Old 06-10-2006, 11:00 PM   #29
wbrownrr's Avatar
2002 22' International CCD
San Luis Obispo , California
Thanks for your input, uwe. We plan a trip to Zion, Bryce and the north rim of the Grand Canyon in just about a month. That will give the setup a good workout! Plenty of flat freeways followed by some climbing. No OD, of course, on the climbs and a chance to try things out on the flats.
Wayne
2002 22' CCD
2008 Dodge Ram 1500 5.7L Hemi
wbrownrr is offline   Reply With Quote
Old 06-10-2006, 11:32 PM   #30
wunderful62's Avatar
1962 19' Globetrotter
sunnyvale , California
Rivet towing in overdrive
i too tow a 1962 19 ft globetrotter, with a 98 gmc sierra xcab long bed pick up.on long trips and level ground i use the overdrive, mine is a lowered truck with 17 inch wheels and low profile tires,this equals lower gearing ,higher engine revs at a given speed and throws off speedo calibration by a low no of miles,but i am careful with hills,frequent trans services etc and i tow a lite trailer ,and with my setup dont think it is that big a deal.it is good to understand they are breakable and you wont be going anywhere once you damage an overdrive.
wayne wunder ,w.b.c.c.i./v.a.c.#4287 1962 19ft globetrotter
wunderful62 is offline   Reply With Quote
Old 06-11-2006, 08:50 AM   #31
DAFuller's Avatar
2001 19' Bambi
Gorham , Maine
A friend with a Dodge 2500 (2000, I think) killed his auto trans by towing in OD (at lease that is what the mechanic who fixed it told him the cause was). He was towing on fairly level terain, trying to save a bit of gas.
DAFuller is offline   Reply With Quote
Old 06-11-2006, 09:45 PM   #32
1960 24' Tradewind
santa barbara , California
hello everyone,
My input in this discussion is (speaking from a auto/truck mechanic techs
experience) With some exceptions ,towing in overdrive is NOT recommended generally speaking .the overdrive ,lowers the engines RPM and with a load
(part of the exception here) that is not great ,say a 60s bambi or utility trailer it can be done. Increasing the towing load greatly such as an excella
or late model 25ftr can cause the trans to hate life and overheat ,that heat destroys and breaks down the transmission fluid ,the clutches and bands burn up,the converter goes south .There is no maybe ,it will in time as others here have found out .Silvertwinkie added trans cooler ,PCM upgrades and changed the behavior of the trans .Thats what the tow/haul is also for ,the trans is controlled by the PCM or power train control module .the shift points are raised ,the converter is in lockup so no slippage happens .Still if you have an axle ratio that is a tall gear even in tow/haul ,too much towed weight or load will take it's toll on the trans .Remember HEAT is the automatic transmissions enemy .So follow the owners manual recommendations above all else ,they build the vehicals so they know what they can handle .But as noted some setups can tow in OD ,as some are doing ,I know for certain that
shifting out of overdrive on the hills will solve alot of problems.On my setup i have a fuller 5 speed overdrive in the travelall and definatley have to put it in 4th or sometimes 3rd on the steep hills with my 60 tradewind ,if I did not i would lug down the engine and damage to it will result .The aftermarket chips and modules from JET PERFORMANCE or HYPERTECH raise the shift points and converter lockup times so they are a good upgrade as well. EVERY auto trans towing needs the biggest trans cooler they can fit ,and a temp gauge so you can monitor your trans temp while towing and that alone will give you more peace of mind and control of your vehical.
Happy towing
Scott
scottanlily is offline   Reply With Quote
Old 06-12-2006, 09:14 AM   #33
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
What about with manual transmissions?
This weekend, driving across 250 miles of prarie, I had ample oportunity to think about using that 5th grear. I restrained myself, but couldnt help but wonder if I wouldnt be better off using it on the flats. On a second note, does anybody know what the optimum RPM zone is for towing with a 91 F 150 with a 302 or where to find out?
thanks
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 06-12-2006, 10:42 AM   #34
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
On my 3/4 GMC Savana Van, 6.0 liter 4.10 axle, tow/haul configuration with transmission oil cooler, my manual does note that OD towing is permissible as long as you do not have excessive hunting. Tow haul pretty much steps down the shift points so the tranny will downshift sooner, and hold the lower gear longer.
From what I can determine, this combo will handle the OD towing reasonably well. Its not unusual to see that I still haven't gone in OD at speeds as high as 55, until the throttle position and load on the engine decreases. I towed in third in all other vehicles prior to this one, this being the first to state that its okay to use OD.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-12-2006, 06:26 PM   #35
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, wbrownrr,
The flip side of having the 4.10 rear end in the Dakota was climbing the hills in Kentucky and Tennesee at 3500 rpm at less than 60 MPH in 3rd gear. That was no fun at all.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 06-12-2006, 11:47 PM   #36
1960 24' Tradewind
Hello Gen Disarray,
I tow in fifth OD all the time with my travelall except where i noted in my previouse posting .It depends on your drivetrain .I have a big v8 392 cid and 4:10 gears ,32" all terraine BFG tires so the gear ratio to RPM is very good .The engine is at about 2000 rpm at 65 mph in fifth gear so It works well .That 5 speed gives me total control of the gearing ,when I aproach a grade of signifigance ,I will pull it into 4th or third if needed then put her back into 5th ,its all about keeping the engine RPM in the torque range thats
needed .
Scott
Towing Experience app Tow Vehicles 9 04-19-2004 09:51 PM
towing with Roadmaster/ Fleetwood Cruiser On The Road... 1 09-26-2002 04:14 PM
Towing Regulations by State InsideOut Towing, Tow Vehicles & Hitches 2 09-16-2002 07:35 AM
Towing cars CBBOB Airstream Motorhome Forums 13 07-24-2002 08:15 PM
towing enclosed racecar trailer fangthorpe Mechanics Corner - Engines, Transmission & More... 1 06-30-2002 04:45 PM
