Old 09-28-2014, 10:41 AM   #21
1965 mustang's Avatar
Stoughton , Wisconsin
With weight distribution, doesn't half that weight get distributed to the trailer? So your 1000# tongue weight would really be 500#?
1965 mustang is offline   Reply With Quote
Old 09-28-2014, 11:35 AM   #22
aftermath's Avatar
Spokane , Washington
[QUOTE=1965 mustang;1517139]With weight distribution, doesn't half that weight get distributed to the trailer? So your 1000# tongue weight would really be 500#?]
As I understand it, no. An expert will chime in soon. What the wd hitch does is distribute the weight to the front wheels while taking some off the back. You are still looking at 1000K.
Am I right? Anyone?
aftermath is offline   Reply With Quote
Old 09-28-2014, 12:02 PM   #23
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Some, a little- not half of the weight is transferred-
Think of it this way: no weight distribution, the truck and trailer sag in the middle. The weight bars (spring bars, angle) pick it back up to somewhat level. Cat scales will show you exactly how much weight is transferred.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-28-2014, 12:02 PM   #24
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
The theory is less than a third of the tongue weight gets transferred back to the trailer axles. More typically one is lucky to see a couple of hundred pounds with a 1,000pound tongue weight.
In order for that to happen, a loft of twisting torque is applied to the hitch of the truck trying to force the front end lower by moving a part of the downward force vector forward. So the more one cranks the weight distribution hitch, the more one is applying rotational forces to both hitch socket and tow vehicle frame.
This rotational force has been known to cause issues in the tow vehicle rear end like cracked welds or hitch failure on vehicles without frames.
Our 25FB had a 1,175 pound tongue weight camping ready. That was too close to the factory maximum rating of 1,200 pounds on our Dodge 2500HD factory receiver so I cut the factory receiver off and installed a Curt 15049 receiver rated for 2,550 pounds tongue weight and capable of pulling a 17,000 pound trailer.
Before picking up the 25FB from the selling dealership, my ML320 CDI Mercedes had to go to CanAm to have the hitch reworked so it would not twist off with the weight distribution system.
Our Classic has a tongue weight over 1300 pounds, so we are not overloading the Dodge tow vehicle capability.
Old 09-28-2014, 02:16 PM   #25
m.hony's Avatar
2013 30' Classic
200# transferred is really good.
TAC #MS-10
Airforums #70955
Old 09-28-2014, 03:38 PM   #26
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Switz I believe you mean Curt 15409 receiver there is no 15049 series.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 09-29-2014, 11:49 AM   #27
Vintage Kin
Fort Worth , Texas
As a rule of thumb:
A WDH will leave about 75-80% of TW on the rear axle of the TV. From there, the ratio is 2:1 TV front axle versus TT axles.
The short version is that hitching the trailer will lighten the front axle. Adjust the WDH so that the front axle unhitched and hitched weight are the same or close (less than versus more than). Called FALR [Front Axle Load Restoration].
" . . Of course you can influence this number somewhat by distributing your loads properly inside the trailer".
By properly it is meant that loads need to be near the TT axles (and never to the rear of the TT). On them, or within a short distance.
Old 09-30-2014, 01:02 PM   #28
2015 30' Flying Cloud
Asheville , North Carolina
Tundra towing FCloud 30'
Hi, We have just gone from a 25' FC to a 30'11" FC and tow with a 2008 IForce V8 Crew Max Cab Tundra. We bought from Colonial Airstream and ordered the ProPride Hitch. Amazing......we still don't know the Airstream is back there. Tows like a dream. John
John Moody is offline   Reply With Quote
Old 09-30-2014, 04:26 PM   #29
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I am with you with the 1/2 ton, articulated hitch and a big trailer... Let us see if everyone concurs....
Old 09-30-2014, 05:55 PM   #30
m.hony's Avatar
2013 30' Classic
It's the ProPride that makes it so.
I have a Tundra CrewMax 5.7 pulling a 30' Classic with an Equal-i-zer. It handles fine, but fine tuning is almost impossible.
I can tow easily with good weight distribution and sway control, but my trailer is nose down and it bugs me.
TAC #MS-10
Airforums #70955
Old 10-01-2014, 06:00 AM   #31
2015 30' International
FREDERICK , Maryland
Thanks for the feedback. Will be heading soon to Colonial Airstream to see about trading up to a 27 or most likely a 30 footer.
Doc Foster is offline   Reply With Quote
Old 10-01-2014, 07:46 AM   #32
m.hony's Avatar
2013 30' Classic
Go for the 30!
Make it the last trade for a while-
TAC #MS-10
Airforums #70955
Old 10-01-2014, 08:32 AM   #33
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I think my Equalizer is the same and the trailer may be slightly nose down as well with my Tundra. Would adding another washer into the head help or with 1000 lb bars are they all ready doing all they can do with 4 washers. Propride and Hensley are heavy compared to an Equalizer so do they reduce the payload even more. I'm not sure most RV repair/dealers would know how to install one correctly in my area.
Kelvin
Old 10-01-2014, 04:07 PM   #34
Go for the 30!
That is what we are thinking!
Old 10-06-2014, 11:11 AM   #35
We went ahead and put a down payment on a 30' International Serenity. Will have to wait a couple of weeks as the dealer had to order and then install the window awning package. So about this time next month, will let you know how the Tundra handles the 30 footer, though the 4 hour drive home will have almost no hills to mention. Can't wait!
Old 10-06-2014, 12:37 PM   #36
m.hony's Avatar
2013 30' Classic
It will be fine. I drug a 28' travel trailer behind my Tundra 2 1/2 years before I bought the 30' Airstream. I've been dragging the Airstream around for 2 years. 32,000 of my 42,000 miles are towing a camper. We just returned from a 250 mile trip and are going to Texas Saturday.
TAC #MS-10
Airforums #70955
Old 10-06-2014, 12:39 PM   #37
m.hony's Avatar
2013 30' Classic
Go ahead and get a ProPride now.
$45,000 truck
$80,000 trailer
Why not invest in a $2,300 hitch to make it safe, comfortable, enjoyable?
No, I don't work for ProPride...
TAC #MS-10
Airforums #70955
Old 10-06-2014, 02:01 PM   #38
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
ST tires are not speed rated, but there is a suggestion to not exceed 65 mph. Goodyear says you can go 75 by increasing air pressure in Marathons, but that means a harder ride for the trailer. We don't feel comfortable going over 65, so we don't. We use Michelin LT's on the trailer and the truck. Michelins ride smoother than most other tires, so that is another plus. I believe ST tires are poor quality, don't last long plus they have a history of blow outs; Michelins easily go 60,000 or more miles, so although they are expensive, over time you are ahead.
The Tundra easily pulls our 25 and I don't think a 27 is much different. I'm sure it can pull a 30, but the added weight will wear the engine, transmission and suspension faster. At the price of today's trucks, that would concern me. The Tundra is overbuilt for a half ton, but things wear and you don't know it until it breaks.
Tongue weight as stated by Airstream is unrealistic. And it doesn't count the weight of the propane or a spare tire or stuff loaded into the front of the trailer. A WD hitch transfers approximately 1/3 of the tongue weight to the trailer axles and 1/3 each to each truck axle. We weighed the stuff we bring and got just under the payload for a Double Cab. The Crew Cab has less payload. I was glad to get by because otherwise we would have had to amputate our left legs to reduce weight. Since the Tundra is an automatic, you don't really need your left leg to drive, but it could be a problem to set the emergency brake or walk.
The owner's manual tells you how to weigh the tongue with a household scale and a lever set up, but I've never done it. Take the company weight and add several hundred pounds, divide by 3 and take the number and subtract it from tongue weight to calculate true tongue weight with a WD hitch. Toyota includes a full gas tank when they state payload, so that helps. Some people add an extra leaf or air bags to the suspension, but you still have to consider axles, differential, transmission and engine wear. Put the heaviest stuff forward in the bed to balance weight between front and rear axles. I put the trailer spare in the front of the bed because a 16" tire is hard to get in and out of the tire carrier. This adds maybe 10 lbs. for payload, not enough to worry about.
Gene
Gene
Old 10-06-2014, 04:39 PM   #39
m.hony's Avatar
2013 30' Classic
You really don't want to go over 65 with your Tundra and a travel trailer.
I tried it once and got 7 mpg.
I went 55 mph home on the same trip and got 10 mpg. That's enough to slow me down.
TAC #MS-10
Airforums #70955
Old 10-06-2014, 05:41 PM   #40
Thanks for the heads up. When I drove from MD to Utah this summer, I would accidentally creep up over 55 to as high as 70. When I realized it, I slowed down. That is how easy the Tundra pulled the 25'.
Asking for Toyota Tundra owners and tow veterans... westcoastas Towing, Tow Vehicles & Hitches 40 10-04-2014 10:05 PM
2008 Toyota Tundra and a VTX 1300 hippygypsy Towing, Tow Vehicles & Hitches 4 06-16-2014 02:34 PM
Toyota Tundra 7 pin connector Bonitafarms Lights - Interior & Exterior 13 02-09-2005 05:14 AM
Toyota Tundra Bambi 19' rtate Tow Vehicles 18 05-12-2004 06:58 PM
Toyota, 4x4, V-8, Auto, Tundra pick-up Fogducker Tow Vehicles 13 01-28-2004 07:48 PM
