Old 08-23-2016, 01:54 PM   #43
2015 22' FB Sport
Wethersfield , Connecticut
Originally Posted by thiel View Post
Anybody towing with the 4.6L engine?
I tow a 22 FB Sport with my 2003 4.7L two wheel drive Tundra. With the factory Toyota tow package it is rated for 8000 lbs towing. I have put a lot of miles towing over the years and I get ~ 16 mpg on the highway towing the AS. The 2 wd makes a difference. I live in the NE and use studded winter tires and have no problems getting around.
TinkersToy is offline   Reply With Quote
Old 08-23-2016, 11:15 PM   #44
2016 25' International
Deerfield , Massachusetts
Great info in this thread... Wondering if anyone is towing with a later model 4.6L Tundra.
I'm planning to buy a 25FB this winter and I have a 2013 Tundra double cab 4x4 with the 4.6L engine and towing package. Rated to tow 6900 pounds. From what I'm reading here it sounds like even though I'll be at the very edge of the numbers, the truck won't have much trouble (especially if I add airbags or helper springs). I have four passengers, but wasn't planning to put anything particularly heavy in the bed -- maybe a kayak, a bike, and some camp furniture.
Still, would be nice to hear from someone who's towing the same unit with the same truck, just to put my paranoia at ease! I'm trying to dot every I before I plunk down the cash for the trailer.
thiel is offline   Reply With Quote
Old 08-24-2016, 01:49 AM   #45
Alluminati's Avatar
St. Louis , Missouri
Thiel
A superficial Google search says 2013 4.6L Tundra has a tow capacity of 6,600 and a payload capacity of 1,550. And a 25FB has GVWR 7,300, dry weight of 5,500, and a hitch weight of 837.
Expect a loaded trailer to weigh 1000 lbs above its dry weight. So the 25FB will weigh 6500 which is only 100 lbs less than the truck’s ability. Subtracting the hitch weight from your payload capacity leaves 713 lbs for everything in your truck. If nobody weighs more than 175 lbs, you may be okay, but that leaves no room for a cooler with snacks, or lawn chairs in the back.
Meanwhile the 23FB has GVWR 6,000, dry weight 4800, and hitch weight 467. Now you’re towing a loaded weight of 5800, which is well within the truck’s ability, and you have 1083 lbs carrying capacity inside the truck for people and toys.
Or if you switched up to a 5.7L Tundra, the tow capacity is up to 10,400 lbs, which is well above anything Airstream makes. And a payload capacity of 2,090, which will carry the 837 lb. hitch plus 1253 lbs of people and toys.
I believe your Tundra will pull the 25FB, but it will always be at the edge of its ability and leave a zero margin of error. Get used to white knuckles.
The Morgans
1989 Avion 34VB, "QE3"
2008 Toyota Sequoia 5.7L "Tug"
(Is there no respect for an 8-ton GCVWR truck? *sniff* )
Alluminati is offline   Reply With Quote
Old 08-24-2016, 03:29 AM   #46
CRH
1995 25' Excella
xxxxx , xxxxxx
Yeah, but to get that 2060 payload capacity with a 5.7 Tundra, one has to get a long bed, standard cab, 2WD model.....I bet very few people buy them other than contactors and other people wanting work trucks.
CRH is offline   Reply With Quote
Old 08-24-2016, 07:02 AM   #47
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
We pulled our 23FB with our 2004 Landcruiser. I am pretty sure that it has the 4.6 V8 in it. Power wise, and handling wise, it was no problem. As was mentioned the 23FB is a lot lighter than the 25FB.
The only real complaint I had when towing with the Landcruiser, was the small fuel tank and poor mpg. It seemed like I would start looking for gas about an hour after the last fill up.
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 08-24-2016, 08:08 AM   #48
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Your 2004 Land Cruiser should have a 4.7 V8.
The 4.6 started in 2010.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-24-2016, 08:56 AM   #49
Saint CHarles , Missouri
I will be purchasing a 28ft airstream soon, along with a truck to pull this trailer.
I am the owner of many toyotas in my driving life, but am now looking at a Ford 150 or possibly Chevrolet 2500 for tow vehicles instead of the Tundra. I chose those 2 possible alternatives because of their payload capacity and their better than average reliability ratings in Consumer Reports. Has any of the Tundra owners, or prospective owners, felt like straying to a TV with the extra guts?
ggreen63304 is offline   Reply With Quote
Old 08-24-2016, 10:06 AM   #50
m.hony's Avatar
2013 30' Classic
Nope.
Die hard Toyota fan here- would never consider anything else.
Please do some in-the-driver's-seat time in all of them.
Regardless of what it all looks like on paper, the Tundra 5.7 feels stronger than any of them as far as acceleration and power.
Maybe it's the 4:30 rear end gears and 6-speed?
It feels stronger than a Nissan Titan 5.6, a GM 6.2 with over 400 ft. lbs. of torque and over 400 horsepower on paper, or a Ford F150 EcoBoost. I have never driven a Ram or a new Ford with 5L or 6.2L or 6.4L.
I think after owning many Toyotas you could possibly be disappointed in anything that is not a Toyota.
TAC #MS-10
Airforums #70955
Old 08-24-2016, 10:43 AM   #51
dznf0g's Avatar
Oswego , Illinois
Originally Posted by m.hony View Post
Nope.
Oh! now you've just gone too far..."feels" never works....but yes the rear axle ratio does matter, but what are the trans ratios?
-Rich-
Old 08-24-2016, 10:43 AM   #52
Alluminati's Avatar
Ford's 3.5L Ecoboost engine runs on 87 octane when not towing, but to get maximum torque for towing requires 91 octane.
Chevy does not have a gasoline engine more powerful than the Toyota 5.7L.
Simple examples: I've never had a Ford that didn't require annual service to keep the AC cold. I've never had a Toyota require AC service. Ford's multi-speed intermittent wiper control would be a joke if it weren't a continual thorn in the flesh. If Ford and Chevy's reliability are above average, then Toyota is nothing less than spectacular. It's the simple things that keep me coming back to Toyota.
The Morgans
Old 08-24-2016, 10:48 AM   #53
dznf0g's Avatar
Oswego , Illinois
Facts please: Is the 5.7 Toy over 420HP and 460 Torque?
Also check JD Powers dependability figures. Toy is very good, with some others just measuring tenths of a problem per 100 vehicles behind them. That is so close as to be imperceptible to the vast majority of owners.
However, old truths, become legends which persist...and the race goes on.
-Rich-
Old 08-24-2016, 11:26 AM   #54
I was not aware that the 3.5L ecoboost has a recommendation of running Premium gas for severe duty/towing. I don't like that at all.$$$
Old 08-24-2016, 11:29 AM   #55
m.hony's Avatar
2013 30' Classic
Drive each one.
Feel the acceleration.
Feel the responsiveness.
After driving a Titan 5.6, Ford EcoBoost, and GM 6.2 I'm like, "Really? That's all?"
Transmission Type 6-speed automatic 6-speed automatic
overdrive overdrive
Gear Ratios
1st 3.520 3.333
2nd 2.042 1.960
3rd 1.400 1.353
4th 1.000 1.000
5th 0.716 0.728
6th 0.586 0.588
Reverse 3.224 3.061
The first column of numbers is for the 4.6 motor.
The second column is for the 5.7 motor.
TAC #MS-10
Airforums #70955
Old 08-24-2016, 11:35 AM   #56
1974 25' Tradewind
Calgary , Alberta
A couple of years ago I went from a 2000 Tundra access cab 4WD/4.7 to a 2013 Tundra crew cab 4WD / 5.7. Mainly because my older son grew to 6'3" and he no longer fit in the back of the smaller cab... the extra power in the 5.7 is welcome but I lament the extra 1000 pounds of weight. As we restore our 25' Trade Wind, we'll keep an eye on the all-up weight so that we stay well within the max tongue weight limits, but I've accumulated about 12000 miles of towing both a SOB and flatdeck car hauler on the 2013 Tundra and there are no "extra guts" required, even on 7% grades. You can tell the trailer is back there but it's not like you're reduced to crawling up the hill at 40 MPH.
I can see where a person might want greater load capacity than what the current Tundra has available (especially if you're using the crewcab / 4WD variant like me) with the newer, heavier trailers; but if you can reasonably keep the tongue weight in the sub - 800 pound range (i.e. trailer weight < 6000 pounds) then the Tundra should be more than adequate and the straight-line performance is really only going to be a question of how much money you want to spend on gas.
Alumineer is offline   Reply With Quote
Toyota Tundra as a Tow Vehicle evsjr Tow Vehicles 788 05-27-2016 07:55 PM
Asking for Toyota Tundra owners and tow veterans... westcoastas Towing, Tow Vehicles & Hitches 40 10-04-2014 11:05 PM
Should I tow my 1991 Airstream Classic Limited 34' with a 2013 Toyota Tundra Crewmax? auburns2003 Tow Vehicles 8 08-16-2013 07:42 AM
