Old 07-05-2010, 12:14 PM   #1
2008 20' Safari
murphys , California
Cool Towing with a 1/2 ton
I'm considering purchasing a Sport 22 FB with a GVWR of 4500 lbs. I own a 2003 chevrolet 1500 extended cab four wheel dirve with a 4.10 rear axle ratio, a heavy duty trailering equipment package and a 5300 V8. The truck has a 6400 GVWR. Will my truck be able to tow this trailer without to much trouble?
murphys is offline   Reply With Quote
Old 07-05-2010, 12:25 PM   #2
r carl's Avatar
Lin , Ne
It will be a piece of cake.
Old 07-05-2010, 01:26 PM   #3
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
No worries. Go for it!
Craig and Carol
1997 34' Excella 1000
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Aviator is offline   Reply With Quote
Old 07-05-2010, 01:27 PM   #4
bobandcarla's Avatar
2005 25' Classic
Pelham , New Hampshire
I tow a 25' with a 1/2 ton Chevy 1500 and have been to FL. many times so it should be no problem. I think the only trouble I would have is if I went out west with the long hill climbs.
Bob & Carla
05 classic 25'
WBCCI # 1836
bobandcarla is offline   Reply With Quote
Old 07-05-2010, 06:00 PM   #5
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
I tow my 29' and have no problems. If I hit hills, I slow down.
Annette
AirHeadsRus is offline   Reply With Quote
Old 07-05-2010, 06:17 PM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
You should be fine towing. Check your owners manual on the truck and verify whether you can tow in OD or need to stay in 3rd. the 2500 series trucks with the 4.10 axle can tow in OD as long as tranny isn't hunting back and forth. The 1500's might be a smaller tranny which won't hold up with OD towing.
Bottom line check the manual, don't rely on opinions on this one.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 07-05-2010, 06:29 PM   #7
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
No problem towing, 05 Burb 1500 with a 25' Sovereign. Crossed over the Smokies this Spring, almost a piece of cake. Slow and easy she goes.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 07-05-2010, 08:09 PM   #8
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
1/2 Ton Towing
No problem. We use a 2009 Chevy 1/2 ton 4X4 with the same engine to pull our renovated/updated 65 Safari. I used to use a 3/4 ton and find the 1/2 ton rides and pulls smoother. The suspension on the 3/4 ton was too stiff.....Tim
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 07-05-2010, 08:20 PM   #9
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
That's the ideal tow vehicle for an Airstream. It should pull like a dream behind your truck.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 07-05-2010, 08:23 PM   #10
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
We tow our '83 Excella 27' with our 1999 Silverado 1500 with the 5.3. The owner's manual says to tow in OD. You may need to take it easy on the long hills, but should be OK
We get from 12.5 to 15 mpg depending on the terrain. We do keep the speed down to 55 to 58 mph.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 07-09-2010, 05:26 PM   #11
JFScheck's Avatar
2020 30' Classic
Derwood , Maryland
Images: 37
Been towing my 25fb around but minus my usual Rockies and other large mountains - at 65 mph average speed I'm getting 16.5 - 16.8 mpg.
LOVE me some diesel
Don't know why the US trucks in the 150/1500 class don't have one as an option....
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 07-16-2010, 05:59 PM   #12
Journalist's Avatar
1969 25' Tradewind
LOVE me some diesel
Chevy did build half-ton diesels up through '97. They also had a smaller DuraMax intended for the lighter duty pickups and the Hummer H2 slated for production up until the economy nearly wiped out GM last year. Still no word if it will ever see production now. I'm a big fan of diesels myself. My 8,200 pound crew cab dually with a 4.10 rear end gets 19 on the highway and around 15 towing.
AIR #8891
Old 07-21-2010, 11:57 AM   #13
JFScheck's Avatar
2020 30' Classic
Derwood , Maryland
Images: 37
H2 Diesel - I would have been all over that! Fingers crossed they can get a nice diesel the 1500 since the interior seems to be a bit nicer than the HD class (or put it in a "Burb")...
**I Love U.S.A.**
Old 07-21-2010, 01:16 PM   #14
Road Ruler's Avatar
St. Catharines , South Western Ontario
Images: 38
Isn't it amazing that people want a right sized diesel for a basic pick up and yet in NA it is not available.
When will the NA vehicle manufacturers start building what folks want??? Not what they think they need or what brings them the largest profits!
Road Ruler is offline   Reply With Quote
Old 07-21-2010, 03:08 PM   #15
RaleighAir's Avatar
1973 31' Sovereign
raleigh , North Carolina
I pull a 31' w 07 suburban, no problem at all.
RaleighAir is offline   Reply With Quote
1/2 ton
Upgrading to optimize a 1/2 ton Van for better towing- advice needed Tony S Tow Vehicles 7 04-25-2010 08:27 PM
towing a 31ft 1970 sovereign with a 1994 one ton dodge Beverly II Tow Vehicles 7 04-19-2010 09:38 PM
towing with 1/2 ton 07 silverado ext cab Barry Parkof Tow Vehicles 6 02-28-2009 10:42 AM
1/2 ton vs 3/4 ton towing? subfan1 Tow Vehicles 7 12-13-2007 03:10 PM
Who's towing with a 1/2 ton? wildwoodrver Tow Vehicles 50 11-29-2004 07:05 PM
