Old 01-13-2013, 09:24 AM   #1
San Diego , California
Towing with an F150
We are new to learning about Airstreams. We have a 1994 F150 V6 4.9 Liter manual transmissions in very good running condition. We are we are looking at 23FT & 25FT airstreams, mainly Safari and Internationals, but we are concerned about towing.
We would love your expert advice!
Regards
Susanne
smccall is offline   Reply With Quote
Old 01-13-2013, 09:47 AM   #2
Denis4x4's Avatar
Durango , Colorado
Try this forum:
View forum - 1980-1996 F-Series - Ford F150 Forum
I have a 2002 F-150 with the factory tow package that is rated to haul a 25' AS. Lot's of good info over there.
Denis4x4 is offline   Reply With Quote
Old 01-13-2013, 11:17 AM   #3
Towing with F150
Thanks Denis for link, can't wait to read it.
Regards
Susanne
Old 01-13-2013, 12:39 PM   #4
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
Have you looked up Ford information on your truck? I did a quick google on your truck and while this is a 1995 if you have this tranmission it doesn't sound like your truck will tow very much.
1995 F150 towing capability - Ford Truck Enthusiasts Forums
Point is to investigate the various ratings on your vehicle first including combined weight rating and rear axle rating. Then on a vehicle this old, consider how well the maintainance has been done. This is more than just oil changes, have trans fluid and axle fluid changes been done. If you have owned this for a long time you obviously know how well it was taken care of, if purchased used did you get any maintainance records. Also consider what condition the cooling system is in. Towing puts increased load on all the vehicle systems.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 01-13-2013, 02:13 PM   #5
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
We have towed our 25' for three years with the 5.3L F150. It's adequate, but works really hard in the mountains. I'm hoping to update/upgrade to a later model Tundra. I really doubt you'd be happy with that truck for either a 23' or 25'
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 01-13-2013, 03:07 PM   #6
Connellsville , Pennsylvania
The strength of the 5-speed manual was the limiting factor for low tow rating on those trucks. I don't remember the exact #'s, but the 4-speed manual and auto trucks were rated much higher. I had a friend that used to buy new f-150's in the '90's every other year for his nursery business. He would alway buy a non-overdrive 4-speed and then eventually autos for that reason.
Midnightmoon is offline   Reply With Quote
Old 01-26-2013, 10:40 AM   #7
Dobber's Avatar
2012 25' FB Flying Cloud
Queens , New York
f150forum
here is another great resource :
Ford F150 Forum - Community of Ford Truck Fans - Powered by vBulletin
Dobber is offline   Reply With Quote
Old 01-26-2013, 11:46 AM   #8
Columbus , Ohio
Ford has really improved the F-150 over the years. But in 2009 they accelerated the arms race. In 2009 Ford improved their frame. Poplular Mechanics said it was as if Ford gave every bolt and nut 1/2 a turn tighter. Fords fully boxed frame was was a game changer. No rattles, no squeaks and a really nice interior. But yhe 5.4 litre engine was a dog and they new it.
In 2011 Ford introduced new engines that were head a shoulders over the previous engines. I bought a new 5.0 litre and I smiled everytime I drove it. The Eco-Boost was not out yet. The 5.0 litre Ford got better mpg than the Honda Ridgeline it replaced. I test drove the F-150 Eco-Boost and thought WOW. That is really a powerful engine. I would recommend the F-150 Eco-Boost engine to anyone looking for a 1/2 ton truck.
Ram, Chevy, and Toyota are trying to catch up. In this next year or two they will catch up as the frames and engines and now 8 speed transmission from Ram will level the playing field. Just in time for Ford to introduce a Eco-Boost 5.0 litre engine I hope.
tuffr2 is offline   Reply With Quote
Old 02-01-2013, 10:29 PM   #9
mefly2's Avatar
2015 25' FB Eddie Bauer
Ram owners might feel that they did catch up ... just an opinion, YMMV.
Old 02-02-2013, 05:07 AM   #10
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Susanne
We have a lot of customers that have towed many thousands of miles with your truck. Most have the automatic transmissions but I prefer the manual. You do need to learn to back up well so you are not slipping the clutch too much getting into campsites.
That 4.9 is an industrial engine it used to go in school buses and run big genertors wide open all day it is almost like a diesel when you tow with it, not a lot of Horsepower but huge low end torque.
It is important that you set the hitch up correctly and get an inertia based brake control. A couple of things can affect the performance, do you know your axle ratio? If you don't post the axle code from the sticker on the drivers door frame. Is it 2 or 4wd? What size tires does it have on it?
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Questions about towing a 25FB with a F-150 barrettjl Towing, Tow Vehicles & Hitches 32 03-13-2012 11:13 PM
Towing Question from a novice imaginair Tow Vehicles 13 10-20-2011 07:15 PM
Towing with a TDI VW Jetta PA BAMBI II Tow Vehicles 102 07-21-2011 09:27 AM
F150 towing a 25 FB Flying Cloud Forger Tow Vehicles 7 03-24-2011 07:59 PM
