Old 05-22-2011, 01:36 PM   #15
Mhenry2712's Avatar
2011 19' Flying Cloud
Tulsa , Oklahoma
Originally Posted by overlander63 View Post
Let's see if I can push you over the edge to the 23....
It will tow easier, with less bouncing and sway, because it has two axles. They will tend to want to keep the trailer going in a straight line more than a single axle trailer. Also, the two axles will help in backing, because the trailer won't try to turn as easily, again the axles trying to keep things going straight. The 23 has more room inside, as well (duh!). As long as it doesn't exceed your tow rating, it would be a good choice.
@6000 pounds Its 92% of my 6500 tow rating loaded... It won't being "pushing" if I jump! Generally except for safety Im willing to put up some negatives on the pulling. I've pulled a bouncing Front end loader on a 30 ft trailer...
Mhenry2712 is offline   Reply With Quote
Old 05-23-2011, 05:37 AM   #16
1965 28' Ambassador
Malta , New York
Thanks. I'm going to be towing a 1965 Ambassador that weighs 4,000 lbs approx after completion. has brand new axles on AS that I just replaced.
Airstreamdmb is offline   Reply With Quote
Old 12-28-2014, 01:54 PM   #17
2014 25' Flying Cloud
Hampton , Virginia
We bought our FC 25 RT in Feb 2014 and have pulled it over 4000 miles, 30 nights from FL to Canada this year. Our tv is a Toyota Tacoma long bed 4 door 4 wheel drive with a factory towing package, 5 speed automatic. The AS weights 5300 lbs. with a gvw of 7300. Based on the factory spec of 6500 lbs, tv and the 11000 total gvw we remain below although marginal at time below the weights. We average 13.5 MPH and have traveled through the Blue Ridge and Adirondack mountains, we tow at 55 MPH plus or minus 5MPH.
Chuck
Hampton VA
25 ' flying cloud rear twins
2007 Toyota Tacoma
engineshow is offline   Reply With Quote
Toyota Tacoma TRD - who's towing with one? keithmac Tow Vehicles 9 10-29-2010 06:45 PM
2010 Toyota Tacoma and 23' Flying Cloud jholland Tow Vehicles 24 04-16-2010 09:48 PM
Towing with a 2009 v6 toyota tacoma TGK Tow Vehicles 25 05-13-2009 04:25 PM
Thoughts on Toyota Tacoma and Safari SE 20' 55neal Tow Vehicles 9 06-18-2008 11:26 PM
Toyota Tacoma Tv? Red Rover All Argosy Trailers 16 01-18-2008 05:10 PM
