Old 12-03-2014, 09:49 PM   #1
2014 19' International
Richmond , Virginia
Toyota Tacoma V-6
Has anyone towed a Flying Cloud m28 with a Toyota Tacoma, especially with empty holding tanks? The truck is rated for it but may be a little light on HP.
TomOnTheJob is offline   Reply With Quote
Old 12-03-2014, 10:08 PM   #2
bgordon's Avatar
Austin, TX & , Colorado
Images: 32
I tow my 1948 16' Boles Aero with a V6 Toyota pickup (pre-Tacoma). I had it weighed at 2500# and have a couple hundred pounds of gear + topper in the bed.
It gets the job done but is laborsome. The 3.4L V6 engines found in Tacomas are quite a bit stronger and if it's a late model 4.0L V6 I think you'd be fine.
The biggest issue is whether or not you'll be going up/down many hills. I'm in Colorado and hills can be pretty stressful. If you're on relatively flat ground it shouldn't be too much of an issue, but if you're going up and down hills I think you'd want something bigger.
bgordon is offline   Reply With Quote
Toyota Tacoma TRD - who's towing with one? keithmac Tow Vehicles 9 10-29-2010 06:45 PM
Towing with a 2009 v6 toyota tacoma TGK Tow Vehicles 25 05-13-2009 04:25 PM
Thoughts on Toyota Tacoma and Safari SE 20' 55neal Tow Vehicles 9 06-18-2008 11:26 PM
Toyota Tacoma Tv? Red Rover All Argosy Trailers 16 01-18-2008 05:10 PM
Need advice: Toyota Tacoma 4X4 Ext. Cab for late 70's 25' Tradewind? thierry Tow Vehicles 20 02-08-2005 06:10 PM
