Old 02-13-2009, 02:54 PM   #1
2007 19' Bambi
New Smyrna Beach , Florida
Toyota 4runner and 19' safari
I own a 4.0L, SR5, 4runner and would like to get 19' Bambi. Will this SUV tow this trailer safely? I would consider the Bambi 16, but sure do love that 19'. We would be traveling in mountains occassionly.
bebelee is offline   Reply With Quote
Old 02-13-2009, 04:21 PM   #2
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
We tow our 19' Bambi with an 03 Pathfinder. I believe its towing capacity and specs will be considerably below yours. We have over 50,000 KM on the towing combination - our home base is Ontario and the perimeter of our travels includes Vermont, Maine, Newfoundland, Alberta, Wyoming, Colorado, Nevada, New Mexico and Tenessee.
In hill country we've never felt the need to worry about maintaining speed on a grade - on a long, steep grades we've slowed down, geared down - and let the transmission to do its work comfortably. Downhill is the same - slow and easy.
Having said that - over time we've had some mixed opinions on the Pathfinders capability and eventually evolved from a basic WD hitch to a Hensley. The discomfort, prior to a Henslyey, was exclusively heavy truck traffic on interstates.
The Pathfinders weight capacity is 5,000 lbs and our loaded towing weight revolves around 4,200 lbs. Presuming you are towing within your weight capacities, but given your short wheelbase, I believe you might also go through the same learning curve that we have. Although the Pathfinders handling characteristics seemed "OK" we graduated to "Great" once we linked the two with a Hensley - the difference is unbelievable - and I can't emphasize that enough.
Bottom line is that our rig today seems well matched with the Hensley and we have no hesitation in considering any trip - anywhere - the only limiting factor may be the Pathfinders age and mileage - we now have almost 200,000 KM on it - and we're wondering whether it might be time to trade. We did plan on moving up to a larger vehicle when that time came - but given the economics of the day - we'll be quite happy to buy back into the same class and size of vehicle as the Pathfinder. The vehicles that we are considering are another Nissan Pathfinder, a Nissan Frontier or a Toyota Tacoma - all smaller than yours.
Good Luck,
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 02-13-2009, 04:33 PM   #3
Road Ruler's Avatar
Images: 38
Jay
Jay. Those Nissan VQ engines are bullet proof.
We had the 3.0 VQ engine in a 93 Nissan Quest. Last year the Quest was broad sided and written off. It had the original engine and tranny. At 435,000 klm's both still worked great. Towing for over ten years didn't seen to hurt it.
Old 02-13-2009, 05:04 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
You do not specify the year or if 4X2 or 4X4.
Based on a 2007 4Runner 2WD/4WD with that engine it was designed to tow 5000 #'s.
>>>>>>>>>>>Action
Old 02-14-2009, 02:37 PM   #5
2007 19' Bambi
My 4runner is a 2007 2WD which I bought used. It appears that a tow package was not optional with the 4runner and wonder if it needs additional beefing up to tow.
Old 02-14-2009, 02:49 PM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Your 2007Toyota4Runner 2WD 4.0L V6 is rated for 5000 #'s. The 2003 (the latest year Airstream supplies data) Bambi 19' has a total gross weight capacity of 4500 #'s, so you should be OK.
This assumes both units are properly hitched and in good condition.
>>>>>>>>Action
Toyota 4Runner TV ? OhScottyOh Tow Vehicles 22 04-30-2008 10:47 PM
Towing 2008 19' Bambi with 2008 Toyota Highlander JDBfreeheel Tow Vehicles 1 03-08-2008 09:27 PM
Toyota Tundra & 19' Bambi International CCD Plotrow 2006 - 2010 International 12 06-09-2006 02:03 PM
Doing research-19' Bambi-Safari OR 23' Safari-WHY? ernesto ca Member Introductions 9 04-06-2006 06:33 AM
Toyota Tundra Bambi 19' rtate Tow Vehicles 18 05-12-2004 06:58 PM
