Old 11-09-2003, 10:20 AM   #1
Beatrice's Avatar
Smile Towing with a 3/4 Suburban?
Hi everyone,
My fiance and I are going to hit the road in our 73 Argosy 26-footer. We have a 3/4 ton 88 Suburban, and are trying to figure out the best hitch, sway bar, brake systems. We would appreciate any words of wisdom--we would like to err on the side of caution!
This looks like a great forum!
Beatrice
Beatrice is offline   Reply With Quote
Old 11-09-2003, 10:37 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Welcome to the forum!
There has been much discussion on the brake controllers.
The Prodigy seems to get the highest marks. Seach on brake controllers and you will find a bunch of threads.
You will need a WD (Weight distrubiting) hitch. There are many brands. With a 26 footer and a 3/4 ton suburban a standard Reese WD hitch would work.
Sway control can be a function of the hitch or you can go to a friction type. With the size trailer you have I would think that the integrated type would be fine and one less thing to worry about.
This would be a Reese WD with the Dual cam sway control.
dual cam sway control
WD base hitch assembly
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 11-09-2003, 11:29 AM   #3
Another control that's been enjoyed by it's users is Jordan brake controller.
John is offline   Reply With Quote
Old 11-09-2003, 04:28 PM   #4
1986 32' Excella
1993 36' Classic 36
Huger , South Carolina
I'm not to sure if you have gotten all the info that you needed on hitches. But if not here you go....I use a hitch called Equailzer manufactured by Lindon Hitches. It does both jobs of WD and sway control in one unit. It uses the friction from the bars on saddles to control sway...so there is no need for additional sway devices. I have been using this hitch setup for almost 10 years now with no troubles.
mtlagger is offline   Reply With Quote
Old 11-10-2003, 07:16 AM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Towing with a 3/4 ton Suburban?
Greetings Beatrice!
Welcome to the Forums and the world of Vintage Airstream/Argosy ownership!
I have towed my '64 Overlander all over the country with my '99 GMC K2500 Suburban, and am confident that you will like your combination of 26' Argosy/C-K 2500 Suburban (my Suburban currently has nearly 119,000 miles over half of which have been towing either the Overlander or Minuet). I suspect that the loaded weight of you Argosy will likely approach 6,000 pounds as my '26 Airstream Overlander when loaded is within close proximity to that weight with a tongue weight of about 725 to 750 pounds depending upon how the coach is loaded.
I have utilized the Reese Straight-Line hitch (it includes the Dual Cam Sway Control System) with 800 pound weight distribution bars since 1995. While there are many similar systems produced by other manufacturers, I have been very well satified with this arrangment. The one thing to keep in mind if you choose to go with the Reese Dual Cam system is that it is sensitive to having weight distribution bars that are very close in rating to the actual tongue weight of the trailer - - I have found this especially true when towing with my K2500 Suburban.
I currently use a Tekonsha Voyager Brake Controller on the Suburban, but would probably switch to the Prodigy if I were reconfiguring the system today. On my Cadillac, I utilize the same hitch system, but utilize a Hayes-Lemmerz MicroControl HD Plus controller with remote control - - I am very satisfied with this inertia type controller, but it is not a widely respected controller as is the Prodigy.
You can find more information about brake controllers from:
Tekonsha Brake Controllers
Good luck with your Argosy/Suburban combination!
Kevin
Kevin D. Allen
AIR #827
Old 12-01-2003, 06:05 PM   #6
Beatrice's Avatar
Smile Thank you!
Thanks so much for your great responses. This is a really big help to us!
What a great forum,
Beatrice
Old 12-01-2003, 06:16 PM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I have used Reese hitches in the past, this time around I decided to try the Equalizer www.equalizerhitch.com I have very pleased with the performance of it. I also use the Prodigy. You would be hard pressed to get me to use anything else. It was a major improvement over all the others I have had over the years.
Aaron
Another towing question ipso_facto Our Community 34 08-28-2010 03:47 PM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 08:05 AM
Suburban or Van with a 350 or 454...which do you prefer? texasphilter On The Road... 12 04-06-2004 03:05 PM
Info Request from Suburban Owners MileHigh On The Road... 32 01-28-2004 06:16 PM
Airbags and Towing with Car mcostanzo Tow Vehicles 0 07-02-2003 02:40 PM
