Old 02-10-2006, 06:50 AM   #1
1958 26' Overlander
Lachenaie , Quebec
Towing with a Land Rover
From what I've read, towing an Airstream with a Land Rover is a pain in the A*** (short wheelbase, reliability, towing capacity). Unfortunately, changing vehicule at this time is not an option. Any suggestion to enhance my towing pleasure?
Daniel
dan_lemire is offline   Reply With Quote
Old 02-10-2006, 06:54 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
It all depends on what size Airstream your considering...... I'd suggest something totallly different for a 16" then I would a 30+'.
Old 02-10-2006, 07:23 AM   #3
Jim Jarzabek's Avatar
1950 25' Cruiser
Lebanon , Ohio
Images: 16
What will you be towing?
Dan
What you are towing determines the type of tow vehicle you will need......
You cannot turn the Land Rover Discovery into something it was not originally designed and engineered for
If you want a recommendation for a truly "all purpose" tow vehicle that is reliable, it is hard to beat a 3/4 ton Chevrolet Suburban with a 454 V-8 and a 4:10 rear end that has a factory tow package. 1990 thru 1994 were good years. An overdrive automatic transmission will help save gas when you are not towing.........
Jim Jarzabek is offline   Reply With Quote
Old 02-10-2006, 09:15 AM   #4
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
We've got a Land Rover and I wouldn't even consider towing the Caravel with it. It's pretty sluggish by itself. I would think that with the added weight and drag of the frontal area that it would be a nightmare.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 02-10-2006, 10:19 AM   #5
Pschoerrn's Avatar
1971 29' Ambassador
Braunschweig , Germany
Sorry Paul,
but there must be something wrong with your Landrover... How old is it and which Model??
You know, what you say would mean that all the europeans and others (or better non-americans and non-canadians) risk their lifes everytime they tow such a light trailer like yours...
The Airstream weight list says that a 1967 Caravel has a Hitchweight of 300lbs and a Dryweight of 2450lbs, so every newer Landrover can handle this easily.
You are true, it is not a good idea to tow a 29 or 31 footer at american Highway speed with the Landrover, but a Caravel??
Sorry, I can´t see any problem there. Get a good swaycontrol and if you want even a weightdistributionhitch for the 300lbs, fix the car and everything should be ok.
Take c'air
Bjoern
Björn H. Adam
Wolfenbuettel, Germany
AirstreamForumsMember No. AIR 5535
Proud Owner of a 1971 Ambassador 29' called "Dave"
-A stranger is a friend you just haven´t met before!-
unknown irish
davetheairstream
Pschoerrn is offline   Reply With Quote
Old 02-10-2006, 11:31 AM   #6
1950 25' Cruiser
Lebanon , Ohio
Images: 16
European caravans are relatively light...
Sorry Bjoern,
But the Land Rover models in the U.S. have a well deserved reputation as a Yuppie status symbol.....
I will take the heat for my view on this; but prior to the introduction of the Ford Excursion and the Hummer, the Land Rover Discovery was the ride of choice for many an up and coming young suburbanite. But they always seem to be in the shop and repairs are expensive....
Most European caravans are in the 2000 pound range due to composite material construction and requirements limiting size and width due to the differences in road construction.....
You cannot begin to equate American and European recreational trailers as one weighs twice as much as the other...
The popular vintage airstream of choice for export to Europe are pre 1970 single axle bambis and caravels; the smaller width, length, and dry weight allow them to operate on the road with modifications to the axles, brakes, and electrical systems, etc......
Personally, I would never tow an airstream or any other travel trailer I wanted to keep that had a "dry weight" of 2500 pounds with a Land Rover Discovery as I once owned one.....
Actually, I owned it along with my mechanic because it was in the shop so often!
Old 02-10-2006, 12:20 PM   #7
1954 25' Cruiser
Paradise , Texas
Originally Posted by Pschoerrn
Sorry Paul,
Take c'air
Bjoern
There is nothing wrong with the vehicle, it is just underpowered. It's a 2000 model with 92,000 miles and it's always been underpowered. My wife is a real estate agent and she bought it for it's ablility to show rural properties. It's been great for that purpose but I wouldn't dare count on it to jump up and get with the flow of traffic.
Paul Mayeux
AirForums #1565
WBCCI #7162
Towing Experience app Tow Vehicles 9 04-19-2004 09:51 PM
Towing Mirrors 53flyingcloud Towing, Tow Vehicles & Hitches 8 01-03-2003 04:28 PM
Towing Regulations by State InsideOut Towing, Tow Vehicles & Hitches 2 09-16-2002 07:35 AM
Towing COArgosy78 1969 Overlander 5 09-05-2002 10:18 AM
Towing cars CBBOB Airstream Motorhome Forums 13 07-24-2002 08:15 PM
