Old 02-11-2015, 08:06 PM   #1
chaseav's Avatar
2015 25' FB International
Towing with Range Rover
I'm not sure where this topic should go but I was wondering if anyone tows a 5400+ pound Airstream with a Range Rover. It looks to me like the tow capacity is certainly there but the tongue weight with that airbag suspension would be a real problem. I'd all but ruled out the Range Rover as a potential tow vehicle until I saw Land Rover (Europe) doing some big promotion with a European Airstream in tow. It's #hybridadventure on Facebook and Twitter.
If anyone tows with one currently, I'd love to hear feedback. Thanks in advance!
chaseav is offline   Reply With Quote
Old 02-11-2015, 08:14 PM   #2
N/A , N/A
Just FYI, the European Airstreams have a ~ 250# tongue weight, due to a different design (axles being more forward).
rostam is offline   Reply With Quote
Old 02-11-2015, 08:28 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
What year and model Range Rover are you asking about? And what are your towing plans, locally to the State Parks or to Alaska?
Doug and Cheryl
Old 02-11-2015, 08:37 PM   #4
chaseav's Avatar
I certainly appreciate the feedback but I don't think that's accurate. If you're seeing a 250 number that's probably in KG not pounds and if that's the case, it converts to something like 550lbs. Which is exactly the max tongue weight of the Range Rover I'm looking at.
Old 02-11-2015, 08:38 PM   #5
chaseav's Avatar
I'd buy new or slightly used. I understand the diesel HSE will be available in the US next year.
Old 02-11-2015, 08:39 PM   #6
chaseav's Avatar
Tow plans are mostly in the Southeast with an annual trip across the Appalachians and back.
Old 02-11-2015, 09:51 PM   #7
dkottum's Avatar
So you don't have the truck or trailer yet. If buying near new you shouldn't have any trouble getting a Range Rover rated to tow a medium-sized Airstream. The greater question may be an expensive vehicle with a rather spotty reliability history, although I have heard the newer models are much better.
Personally a tow truck is nothing to me but a tool to get our Airstream where we want to go and back without a big investment. Not to big and not too small, but a good match to us, our Airstream, and our travel is the best choice.
Doug and Cheryl
Old 02-11-2015, 10:15 PM   #8
N/A , N/A
Here is the specification of a 27 ft Airstream in UK:
Specifications - Airstream & Company
Tongue weight (Nose weight) is between 110 to 150 KG, which is 242# to 330#. I suspect a North American 27 ft model would have a tongue weight close to 1000#.
Old 02-11-2015, 10:38 PM   #9
dkottum's Avatar
Here is a previous Land Rover discussion that a troll managed to get closed.
http://www.airforums.com/forums/f516...ud-111985.html
Doug and Cheryl
Old 02-11-2015, 10:52 PM   #10
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
I'm guessing the OP is thinking about a 23' FC , if so then the trailer is 8' wide x 23.9' long and dry wt starts at 4806# and gross wt is 6000# tongue wt with propane and no cargo or options is 468#.
We need to know the year , model and options of the Range Rover he OP is thinking about to be able to find out its tow rating in the US.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 02-12-2015, 05:11 AM   #11
chaseav's Avatar
Okay, I have a 2015 Intl Signature 25FB. Empty weight is 5400lbs, and tongue weight is 740lbs with full propane. The 2015 Land Rover Range Rover HSE has a towing capacity of 7716lbs which greatly exceeds that of my Chevy Avalanche at 7200lbs. (Much bigger engine). I can't even find the tongue weight anywhere right now but I believe it's about 550lbs. The tongue weight is the problem but for 2016, the diesel version may be available here which, may, have a higher tongue weight. Mostly what I'm after here is a first hand account towing with a Range Rover and if the tongue weight is accurate.
Also, our tow vehicle is always our multi-purpose, around town vehicle so I can justify the cost (sort of) but the performance doesn't really seem to be there. I'd settled on that a long time ago but seeing Land Rover not only use an Airstream but brag about its capabilities towing with it made me wonder. The rear suspension has a lock out function specifically for towing but I'm not sure what that does to tongue weight.
Old 02-12-2015, 05:18 AM   #12
jmcarter's Avatar
2010 28' International
Richmond Hill , Georgia
IMHO given your desire for a nice multi-purpose SUV you might be better served looking at the Mercedes GL, at least you can get some discounts. Great tow vehicle, especially with the diesel.
jmcarter is offline   Reply With Quote
Old 02-12-2015, 01:16 PM   #13
Tom T
Tom_T's Avatar
Orange , California
We're faced with a similar need & multipurpose vehicle, & wanting the smallest package with a V8, & came to the 2006-10 Porsche Cayenne S as our best bet & what we liked & what alos fit into other activities (e.g.: PCA vs. BMW-CCA, etc.), with the VW Taureg V8 or V10 & V6 TDI cousins as maybe. Similar 7716# TW & 770# HW (with WD, 5000/500 wt. brg. on some specs) as your L.Rover above.
For comparison - our TT is a restored with some mods vintage kin 1960 Avion T20 which Avion brochures from 1960 stated 2680#TW & 275# HW, but I just did a HW last weekend with my new Sherline Scale & got 535# HW - with it loaded as we travel - save a few food & clothing items/bags - plus several wt. adding items probably not included in the 275# HW, including: 2x 30# LP tanks, Hensley Cub WD/AS hitch, Tekonsha RF Brake Controller on an 18x24x1/16 steel plate, & a full larger than stock replacement polypropylene water tank (IIRC it's 27 vs 20 gals.). I'd guess the TW is probably more in the 3-4000# +/- range wet & loaded, & I'll be adding an RV bumper bolt-on 2" reciever & cargo rack with the spare & 2 cruiser bikes to the Avion's 4" rear bumper, which may off-load some HW.
I posted a similar "...give me your feedback...." post & got some good feedback, & some trolls & truck-only folks. Frankly, I found more towing feedback & info on the other Porsche & VW forums. I'd also talked with a bunch of Porsche mechanics & other owners with them, in order to get the full good, bad & ugly on them. I also looked at MBZ ML's, BMW X5's, LR & other mid-sized US & Asian SUVs (Durango/Grand Cherokee, Trailblazer/GMC, Explorer, Land Cruiser/4Runner, etc.) from the mid-late 2000's, before zoning in on the Cayenne S.
Hopefully you'll get some good actual experience here, but suggest that you also follow that approach in checking out the LR to make sure it fits your needs. If the LR is what you want, then check it out thoroughly & know any pitfalls.
If you're not sold on LR only, then maybe look at the other choices out there, & I think the Cayenne S or Diesel are good options in the premier end of the range - along with LR.
No sales pitch, since we're still looking anyway! But more for some ideas on an approach to checking it out for your AS's TV duties.
Good Luck!
Tom
Tom T (janabanana48's other half )
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner)
Tom_T is offline   Reply With Quote
Old 02-12-2015, 03:12 PM   #14
andreasduess's Avatar
1984 34' International
Toronto , Ontario
There's a reason that Land Rovers and Range Rovers are much loved tow vehicles in Europe, not just for travel trailers (which are different over there) but also for heavier jobs, such as horse trailers and even light artillery. I have personally taken a Land Rover British Army truck across the high passes of the Pyrenees, with zero trouble - and not always on paved roads.
They are excellent, sturdy vehicles. The model you're referencing has a US published towing capacity of over 7700lbs.
The HSE has a Jaguar sourced engine, Aston Martin developed the gearbox and the brakes are 19" Brembos. About as far from a toy as you can get.
andreasduess is offline   Reply With Quote
Towing with a Range Rover Sport philian Towing, Tow Vehicles & Hitches 22 02-24-2015 08:35 PM
towing an Airstream with 2008 Range Rover Sport allen galkin Tow Vehicles 17 06-20-2014 07:26 PM
Towing with a Range Rover Jr1974 Tow Vehicles 26 08-26-2013 09:28 PM
Towing with 2006 Range Rover ghaag Tow Vehicles 15 06-30-2010 01:46 PM
towing with a 94 range rover maryszka Tow Vehicles 3 02-17-2004 06:36 PM
