Old 11-28-2014, 09:29 AM   #1
Westlake , OH(summer)NC(winter)
Towing with new MB GL350
Anyone out there towing the AS with a newer model (2013--2015) GL350? If so, what type of anti-sway hitch are you using and did you install electronic brake controller? Also, any mods to the factory hitch?
Thanks much. I'm Planning to tow a 25' Flying Cloud with the new GL.
OHNewbie is offline   Reply With Quote
Old 11-28-2014, 09:55 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I'm not the best one to answer, but I towed a 20' with a '05 ML500 and now tow a 25' with a '12 Dodge Durango, which is the same platform as a GL.
On both I used Reese Dual-cam with a Prodigy controller, no hitch mods.
You certainly will need a controller.
2019 Ford Expedition Platinum
Old 11-30-2014, 09:03 PM   #3
dmcgaugh's Avatar
Seattle , Washington
I tow with a 2012 GL350. Have an Equal-i-zer hitch and Prodigy brake controller. Assuming the 2013+ is the same as the 2012, the factory tow package is prewired with the wires under the driver's side dash. I extended the wires into the center console compartment and installed the controller inside the compartment out of sight.
dmcgaugh is offline   Reply With Quote
2012 GL350 Hitch Reinforcement dmcgaugh Hitches, Couplers & Balls 14 07-04-2021 06:43 AM
Sprinter one-ton towing/non-towing hwy mpg? gecko Tow Vehicles 18 08-02-2014 10:57 PM
Towing 2012 w/Mercedes GL350 Bluetec jevering Towing, Tow Vehicles & Hitches 3 04-21-2012 10:45 PM
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
