Old 08-24-2016, 11:10 AM   #57
dznf0g's Avatar
Oswego , Illinois
Originally Posted by m.hony View Post
Drive each one.
Feel the acceleration.
Feel the responsiveness.
After driving a Titan 5.6, Ford EcoBoost, and GM 6.2 I'm like, "Really? That's all?"
Transmission Type 6-speed automatic 6-speed automatic
overdrive overdrive
Gear Ratios
1st 3.520 3.333
2nd 2.042 1.960
3rd 1.400 1.353
4th 1.000 1.000
5th 0.716 0.728
6th 0.586 0.588
Reverse 3.224 3.061
The first column of numbers is for the 4.6 motor.
The second column is for the 5.7 motor.
My comment wasn't to "dis" your "feel" comment, but there is something needed to be brought up here about throttle feel. In the days of mechanical (cable most recently) throttle actuation, the response of the throttle body was linear, or in some cases, a smooth curve from closed throttle to WOT. With the advent of fly-by-wire, the opening of the throttle plate relative to foot pedal apply is a compound curve relationship....and is engineered for various end means manufacturer to manufacturer...and even between models within a manufacturer's stable. The curve can be manipulated to reduce the propensity for the consumer base to perform unneeded "jack rabbit" starts. This helps fuel economy. This is only one example of the type of programming done. There are many. They are computer controlled and differ in different gears, in TH mode, etc.
As a real world example. The 5.3 L seems to require a lot of throttle input to "get going", as perceived by the driver, but then...say after 1/4 pedal depression, it ramps up more aggressively. Some owners don't like that, but it really helps with city fuel economy.
Conversely, I wish my 6.2 L were a bit more like the 5.3 in throttle response. It ramps up more quickly off idle and, because it is so torquey, has a tendency to spin...particularly when wet. Even dry, it'll chirp when crossing the painted stop line or cross walks. Add a trailer, and a very light foot is required when pulling away.
I don't know if Tundra has gone to fly-by-wire yet, but every truck's "feel" is determined by the calibration engineer.
-Rich-
Old 08-24-2016, 11:29 AM   #58
dznf0g's Avatar
Oswego , Illinois
Drive each one.
overdrive overdrive
Gear Ratios
1st 3.520 3.333
2nd 2.042 1.960
3rd 1.400 1.353
4th 1.000 1.000
5th 0.716 0.728
6th 0.586 0.588
Reverse 3.224 3.061
8L90 trans, 6.2L
First: 4.560
Second: 2.970
Third: 2.080
Fourth: 1.690
Fifth: 1.270
Sixth: 1.000
Seventh: 0.850
Eighth: 0.650
Reverse: 3.820
3.42 gear in the Maxtow
Read more: http://gmauthority.com/blog/gm/gm-tr...#ixzz4IGuJIPbR
-Rich-
Old 08-24-2016, 12:12 PM   #59
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Not taking it as a dis-
Realizing throttle response could be as simple as the spring in the accelerator pedal-
I still love my truck and think is totally up to the task of hauling my Classic 30 around almost every weekend.
Whatever brand someone likes-
Whatever features convinced them one or the other was best for this reason or that-
Whatever you like will serve you well with good dependability, reliability, longevity-
The million mile Tundra has the now defunct 4.7.
I wonder if the 5.7 or 4.6 will ever have a million mile video on YouTube.
I honestly don't think the numbers are figured the same way from brand to brand- there is no standard unless all manufacturers have adopted J2807.
Otherwise it is impossible to compare apples to apples.
The Tundra only has 2 engine choices backed by one each transmission choice and one each rear end gears slightly different depending on 2-wheel drive or 4-wheel drive and tow package.
I opted for the bigger engine due to testosterone maybe, but it is a hoss.
Mine is a 2 wheel drive tow package truck.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-24-2016, 01:35 PM   #60
Alluminati's Avatar
St. Louis , Missouri
Facts please: Is the 5.7 Toy over 420HP and 460 Torque?
Sorry, I was comparing only the two trucks he mentioned: Ford F150 and Chevy 2500. The 6.2L engine is not available on the 2500.
Just the facts: That model Ford requires high octane, and that model Chevy requires diesel to surpass Tundra's torque.
The Morgans
1989 Avion 34VB, "QE3"
2008 Toyota Sequoia 5.7L "Tug"
(Is there no respect for an 8-ton GCVWR truck? *sniff* )
Alluminati is offline   Reply With Quote
Old 08-24-2016, 02:05 PM   #61
dznf0g's Avatar
Oswego , Illinois
Just an FYI..I believe everyone is now J2807 as well as Torque and HP number compliance. I forget the J-number for power ratings, but all complied with that quite a few years ago. Apples are pretty much apples nowadays. FYI also, back in the day, Toyota was indeed the "marketing offender" with T and HP. They tested with no belts driving A/C, PS,, water pump etc. Everyone else had driven components in the test routine. SAE thought better of that one as well as towing figures later.
-Rich-
Old 08-24-2016, 02:11 PM   #62
Alluminati's Avatar
401 ft lb torque is sufficient to pull my 34' trailer, and my Sequoia does it comfortably.
If I were in a race I could just put on the OEM supercharger for that engine. Then I'd get 510 hp and 550 ft lbs of torque.
The Morgans
Old 08-24-2016, 02:13 PM   #63
dznf0g's Avatar
Oswego , Illinois
And I'm not saying otherwise. If youz happy, that's all that matters. I'm just a stickler for accuracy of facts and figures.
-Rich-
Old 08-24-2016, 04:46 PM   #64
m.hony's Avatar
2013 30' Classic
The GM 6.2 gas is rated at maybe 425 hp and 425 ft. lbs. of torque.
The 5.7 Tundra has 381 hp and 401 ft. lbs. of torque.
Facts, but...
To my foot and gut the Tundra FEELS stronger, more responsive, quicker accelerating.
I said this in an earlier post.
It could be transmission gears.
It could be rear end gears.
It could be the spring in the accelerator pedal.
It could be any and/or all of the above.
The Tundra CrewMax still has a larger rear seat area with larger rear doors that open to nearly 90 degrees rather than the 45 degree opening rear doors of others.
It is easier to exit the rear seat of a CrewMax Tundra. The cab is just bigger. The B-pillar isn't in the way of your feet. You just stick your foot out and exit.
When exiting a GM crew cab my feet get hung up at the B-pillar. It takes some thought to figure out how to turn my foot to get it out.
Even compared to Duramax/Allison GM 3/4 ton and 1 ton trucks I can't tell a nickel's worth of difference.
True, the GM trucks at work are towing trailers heavier than my Airstream...
The Tundra feels good to me.
I like it.
TAC #MS-10
Airforums #70955
Old 08-24-2016, 04:48 PM   #65
m.hony's Avatar
2013 30' Classic
Too bad the TRD supercharger is no longer being built.
Maybe there are still some of them hanging around in parts bins.
Who else has 501 hp and 550 ft. lbs. of torque?
TAC #MS-10
Airforums #70955
Old 08-24-2016, 04:56 PM   #66
aftermath's Avatar
Spokane , Washington
We were talking about the 4.7 million mile Tundra in the video.
Not sure the 5.7 will last as long as the 4.7, but I'm sure it will last a long time.
Thanks, I missed that. I had a 4.7 in my 4Runner. It was a great engine. Still wish I had it.
aftermath is offline   Reply With Quote
Old 08-24-2016, 06:36 PM   #67
Alluminati's Avatar
ggreen was comparing Tundra to Ford F150 and Chevy 2500.
Yes, Chevy makes a strong 6.2L engine, but you can't get it in the 2500
Likewise, Toyota makes diesel engines, but they don't put them in Tundras in the US.
The Morgans
Old 08-24-2016, 09:10 PM   #68
dznf0g's Avatar
Oswego , Illinois
"The GM 6.2 gas is rated at maybe 425 hp and 425 ft. lbs. of torque."
420hp and 460 torque. Geez guys, it would take 2 seconds to google this stuff. Again, I'm a stickler for accuracy and facts and figgers.
-Rich-
Old 08-24-2016, 10:05 PM   #69
2007 22' International CCD
I still like my toyota pickups. They take the abuse I dish out, seem to run forever in spite of it, and they seem to be the right fit for my family. If we go to a bigger truck to haul our 22' International better/faster/stronger it will be a nice Tundra crew cab setup. 4x4 optional. Diesel would be nice, but I'm sticking with what I like.
GMC has been a total pain to me in the past, and I won't consider a Ford for similar reasons.
As the old saying goes, you pay your money, and you take your choice. To me and my family, it's Toyota or a Toyota product (Lexus). We've tried other brands, had s fleet of Volvos for a while, but that fleet, while very safe, took far more engineering and hard work to maintain. I don't have to sweat the Toyotas...
KE4GNK/AE
Old 08-25-2016, 05:31 AM   #70
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
It will be very difficult to get me out of a Toyota. We've just had great luck with them for years and years. We've run the landcruisers up to 250,000 before we sold them, and they still had good resale. Same with 4 Runners, and a Tacoma. I a sales rep,,so I put on a lot of miles.
The right diesel in one of the big three, at the right price, may tempt me, but they way they are now priced, I'm not interested.
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Toyota Tundra as a Tow Vehicle evsjr Tow Vehicles 788 05-27-2016 06:55 PM
Asking for Toyota Tundra owners and tow veterans... westcoastas Towing, Tow Vehicles & Hitches 40 10-04-2014 10:05 PM
Should I tow my 1991 Airstream Classic Limited 34' with a 2013 Toyota Tundra Crewmax? auburns2003 Tow Vehicles 8 08-16-2013 06:42 AM
