Old 07-13-2011, 08:38 PM   #1
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
Towing with a TDI VW Jetta
On our vacation to the Adirondacks this past week I ran into a fine Canadian couple who were towing a 2008 20' AS Safari with a TDI Jetta of the same vintage. They were all set up with a weight distributing hitch system and towing mirrors. I was shocked by the rig- but the gentleman assured me they feel very safe and capable with the car as a tow vehicle.
Turns out they have towed with this combination across country a few times, over the Canadian Rockies and coastal mountain range, from sea level to 7000' above sea level with no problems. He attributes this to the low torque of the TDI, a manual transmission, and the correct towing set up done by Can-Am RV Center in London, Ontario.
I have some pictures of the car and trailer and the towing package, but none of the rig hitched up to go. I will post them when I get time.
Ben
PA BAMBI II is offline   Reply With Quote
Old 07-13-2011, 08:58 PM   #2
Hillsboro , North Carolina
Jetta TV
These people are out of their &^%$# minds. IMHO.
How can they even handle the tongue weight? Braking?
TDI's can hardly handle braking when loaded with stuff from the lumber yard!
Yes, it can be "pulled", they have the torque.
But safe? YIPES.
TinCanLand is offline   Reply With Quote
Old 07-13-2011, 09:24 PM   #3
Incorrigible
Ike T's Avatar
1976 Argosy 24
-- , Georgia
I sure hope the Jetta's brake system components were upgraded as part of the setup.
Tim
1976 24' Argosy
1973 International Harvester Travelette 1210 4x4 'Bernard' 164" WB
1997 Georgie Boy 30' SuperDuty v10
Ike T is offline   Reply With Quote
Old 07-13-2011, 09:30 PM   #4
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Tell you what - I've got a Passat TDI, and it's a very nice little car (though one body size bigger than the Jetta) and it's got lots of low end torque. Engine is pretty comprarable to the Jetta's, but possible a bit beefier, but I wouldn't tow a garden trailer with it. I just don't think the suspension is up to it, the brakes are designed only for the vehicle itself, and if I recall correctly, there's not even a factory hitch for it ... so I just wouldn't go there ... all I can say, is "Good luck with that!"
AirsDream is offline   Reply With Quote
Old 07-13-2011, 09:41 PM   #5
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Hey All
I don't see braking as the issue. The Jetta's brakes stop the Jetta. The Airstream's brakes stop the Airstream.
In Europe there is a frame hitch available that allows the Jetta and Golf TDI to tow a max load of 3,600 lbs.
I am giving some consideration to towing a Basecamp with a VW Golf TDI. I would think that this combo would be able to achieve 25 mpg. I would prefer to tow with the Golf as I believe it would be more stable and the tongue weight would be less of a problem with the short distance between the rear wheels and the tongue.
I suspect the Canadian couple felt comfortable because they have logged lots of miles with their combo and it has been properly engineered by Can-Am.
Dan
Old 07-13-2011, 09:49 PM   #6
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Just out of curiosity, what happens when the Airstream's brakes fail on a 10% downhill grade when a Jetta is in front?
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 07-13-2011, 09:56 PM   #7
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
You get a vw golf at the bottom! Lol
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 07-13-2011, 10:05 PM   #8
Maniacal Engineer
barts's Avatar
Menlo Park , California
I would think the brakes on the Jetta are capable of stopping that rig at least once. I'd feel more comfortable w/ surge brakes, I think; they're more reliable than electrics.
I have a Jetta TDI, and while I'm not likely to tow w/ it, it has plenty of handling, power and brakes to pull my 1000 lb boat. It's a far better tow
vehicle than my CJ7 was....
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 07-13-2011, 10:10 PM   #9
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Hey All
Dan
Well said Dan. I keep telling people that if the brakes will stop the car (which they do), then the trailer brakes will stop the trailer. Like you, I see no issue at all.
You can rest assured that Andy Thompson at Can Am would not have sent a customer out in a combination that either didn't work or wasn't safe; his reputation is made on these things and that reputation is formidable. He tends to work on the math and physics of towing rather than the general received wisdom and hearsay that is prevalent in the RV world. He then proves his work with track and road testing and ultimately, of course, with thousands of happy customers.
I'd imagine all the Can Am customers out there will be smiling at the success of the Jetta as a tow vehicle for an Airstream and the somewhat alarmed comments of the non-Can Am customers.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 07-13-2011, 10:11 PM   #10
MrUKToad's Avatar
Chatham , Ontario
What if they don't?
Old 07-13-2011, 10:29 PM   #11
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Kevin
I would not panic because I would already be in a lower gear using engine braking to keep my speed down. The VW 4 wheel disc brakes would then be adequate to provide additional braking as needed. Also, we are talking about a 3,000 lb car here and a similar 3000 lb trailer. I suspect the 6,000 lb truck towing a 9,000 lb (or more) trailer would have more of a problem stopping than the VW would.
I always use engine braking for controlling my speed when going downhill whether I am driving my car (5 speed manual) or towing my trailer (6 speed auto). This has allowed me to drive 150k on my 02 BMW 330 Coupe before replacing the brake pads.
Dan
Old 07-13-2011, 11:07 PM   #12
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I have the Jetta TDI manual transmission. Plenty of torque at low rpm, stiff and solid suspension handles incredibly well, disc brakes all around stop it on a dime. Heavy in front and light in rear, I think it could tow very well and be very stable doing it.
I also have the 20' Safari and I've been thinking about it. I suspect it would be more stable than the pickup and stop at least as well, wonder mostly about the gearboxes holding up. Our excellent TDI experience will probably put us in a Touareg TDI so we don't have to drive around in a pickup when we are out for six months.
doug k
Old 07-13-2011, 11:09 PM   #13
dkottum's Avatar
Ben, please post the pictures. Thanks!
doug k
Old 07-14-2011, 05:27 AM   #14
oh2bcarefree's Avatar
House Springs , Missouri
Images: 48
Andy from Can Am RV in Canada drove the TDI combo to Alumapalooza in 2010. Here is a link to the thread page with a photo by Tinloaf. It's in post #174.
I also drive a '09 TDI, but am not going to use for a tow vehicle. It may be able to do it... but, I personally don't have the comfort factor. Maybe it's a mental stereotype, but I have more comfort with a bigger engine/size vehicle (truck).
http://www.airforums.com/forums/f290...tml#post857689
Tina
Tina and Mike
1959 Avion e-20
oh2bcarefree is offline   Reply With Quote
Question: Can you keep the refrigerator on while towing? Scott J-24 Refrigerators 59 11-25-2015 08:53 PM
Towing 2011 Classic 34 With Chev Duramax RV Doctor Tow Vehicles 13 04-17-2011 10:21 PM
Towing with a 1996 Roadmaster wagon Globie64 Tow Vehicles 7 03-30-2011 11:56 PM
Towing and oil analysis pappy19 Tow Vehicles 12 03-23-2011 08:57 PM
