Old 08-18-2008, 04:51 PM   #1
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Towing with a flathead
I have a 1941 Plymouth. It is a P12. 4 door. It has a flat head 6 and 3 on the tree. I replaced the engine with a Dodge flathead 6 out of a 1949 pickup. It looks the same but it is a bigger displacement = more horsepower and torque. I also put an electronic ignition in it. new ditributor ect. It has 3 - 1 barrel carter carbs. I also put a 10 bolt rear end in it out of a chevy camaro. Probably 3:08 gears. I always wanted to tow an airstream with this and I am not sure how big to go or how much weight it will tow. Any other street rodders out there doing something like this? Or any one else towed with old cars.
mustang is offline   Reply With Quote
Old 08-18-2008, 04:57 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
My 1969 F100 had 3.73 gears, and a 390 engine, also 3 on the column. Most trucks with the 6 cylinder engines had a shorter ratio rear end, like a 4.11. That would enable you to start out without slipping the clutch too much, and the 6 cylinder would be turning about 3000 rpm at 60. Not that you'd probably go that fast...
Old 08-18-2008, 05:02 PM   #3
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I am wondering how much the old X frame can handle also. I thought about bumoping the gears or swapping the tranny out with a T-5 model.An S10 with a 4 cyl had a close ratio and lower 1st gear
Old 08-18-2008, 05:08 PM   #4
Well Preserved
1993 21' Sovereign
The old Muncie 4 speeds had a very low first gear as well. What kind of bell housing do you have on your flathead? If you didn't mind putting access to the shifter in the transmission cover, you could probably put in a floor shifter and a 4 speed. Doing that, you'd be able to start out easier, and you'd still have 1:1 in 4th.
Old 08-18-2008, 06:10 PM   #5
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
There is a plate made for the t- 5 tranny swap. I would use the stock bell housing. The sgifter is mounted forward on the s 10 as apposed to the mustang or camaro mounted rearword. there fore I would have the shifter coming threw the floor under the seat. I was also wondering about a old military tranny. they used flatheads into the late 60s in millitary stuff
Old 08-18-2008, 09:04 PM   #6
bobkelly's Avatar
2003 22' International CCD
Whittier, California , Depoe Bay, Oregon
While on vacation recently, we saw a group of campers using 1940's decade of Fords, Chevys and Plymouths. They were styling and looking great. Sounds like your primary objective. They kept the trailers small and often painted to harmonize with the car. Tear drops to 15 footers were typical.
Have fun and show us some pictures when you are done. Be sure to contact Safari57 as he runs with old time hot rods and trailers.
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Old 08-18-2008, 09:22 PM   #7
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Military trans are big and heavy.
Having said that the M37/M43 series are 3/4 Dodges may work out for you. Try Antelope Truck and Equipment if you need some questions answered. I restore old Military vehicles for a hobby and those guys are my main supplier. Norm knows about all there is to know.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 08-18-2008, 10:30 PM   #8
1975 27' Overlander
High River , Alberta
If you provide some data about the car, I could readily give you a sense of the performance.
Weight, tire size, transmission gear ratios, and the power and torque ratings of the engine would be useful.
AlbertF is offline   Reply With Quote
Old 08-21-2008, 08:13 AM   #9
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Data is limited short of putting it on a dyno, back then they diidnt have much DATA
Old 08-21-2008, 09:10 AM   #10
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Mustang, are you going to use your '41 to pull the 31 foot Sovereign? Any 6 cylinder engine sounds really inadequate for that job, but what do I know?
I just used my in-law's V6 Trailblazer to tow our puny GlobeTrotter around for a few hours, and it was sure working hard getting up the overpasses. Woefully underpowered for a permanent solution, but luckily for us it's not.
bredlo is offline   Reply With Quote
Old 08-21-2008, 10:30 AM   #11
1975 27' Overlander
Assuming a peak torque output of about 150 lbs ft at 2200 rpm, I'd keep trailer weight to a maximum of about 2500 to 3000 lbs, and not count on towing faster than 50 mph. Performance will be very sensitive weight. Startabiliy (clutch slip) may be a concern with anything over about 2000 lbs. And I'm assuming a final drive ratio of at least 4:1. The 3.08 rear will make towing performance very sluggish.
It would be very interesting though.
My two cents worth.
Old 08-21-2008, 10:46 AM   #12
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Hey, my husband keeps telling me he can pull our Argosy with his Flathead V8. I don't believe it. I feel certain it would not pull the 31' Sovereign.
Judy At Home in Oklahoma
juel is offline   Reply With Quote
Old 08-21-2008, 10:50 AM   #13
bredlo's Avatar
1954 22' Safari
Love that one, Juel. If you ever find you need to repaint the Argosy, match it to that pickup. They look great together!
Old 08-21-2008, 11:52 AM   #14
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
I wasnt going to pull my 31 footer with it, but I always wanted to find a smaller one and maybe throw some green flames on it. I have the picture on my profile but dont know how to post it to the thread. I figured a 20 footer max preferablty an old Bambi or small Globe Trotter
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
Help with Towing CAAR Hitches, Couplers & Balls 3 07-18-2006 02:42 AM
Towing perfuse2004 Tow Vehicles 5 10-01-2004 04:51 PM
towing with out brakes? mary ellen Brakes & Brake Controllers 4 03-14-2003 10:16 AM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
