07-21-2010, 03:21 PM
1958 26' Overlander
Mesa
Towing with P-Metric tires on F150?
My 2010 F150 came with Michelin P255/65R17 (35PSI/2000lb rated) tires. They are great, silky smooth tires but they are standard passenger tires, not light truck tires. They did fine towing my Sovereign during the 4th of July weekend but I still feel uneasy towing with these tires. Does anybody else tow with a similar tire and what kind of performance do you get? I'm also curious what other F150 owners have on their truck.
I'm thinking about upgrading to Michelin LT M/S tires (44PSI or 51PSI) but before I pay the big bucks I want to know if it's needed.
Thanks in advance.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
07-21-2010, 04:21 PM
More noise, less signal
2010 30' Classic
South of the river
If you can derate them by 15% and still have them be above your scale weight you should do ok.
07-21-2010, 04:25 PM
1958 26' Overlander
Mesa
Thanks, Jammer.
I forgot to mention that these tires came from the dealership inflated to 40PSI. I'm told that's standard practice with these tires for towing.
1958 Overlander
4CU 1st VP
07-21-2010, 04:54 PM
1979 30' Argosy
Flinton
, where we park it
I think you will feel a lot of side shift when trucks are passing and in high cross winds. I would change to a LT tire. Auto makers put cheap crappy tires on their new cars and trucks anyway and they don't last long if you work them very hard.
Marvin
Marvin & Annie
Toby & Niki (fur babies)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
07-22-2010, 07:00 PM
Ottawa
, Ontario
Does the owner's manual talk about what kind of tires the truck should have?
Stay Calm. Be Brave. Wait for the Signs.
07-22-2010, 07:32 PM
2002 25' Safari
1977 20' Argosy 20
northern valley
, new jersey
Thanks in advance.
Mike,
am perfectly content with the factory equipped BF Goodrich Rugged Trail T/A, P275/95R18
on a 2008 F150 4x4 Supercab.
have towed the 2002 Safari 25C, the 1981 31' Excella, and the 1976 31' Sovereign, all with no problem or issue.
imho, you don't need to spend the money....
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
07-22-2010, 07:43 PM
_
jm'
check those tire size parameters again...
and the rugged trail t/a is an LT tire...
that comes in a variety of load/inflation ratings from 35 psi to 80 psi.
so is your point that something OTHER than mich' in LT is a good choice?
or that E rated tires aren't required?
the oem tires on my last 250 were the same (bfg rugged trail t/a) and lasted ~50, 000 miles all towing.
i agree they are a reliable solid performer even as a oem tire.
the E rating helps if towing larger heavy trailers and carrying a full payload,
but clearly aren't required for lighter weight setups.
cheers
2air'
07-22-2010, 08:25 PM
2002 30' Classic S/O
1989 25' Excella
Missouri Valley
, Iowa
Mike,
My 2010 F150 supercrew, 6.5' box, max trlr pkg. also had P tires - 275/65R18 Goodyears, Wrangler I think. Had a flat w/ less than 5,000 miles - no big deal.
We pulled the 30' Classic w/slide to Newfoundland in May & June. Ruined a tire on a gravel entrance road to a campground. This was a well traveled road. That was all I needed to make me replace them w/ Michelin LT. More plies are tougher tires. For my peace of mind the LTs were worth it. I drive on gravel roads around the farm all the time (Not w/ this truck !!!) I know how I want tires to perform - the P tires weren't for me, rock road or highway!! Its hard to tell but the LTs @ 80 psi didn't seem to ride much, if any, worse than OEM crap.
07-22-2010, 09:55 PM
1958 26' Overlander
Mesa
Thanks Dan. Do you have 4x4 with 3.73 gears? Do you keep your tires inflated at 80PSI? My truck has only a 4x2 with 3.55 gears. I'd love to go with Load Range E but I'm not sure if the OEM alloy wheels can handle 80PSI. Where can I find that out? Tried looking on the rim but didn't see any PSI ratings anywhere.
It's apparent that these P-Metric 35PSI tires aren't going to cut it. Here's my door sticker and I only have 1680lbs of payload. Tongue weight of my Sovereign is about 600lb and I carry 50 gallons of water. That's 1000 lbs already and I haven't even gotten to passengers, generators, and other camping stuff like my inflatable boat.
I'm looking at P-Metric 265s which provide an extra 500lbs capacity per tire at 44PSI. BFG has 265s at 50PSI. The LR-E tires do intrigue me.
Just not sure which way to go?
1958 Overlander
4CU 1st VP
07-22-2010, 10:43 PM
1961 22' Safari
Union
, Oregon
I had three flats in 5 weeks with P rated tires, all on pavement. Changed to LT tires, the same brand, and have had 2 flats in 16 years, with a lot of gravel and rock roads.
In my opinion P rated tires are for city drivers who will never see a pebble on the road.
Sam
07-23-2010, 06:28 AM
1958 26' Overlander
Mesa
Originally Posted by jm2
Mike,
am perfectly content with the factory equipped BF Goodrich Rugged Trail T/A, P275/95R18 on a 2008 F150 4x4 Supercab. Have towed the 2002 Safari 25C, the 1981 31' Excella, and the 1976 31' Sovereign, all with no problem or issue. imho, you don't need to spend the money....
best,
Thanks, Joseph. But your tires have more beef than mine. I couldn't find a perfect match for your size but what I did find was 44PSI at a max payload of 2700lbs. At the very least I'm looking at a similar tire my truck. Do you have 3.73 gears on your truck?
Marvin, yeah. I already do a little.
Aage, no nothing. Just general tire info. Tire specifics are on the door only.
Samb, thanks for your post. What tires are on your truck? BTW, love the dinette/dash. Is your battery box holding up ok with the extra weight?
1958 Overlander
4CU 1st VP
07-23-2010, 06:30 AM
1997 34' Limited
South of Atlanta
, Georgia
I am running 275/55/R20 Scorpions on my 2009. These are the factory tires with a max load of 2040# each at 44psi. When towing our 34' which has an 820# tongue weight, I am within about 100# of my limit. They have been fine so far, but when I replace them at wear-out, it will be with a higher capacity tire. I have factory aluminium rims, and like Mellow Mike am not sure where to find the pressure capacity for the rim. It would be a waste of $ to buy a higher weight capacity tire if I exceed the rim capacity.
Craig and Carol
1997 34' Excella 1000
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
07-23-2010, 06:37 AM
1958 26' Overlander
Mesa
Craig,
What is the max payload for those tires as stated on your door sticker?
1958 Overlander
4CU 1st VP
07-23-2010, 06:41 AM
1986 25' Sovereign
Plant City
I use P225/70/15 XL on my e150 van pulling the TT and i have them set to 41psi. the do just fine. Max load is 2280.
| Thread Tools |
| Display Modes |
