Old 10-07-2006, 01:29 PM   #1
kontiki
kontiki's Avatar
Profile:  1989 25' Excella
San Andreas , California
Toyota Tundra
Does anyone have any suggestions about towing with a Toyota Tundra? I have a 1977 Argosy 24 ft.
Thanx
kontiki is offline   Reply With Quote
Old 10-07-2006, 01:41 PM   #2
boatdoc
boatdoc's Avatar
Profile:  1973 Argosy 26
Norristown , Pennsylvania
Arrow Toyota Tundra
Hey kontiki; That depends what size engine you have and the horsepower. It is best to check with Toyota dealer if your truck has a towing package and what is the towing limit. If that happens to be 5K you should be fine. What about trans cooler, you should have one even with V8. You will need a weight distributing hitch and sway control. There is much info you must provide for someone to give you recomendation. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 10-07-2006, 01:45 PM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
I tow my 1975 25' Trade Wind with a 2003 Tundra (4x4 4.7 Ltr V8). Your trailer is almost the same size and weight as mine. I have no problems towing. I wish it had a bigger engine when I am going up steep grades, but on the flats it pulls very strong. The Tundra has a soft suspension which is good for the trailer, but makes a weight distribution hitch a must. My Reese has 750 lb bars and seems to be a good fit. A brake controller is another must. I have a Prodigy by Tekonsha which is a very good unit and with the correct addapter cable will plug directly into a plug in the Tundra. I always tow with the overdrive turned off. This makes for poor gas mileage, but a healthy transmission. The only bad thing I can say about the Tundra as a TV is that the mirrors will not let you see enough to be safe. No one makes towing mirrors for the Tundra either. I bought a cheap pair of stap on mirrors at Camping World ($5 each on sale) and they work ok. Yes they shake at hyway speeds, but not so much that you can not use them. BTW, the 2007 Tundra will have a 5.7 Ltr V8 and a 10,000 lb towing limit. They will not be here untill next year.
Richard
Charter Member Four Corners Unit
Old 10-07-2006, 06:33 PM   #4
Bob Thompson
'97 Excella 25
Bob Thompson's Avatar
Profile:  Corpus Christi , Texas
Images: 60
I have a 2002 Tundra extended cab SR5 V8 and have pulled our '97 25' Excella Classic nearly 50,000 miles with it over the past 3 years. The Tundra comes with a transmission cooler standard but I did have to ad a brake controller. I've pulled the Excella all over the West including trips to Seattle, Sonoma, Reno, Sequoia NP, Santa Fe, and Durango. We just returned from a trip along northern Arkansas, Tennessee, N Carolina, Washington DC and back. Although I sometimes wish for a little more truck, the Tundra has proven to me it is up to the task. I almost always pull with the OD engaged and only turn it off if I need to do some technical driving like heavy traffic, going down hills, or difficult up hill pulls. The transmission and the whole truck are doing fine after 94,000 miles although I did flush the transmission and changed to Mobil 1 transmission fluid at about 60,000 miles as part of my standard maintenance. I run 600# bars on the Weight Distribution hitch and it give a very comfortable ride. I use Michelin LTX tires and I keep them aired up to near the max to reduce rolling resistance and improve gas mileage. I got nearly 80,000 miles out of the first set. The ride suffers a little from the high pressures. I've averaged just under 15 mpg pulling the Excella. I replaced the front rotors with Brembo slotted rotors and Performance Friction pads at about 65,000 miles and the newer parts are doing great.
I look forward to driving the truck another 150,000 miles and it looks like it is going to be up to the task.
2002 Toyota Tundra
If the big three auto makers go down, somebody else will pick up the slack, our need for vehicles will continue.
Bob Thompson is offline   Reply With Quote
Old 11-20-2006, 07:21 PM   #5
zadaschwartz
Profile:  1976 26' Argosy 26
Jacksonville , Florida
Towing with a Toyota Tundra
I tow my 26 foot Argosy with a 2000 Toyota Tundra SR5. It has a 4.8 Liter V8 with trans cooler. I have not had any problems towing the trailer. However, I do wish for a bit more speed on the freeway. I can get my speed up to 65-70 mph without the engine feeling as if it is working to hard. However, if I try to push the speed over 70 mph, I can feel the engine really working and can literally watch the gas being guzzled. On another note, the tundra has great torque. I towed our Argosy up to our mountain property in North Carolina one year. We had to pull it up a very steep dirt road just to get the property on the mountain. I put the transmission in low and started up the mountain. The tundra did not miss a beat. It just motored up the hill. As for the brakes, I learned my lesson their too. When I brought the Argosy down off the mountain and down the off the Blue Ridge Mountains, my Tundra brakes were really stinking. I used the brakes quite a bit just to stay slowed down going around the curves on the mountain. This was before I got the electric brakes on the trailer fixed. Highly recommend trailer brakes, they make a world of difference. My Tundra works fine for our needs, but if money were not an object, then I might consider a truck with a bigger engine.
Zadaschwartz
zadaschwartz is offline   Reply With Quote
Old 11-20-2006, 07:33 PM   #6
juel
juel's Avatar
Profile:  1978 Argosy 24
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
I have a 1978 24ft Argosy that I tow with a 2005 Toyota Tundra step-side. The Toyota does a very good job; however, I live in Oklahoma, where there are few hills. I'm not sure I would pick this combo if I was in the Rockies. I have the towing package and a weight distribution hitch. I have the Prodigy brake which is a good choice. I have the SR5 also which has done extremely well so far. Mileage is not bad either.
juel is offline   Reply With Quote
Old 11-20-2006, 10:02 PM   #7
janetb
janetb's Avatar
Profile:  2007 25' Safari FB SE
Aptos , California
Ahh. Yet another thread with info. tailor-made just for us! Thanks Kontiki, for getting it going. We've been feeling apprehensive about towing our new 25' Safari SE (off-line tomorrow~yay!) with our old 2000 Tundra SR5 V8, but now feel that we may be able to hang in there until we get the new '07 sometime in early Spring. In the meantime, we'll avoid towing in the Sierras!
Happy trails, and many thanks!
Janet
janetb is offline   Reply With Quote
Old 11-20-2006, 11:07 PM   #8
pepper48
Profile:  1972 25' Tradewind
Rogers , Arkansas
I tow a 25 ft. 1972 Tradewind with a 2002 Tundra Extended Cab 4.7L V8. The truck has the towing package and a limited slip rear-end. I've towed to Estes Park, Colorado, with no problems. Some of the steep grades did slow me down, but I wasn't in a big hurry. I agree with the posts that recommend a weight distribution hitch and a brake controller. I bought the trailer on Ebay and picked it up in Indiana. I towed it to the nearest RV dealer to have it checked out and to have a weight distribution hitch installed. The trip to the RV dealer required slow speed because the tongue weight left the truck light on the front wheels. I tow in overdrive on Interstates where it is fairly flat. I try to anticipate grades and shift from overdrive before the transmission starts seeking. I stay out of overdrive in heavy traffic and in the mountains. I sometimes wish for more power, but I love the truck.
pepper48 is offline   Reply With Quote
Old 11-21-2006, 07:08 AM   #9
SnorkyII
SnorkyII's Avatar
Profile:  2008 22' Safari
Escondido , California
We tow a 25 foot Safari with an 03 Tundra. It has the V8 engine. I tow with the overdrive off. As I have said previously in other posts, it is a little slow going up the grades. I normally operate in the 2800 to 3200 RPM range on the Tachometer. On the long grades, I drop into a lower gear at 45 MPH. I can pull the Cajon Pass or the Grapevine grades here in California without any trouble, just a little slower. I recently towed the 22 foot Argosy from Colorado to California, and ran most of the trip between 65 to 68 MPH.
Sam
Snorky II
Escondido, CA
WBCCI #2055, VAC
Charter Member FCU, WBCCI Unit #004
ESCAPEES SKP 58345
AIR #13642
08 Safari Sport 22, 03 Toyota Tundra
73 Argosy 22
SnorkyII is offline   Reply With Quote
Old 11-22-2006, 09:22 PM   #10
safari57
safari57's Avatar
Profile:  1951 21' Flying Cloud
West Coast , BC
I suspect you will find McKesh mirrors would work for your Tundra. They appear to fit almost anything out there that I've seen. New they are expensive but we typically find them at swap meets and in local classified papers for the 10 to 30 dollar range. I'm not a fan of the strap on mirrors but they do work in a situation where they are the only thing at hand. I think Dometic may have bought McKesh, but not sure.
Barry
safari57 is offline   Reply With Quote
Old 11-23-2006, 08:34 AM   #11
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
great info in this thread. When you get the personal experiences of those who actually own and do, its much better. I am looking hard at alternatives to the F250 Diesel I now use for our 78 Sovereign. I have been getting a little nutty gathering info on Ford Expedition, Chevy Suburban, and Tundra.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 11-23-2006, 09:27 AM   #12
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Hello kontiki -- I used to have a Nissan Titan for my 24' Argosy. The Titan had an illusory high tow capacity but a low GVWR allowance for passengers/cargo onboard + tongue weight (payload on the order of 1340# with tow package & 4WD). I sold the Titan when other factors led me to an approx 1000# heavier '06 Safari. See: Barkingspider's New Airstream
Some posts above have mentioned overdrive, driving speed and fuel economy. Gear searching is what might happen when you meet the next small hill in the road. If you're in overdrive the tranny controllers will shift down a gear (actually from 5th to 3rd in my Titan!) when they sense the load of a new upslope. This constant gear switching can damage the tranny in average rolling terrain -- and I'm talking improved interstates where grades are gradual. Thus there is a common recommendation to tow out of overdrive when towing. Many owners manuals make this recommendation. Have a dealer let you read the pertinent manual sections if you're considering this. Long downhills, uphills or flats should see less gear searching. But towing out of overdrive will lessen your mileage -- and greatly limit the speed at which you'd care to drive. With my Titan I'd commonly not be happy with RPMs if I was much over 62mph and not in overdrive. Each situation is different ... but take care. Experience of one member pulling a 22' CCD with a Tundra is at Switching to Diesel.
Old 11-23-2006, 09:57 AM   #13
azflycaster
Phoenix , Arizona
Images: 60
Barry
I thought about the McKesh mirrors, but the cost was a little high to see if they worked. I did buy a CIPA 11650 mirror on ebay. It looks just like the McKesh.
I could not get it to stay on the door. It was crushing the rubber so hard that I could not use the window. It always tended to come off at the top. I wound up getting a pair of cheap strap on mirriors at CW for less then $5 each.
They shake in the wind a little, but it is the bst solution I have found.
Richard
Old 11-23-2006, 01:21 PM   #14
SnorkyII
SnorkyII's Avatar
As azflycaster says, the suspension is a little soft. I installed Timbren Suspension Enhansment System (SES) "TORTUN4' to solve this problem. The truck ride is firmer when you are loaded but doesn't change when unloaded. I also looked at installing additioal leaves in the springs, and air bags.
I originally used a set of Ford slip on mirrors I had from an 02 CrewCab. Had to use Tiewraps to hold them on. I finally bought a set of McKesh mirrors. A little expensive but they work fine. I had to bend the tabs a little for proper window operation. They do squash the window rubber, but the rubber has always come back after removel of the mirrors.
Sam
Snorky II
Escondido, CA
WBCCI #2055, VAC
ESCAPEES SKP 58345
AIR #13642
73 Argosy 22
Toyota Tundra & 19' Bambi International CCD Plotrow 2006 International CCD 12 06-09-2006 03:03 PM
2006 vs 2007 Toyota Tundra SilverGate Tow Vehicles 3 04-23-2006 06:36 AM
Towing with a Tundra JimC Tow Vehicles 37 08-03-2003 10:00 PM
Safari 25' Model A towing issues rtierney 2003 Safari 11 07-02-2003 11:15 AM
small trucks ALANSD Our Community 3 05-08-2002 06:01 PM
