Old 01-27-2006, 02:33 PM   #1
frederic.c01's Avatar
1973 23' Safari
amberieu en bugey France , france
Images: 69
Send a message via MSN to frederic.c01
towing with o.drive
hi all
with my b250 dodge efi, I have three speed + od.On the motorway is it possible to draw with the o.drive when the road is punt.
thank's for yr concils.
fred
If you need something, call me. I will say to you how you to pass some.
http://airstream.blog.expedia.fr/
frederic.c01 is offline   Reply With Quote
Old 01-27-2006, 03:27 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
If your vehicle has a tow/haul mode, perhaps, but if not, the answer most likley would be no, unless you had the engine/trans computer re-programmed to lock the torque converter at a lower RPM, but even then, on some engine/trans, it's still better to drive in 3rd. Even if you did have the PCM re-programmed to lock the TC sooner than later, the trans will still hunt on the hills, which could kill the trans if you are not careful.
Anyway you go, it's a good idea to have a good trans cooler and a trans temp gauge so you can monitor and manage the trans temps.
Old 01-27-2006, 04:47 PM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Check your vehicle's manual and see what it says. GM normally puts something in theirs relating to this. The manual for my half ton van said no, the one for my 3/4 ton van says yes. Two different transmissions, tow/haul on the 3/4 ton van plus external transmission oil cooler.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-27-2006, 04:50 PM   #4
Frederic, I tow with a Dodge Ram 2500 truck. The owners manual states that OD should not be used for towing. As I tow on the flat east coast of the USA, I used to experiment with OD when the roads were flat, with a careful eye on my transmission temperature gauge. I recently experimented with sticking to 3rd gear. The mileage went down from 13 mpg to 12 mpg. I found that the noise actually seemed to lessen as the speed in 3rd gear exceeded 60 mph. As a result of this experiment over several hundred miles, I have decided never to use OD when towing. I don't find the benefits of towing in OD (less noise, better fuel consumption) outweigh the risk of burning out the torque converter lock-up clutches. I normally tow on interstate highways at about 62 mph . I hope this helps. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 01-27-2006, 05:39 PM   #5
1986 34' Limited
Prospect , Tennessee
OD Towing
I have heard several different thoughts on this. One dealer says it's OK to use OD if the trans is not hunting up and down and the RPMs are high enough, another says use tow/haul all the time. I have a 2004 Dodge 2500 Diesel and finally decided if I could keep the RPM's up around 1900 + with my gear ratio (and I don't know what that is) it won't be working the transmission too hard because it is up on the torque and horsepower curve. I pull a 1986 34 foot Limited weighing about 10K lbs.
OD at about 65 mph is about 1900 RPM. I only use that when it is pretty flat (and not windy) and I get about 14mpg. I use tow haul when it is hilly and 55 is about max speed I run at, as I recall, about 2200 RPM. It is noiser and fuel mileage drops to about 11 mpg.
This comes with the disclaimer that I may not be doing right and eventually will pay for it, and your tow vehicle could require a different approach
Lee
Full Time.....keeping the shiny side up
Lee Davis is offline   Reply With Quote
Old 01-27-2006, 06:24 PM   #6
jcanavera's Avatar
Fenton , Missouri
Images: 143
And that's why I recommend following the manual that comes with your tow vehicle. There are way too many of us experts out there who think they have it figured out.
I've towed trailers for 25 years, in the flatlands, Colorado, Ozarks, Smokies and many other places. I've never lost a transmission and I attribute that fact to following manufacturers towing recommendations (gear choices and load limitations), transmission oil coolers, and changing transmission fluids regularly. If you do this, and unless there are inherit defects within the transmission, your transmission will give you long and trouble free life.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 01-28-2006, 12:20 AM   #7
1973 23' Safari
Images: 69
hi all
after the reading of your comments, I read again the handbook of the van.it has a switch to remove the od to thus draw a trailer. i think with the od less rpm less petrol.it is very expensive in France about 1 usd per liter.
fred
Old 01-28-2006, 09:05 AM   #8
1994 30' Excella
Mississauga , Ontario
I have found that the difference in fuel economy between overdrive and third gear when towing my trailer is almost 0%.
The engine doesn't have to work as hard per revolution in third gear and the transmission definitely doesn't down shift as often.
Bon chance.
Al
Old 01-28-2006, 09:16 AM   #9
1973 23' Safari
Images: 69
thank you
it 's just by saving in fuel, if there is no difference between overdrive and third gear it is not necessary to take risks with the transmission.
55/60 mph it is a little slow on our motorway in France but it is the speed limit for the trucks,also we roll like them.
fred
Old 01-29-2006, 09:06 AM   #10
Exeter , Rhode Island
When I am towing on flat terrain I use overdrive, otherwise I use tow/haul mode. Trailer weight, engine size and rear axle ratio all play an important part in towing.
Ben
Rob30044 is offline   Reply With Quote
Old 01-29-2006, 09:24 AM   #11
72 tradewind's Avatar
1972 25' Tradewind
Willis , Texas
Images: 8
towing in overdrive
Don't do it! It will kill your transmission
72 tradewind is offline   Reply With Quote
Old 01-29-2006, 09:37 AM   #12
2006 30' Classic
Farmington , New Mexico
Images: 14
towing in overdrive ?????
That blank statement simply is not true!! Using overdrive to tow depends on the tow vehicle you're using and the load you're towing. READ YOUR MANUAL !!
pieman
Mike Lewis is offline   Reply With Quote
Old 01-29-2006, 10:12 AM   #13
pieman
I agree. My tow vehicle is a 2001 Chevy Crew Cab, 4WD, 8.1 eng. 4:10 axle ratio. According to my owners manual I can tow a trailer with a maxium weight of 15,200 lbs. My 89 Excella GVWR is 8,300 lbs. I don't think that I will damage the 5 speed Allision transmission towing in overdrive on level terrain.
The owners manual states Tow/haul is most useful under the following conditions:
* When pulling a heavy trailer or a large or heavy load through rolling terrain.
* When pulling a heavy trailer or a large or heavy load in stop and go traffic.
* When pulling a heavy trailer or a large or heavy load in busy parking lots where improved low speed control of the vehicle is desired.
Ben
Old 01-29-2006, 10:30 AM   #14
65glbtrotter's Avatar
1965 20' Globetrotter
Yakima , Washington
Images: 31
I agree
pieman
I tow a '65 Globetrotter with my '05 GMC Sierra and most of the time I leave to OD on and my trans temp does not go up, the only time I turn it off is when I am going up step hills and it kicks down a gear!
65glbtrotter is offline   Reply With Quote
Towing Experience app Tow Vehicles 9 04-19-2004 10:51 PM
towing with Roadmaster/ Fleetwood Cruiser On The Road... 1 09-26-2002 05:14 PM
Towing Regulations by State InsideOut Towing, Tow Vehicles & Hitches 2 09-16-2002 08:35 AM
Towing cars CBBOB Airstream Motorhome Forums 13 07-24-2002 09:15 PM
towing enclosed racecar trailer fangthorpe Mechanics Corner - Engines, Transmission & More... 1 06-30-2002 05:45 PM
