cause the rear TT axle to carry more load than the front axle and will cause the load on the tongue to be greater than if the TT were level.
---Another subject, weighed axles the other day, 3300 ft and 3000 rr hitched up. I am just shy of level nose down, maybe 1" differance ft to rr. If I could get level would it take some weight off tongue?
If you raise the nose so the TT is level, you will actually increase the load on the tongue.
With 3300# on the front axle and 3000# on the rear axle, the load on the tongue might be around 30# less than if the TT were level.
If you really want to know how much the tongue load changes when the TT is not level, you can do the following:
1. Take your TT to the scales.
2. Disconnect from the TT leaving the TT's axles on one scales pad and the tongue jack on another scales pad.
3. Record the front and rear TT frame heights and the readings from both pads for the following: a) tongue 2" above level, b) TT level, and c) tongue 2" below level.
The above readings should show enough variation in tongue load to get a good estimate of the effect of having the TT out of level.
Ron
Ron Gratz is offline   Reply With Quote
Old 12-07-2008, 02:08 PM   #44
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Originally Posted by rangebowdrie View Post
It seems to me that all of the manufactures tow ratings are very optimistic, in regards to safe, real world towing, for 1/2 ton units.
I don't know about that. The marketing dept tells them to juice up all the ratings, some of their legal dept tells them it's ok to add a little "puff" in their advertising since there are court cases saying everyone expects ads to be semi-lies, and the other guys in the legal dept tell them the ratings in the owner's manual and some of the more obscure data at the dealership or online better be true or they're exposing themselves to a liability suit. The legal guys get in an argument about what is advertising and what isn't because the standards may be different and people stop listening.
So, I think what appears on TV may be puffery while the specific ratings in the manuals and other data are probably pretty close to true, unless the marketing dept is in charge. I expect different companies are influenced differently by the various internal wars going on between depts and individuals.
As consumers we have to make a judgment which companies have lived up to their claims on all aspects of their vehicles and hope that tells us what to believe. Companies with poor reliability ratings would be one way to judge company honesty. If they can't produce a reliable vehicle, why should I believe their ratings?
Gene
Old 12-07-2008, 03:11 PM   #45
1999 25' Safari
Port Huron , Michigan
Where is my reply????????????
I posted a fairly long reply about why I chose a 2007 GMC truck over a Tundra. It was not posted. WHY? I don't think I did anything incorrect in the posting process. Did someone delete my coments???? This really concerns me.Has anyone else felt like your coments or reply was deleted????
mi silver is offline   Reply With Quote
Old 12-07-2008, 04:15 PM   #46
87MH's Avatar
1978 31' Sovereign
Images: 292
Don't feel like the Lone Ranger!
Originally Posted by mi silver View Post
I posted a fairly long reply about why I chose a 2007 GMC truck over a Tundra. It was not posted... Did someone delete my coments???? This really concerns me.Has anyone else felt like your coments or reply was deleted????
My guess is that you timed out - happens all of the time...
Just a slight touch of the wrong key will sometimes "poof" away a post - wish I had a buck for every time that happened to me....
Especially for long posts, I will compose in "Word", do a spell check, and then copy to the "reply to thread".
I sometimes think the Forums keeps the timeout function just to test how high my blood pressure can go.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 12-07-2008, 04:37 PM   #47
Master of Universe
Gene's Avatar
Until Rick Wagoner gives back all his salary, benefits and stock options, all posts praising GM products will automatically go bankrupt.
Actually, I thought I posted something on another thread a week ago and then later, it was gone. It wasn't even about GM or the Tundra. So many keys to hit incorrectly. It's a good idea to compose in a word processor, though I never do it. Midway through one of my way too long posts, I sometimes save it (apple C on a Mac). I've also lost them when my ISP fails for a while and stuff goes into the electrovoid.
Gene
Old 12-07-2008, 05:14 PM   #48
78GussyTX's Avatar
1978 Argosy 30
Alvin , Texas
Images: 8
Gene, I'll measure the Argosy on a Monday and a Thursday and see if it's still the same ... hehe!
We do have the original manual, along with the original purchase receipt, and every receipt for every service it has had along the way ... including the Airstream factory repaint in 1995. The trailer is supposed to weigh 5600 pounds as I recall, and the Tundra capacity 10,800 towing plus payload, again if I recall correctly -- I think it was around 12,000 total, but maybe the 10,800 included the payload. So I have never really worried about the weight, by my guesstimates I am way below the point where I need to worry, and towing has always been effortless.
As for the Argosy models, I heard both ways -- that they were a special enhanced breed, and also that they were made because Airstream had a large quantity of aluminum that did not have the proper finish -- which would make sense as to why the Argosy's were painted. In any case, I must say I am impressed at how well it has held up. It is thirty years old now and looks brand new inside and out (see our pics). It is pretty much all original except carpet, exterior paint color, and refrigerator. I guess that comes from my father in law keeping it indoors all these years, a practice we have continued.
I agree that the recent news has made the big three look pretty foolish. And I sure as HECK do not want my money going to bad business decisions. A lot of their vehicles are perfectly good these days, but they have killed their own competitive posture through bad decisions.
We bought a Ford Windstar for $30K in 2001. It traded in 2006 for $3K, with 50,000 miles and very clean condition. That wasn't that great, but worse, it cost us $3K per year in maintenance the last two years, so we "fired" it.
Regards,
Steve
78GussyTX is offline   Reply With Quote
Old 12-08-2008, 08:54 AM   #49
Master of Universe
Gene's Avatar
The Argosy did use a cheaper aluminum and part of the front and back were steel. I think the decision to make them had nothing to do with having a stock of defective aluminum. During tough times economically, it made sense to see if a cheaper model line would sell. I don't think, at least for a while, they sold many. Now there's a Sport model line, lighter, simpler, cheaper, for the same reason.
Gene
Old 12-08-2008, 03:23 PM   #50
OhScottyOh's Avatar
2009 27' FB Flying Cloud
Reedsport , Oregon
Good article in latest issue of Airstream Life on this very subject, about Argosy.
Scott Prall
08 Toyota Tundra Crew Max 4x4 5.7L
Hensley Arrow
WBCCI 6333
OhScottyOh is offline   Reply With Quote
Old 12-09-2008, 04:29 AM   #51
78GussyTX's Avatar
1978 Argosy 30
Alvin , Texas
Images: 8
Thanks for the info Gene and Scott. I have been very impressed with the trailer and how it has held up for 30 years, even more so if that was a cheaper model. I'll be curious to see what the "more expensive" models from the era were like, we will see at our first Rally in Texas in February.
Scott, is that article online somewhere?
Old 12-12-2008, 12:10 PM   #52
b3Talent's Avatar
1991 34' Limited
Wylie , Texas
08 Tundra as T.V.
I keep reading all of the skeptisism about the Tundra as a TV. Let me say that I have a new 08, 5.7 Crewmax and it tows my 34' Classic just fine, HOWEVER my next truck will be 3/4 or better.
b3Talent is offline   Reply With Quote
Old 12-12-2008, 02:36 PM   #53
connorsa's Avatar
1999 34' Excella
Durango , Colorado
Ok, what does 'BIL' stand for? Love the acronyms on the forum!
connorsa is offline   Reply With Quote
Old 12-12-2008, 03:48 PM   #54
Master of Universe
Gene's Avatar
BIL or bi'il
From the Department of Trivia and Minor Hijacking, "bi'il" means "dress" in Navajo. This is a significant part of my vocabulary of about 5 words in Navajo.
As for BIL, I haven't a clue.
Gene
Old 12-12-2008, 04:38 PM   #55
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Brother-in-Law?
Richard
Old 12-12-2008, 04:54 PM   #56
78GussyTX's Avatar
1978 Argosy 30
Alvin , Texas
Images: 8
I kind of got that sense too, I'm not sure why or where that comes from. The Tundra when properly equipped is every bit as powerful just about any vehicle I can think of.
toyota tundra, tow vehicles
Toyota Tundra rochar3 Tow Vehicles 140 09-13-2014 08:54 PM
Toyota Highlander as a tow vehicle? hellonewman! Tow Vehicles 6 07-13-2007 07:59 PM
Toyota Sequoia as Tow Vehicle Thegman Tow Vehicles 12 10-13-2006 11:15 AM
New Toyota FJ Cruiser as a tow vehicle? chickin Tow Vehicles 10 10-01-2006 10:15 AM
Old Toyota V6 Pickup as a Tow Vehicle? geokid1 Tow Vehicles 10 04-02-2004 06:44 PM
