Old 09-01-2015, 09:04 AM   #15
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
4:11 gears would be better.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-01-2015, 09:05 AM   #16
m.hony's Avatar
2013 30' Classic
All that carpeting is weight- subtract from payload-
TAC #MS-10
Airforums #70955
Old 09-02-2015, 12:04 PM   #17
Wolf Alaska's Avatar
Madison , Alabama
Rich. that 3.42 diff ratio is more toward fuel economy. As a van, it is OK. As a TV, you won't run in OD much...only downhill & I would not run in OD downhill with my trailer behind. So, NO OD when towing.
Also, 6875 is not much for towing with a 33' trailer. You need to get your numbers together & be sure it is reasonable. That goes for your Dodge, too.
My E250 has 3.73 & 7400 lb tow rating.My Excursion has 11,000 lb tow rating.
Wolf Alaska
M.S./CFI/IR/ME/CP
FMCA SKP GS GPAA NRA USN (Ret)
Wolf Alaska is offline   Reply With Quote
Old 09-02-2015, 12:27 PM   #18
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
If there is an owners manual, read it regarding towing. My half ton Chevy van said no OD when towing. On my GMC it says okay. Primarily due to that model tranny being a heavy duty unit. It is possible that with a diesel you might have a different tranny than if you were gas powered. Rear axle ratio does affect towing capacity. If I had taken the standard axle with my 6 liter gas engine on my current van, I would have lost about 1,500 lbs. in towing capacity. Gas mileage is only one of the components affected by axle ratio.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-02-2015, 12:28 PM   #19
Boone , North Carolina
Thanks. I routinely pull a way-overbuilt gooseneck loaded with 200 cut christmas trees, so I know my truck will be fine ...just not near as comfortable as the van. It's tagged for 25,000. I'm sure pulling something that big on the bumper is going to be a whole new experience.
rich minford is offline   Reply With Quote
Old 09-02-2015, 04:20 PM   #20
ericpeltier's Avatar
Superior , Colorado
I have a 1973 33' Streamline. I don't have a weight on it (pointless to weigh, because it's gutted), but I do know that these vintage trailers weighed less per foot than the newer trailers. (Streamlines were also extra light, with aluminum interior parts.)
ericpeltier is offline   Reply With Quote
Mercedes Van Executive Van Airstream Interstate eBay Watch Airstreams on eBay 0 05-14-2012 05:30 AM
2012 airstream avenue class b van generator and a/c 190 camper van fully loaded eBay Watch Airstreams on eBay 0 05-01-2012 11:00 AM
2012 airstream avenue class b van generator and a/c 190 camper van fully loaded eBay Watch Airstreams on eBay 0 04-19-2012 08:40 PM
2012 airstream avenue class b van generator and a/c 190 camper van fully loaded eBay Watch Airstreams on eBay 0 04-09-2012 05:40 AM
2012 airstream avenue class b van generator and a/c 190 camper van fully loaded eBay Watch Airstreams on eBay 0 03-29-2012 05:00 PM
