Old 07-21-2008, 12:24 PM   #1
ridgerunner
ridgerunner's Avatar
Profile:  1966 26' Overlander
Lincoln , Arkansas
Towing vehicle HEEELP
We have a 67 Overlander. My husband left Arkansas in our 2002 4.3 liter vortec v-6 Chevy Blazer to go to our place in Colorado to pick up the Airstream. We are now getting feed back that the trailer will be too heavy for the truck. We recently purchased this truck to get a more reliable tow vehicle. Did we make a mistake? (BTW our old truck has 265K miles on it, we thought it was best to get something newer)
Let me know what yopu think.
Carol
ridgerunner is offline   Reply With Quote
Old 07-21-2008, 12:45 PM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  Bay Area , California
A Blazer really has too short a wheelbase to be a capable tow vehicle for a large trailer. The trailer will end up forcing the Blazer around on the road, and make for a very uncomfortable situation at best. The 4.3, while a good engine, is not really powerful enough to be able to drag a heavy trailer around. We towed a 20' 3000+ pound Argosy with a 4.0 liter Ranger, and you needed an hourglass to measure acceleration times. Your Overlander is easily 1000 pounds heavier than the trailer we towed. We had a 2500 series Chevrolet van with a 5.7 to tow our Overlander, and many times I wished we had more muscle under the hood.
overlander63 is online now   Reply With Quote
Old 07-21-2008, 01:53 PM   #3
RBolton
RBolton's Avatar
Profile:  Belington , West Virginia
I agree, The Blazer is probably not enough truck. Do you know the weight of your trailer? You didn't say what your old tow vehicle was. How did it compare to the Blazer?
Roger
RBolton is online now   Reply With Quote
Old 07-21-2008, 04:06 PM   #4
AlbertF
Profile:  1975 27' Overlander
In the Kootenays , BC
Actually, I think the 4.3 would be OK from a power standpoint, because an empty '67 Overlander would only weight about 4200 lbs. Tow rating is likely to be over 5000 lbs, which looks impressive. The real problem, as has already been noted, would be stability and handling.
I'm assuming it's one of the last of the old small Blazers - 4wd with a solid rear axle. It has a short wheelbase, a narrow track, a high centre of gravity and soft, unstable tires.
You didn't say whether it's a 2 door (100" wheelbase) or 4 door (107" wheelbase). Rear track, however, is only 55" - narrower than a Honda Civic or Toyota Corolla. For a tow vehicle, the specifications can't get much worse. Any old half-ton pickup with good tires and brakes would be a better choice, I'm afraid.
If you are committed to using the Blazer, look at getting narrower, stiffer tires (perhaps light truck (LT) tires), and possibly a Hensley (or other "pivot point projection") hitch.
AlbertF is online now   Reply With Quote
Old 07-21-2008, 04:23 PM   #5
Road Ruler
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Images: 41
For sure. I believe the Hensley promo video shows one of these Blazers towing a 27'ish Airstream. It was Hensley equipped.
Road Ruler is online now   Reply With Quote
Old 07-21-2008, 04:59 PM   #6
ridgerunner
Lincoln , Arkansas
Thanks for the input. To answer some questions our other towing vehicles are a 94 Chev pu with a 350 and 265K miles and a 88 Chevy Suburban with a 454 and only about 20K on the new engine.BUT the sub is on its 5th engine, it has been a maintenance nightmare. (She pulls likle a dream when she is running though)
The Blazer is a 4door 2wheel drive with a reese receiver hitch.
I have done most of my trailer pulling with a horses trailer, not much rv-ing. It will be fun to pull a load that doesn't walk around : ).
Carol
Old 07-21-2008, 05:08 PM   #7
Alumatube
Alumatube's Avatar
Profile:  Jefferson , Arkansas
Not having the horsey load shift will make you very happy. It is a little disconcerting to have your trailer suddenly move your truck around on a straight, flat road (not to mention other types of roads!)...!
Susan
"Despite the cost of living, have you noticed how popular it remains?"
1984 310 Limited Motor Home "The Rockin' A"
1974 31' Excella (soon-to-be carhauler)
Alumatube is offline   Reply With Quote
Old 07-21-2008, 06:50 PM   #8
trevisgardne
trevisgardne's Avatar
Profile:  1973 31' Sovereign
Maryville , Tennessee
I have towed a 73 31ft Sovereign (approx 7000#) with a 4.3 Chevy Astro. I went no faster than 50. I only went about 75 miles. I was nevous. I had no problems.
I would avoid ever doing it again.
TGardner
trevisgardne is offline   Reply With Quote
Old 07-22-2008, 11:54 AM   #9
AlbertF
Two wheel drive is a plus in this case - a lower centre of gravity will help.
Old 07-22-2008, 12:02 PM   #10
overlander63
Rivet Masher
And the reduced weight of not having the transfer case and live front axle will help with towing capacity, as it will weigh less (there's more weight left for the trailer). Depending on what the issues are with the Suburban, I would be inclined to roll the dice with it. If an engine blows, you coast off the road and call a towtruck. If you are in the Blazer, and the trailer starts swaying around, all the towtrucks in the world won't help you until you come to rest.
Old 07-22-2008, 12:10 PM   #11
till
till's Avatar
Profile:  1967 26' Overlander
1968 26' Overlander
Lisle , Illinois
Images: 108
I have to say these guys are right on. I tow my Overlander around with a '91 Caprice wagon now. The wheel base and track are about as small as I want to be. If you have a Sub, I would put my money into bringing it back to life and up to snuff.
One day I would like to tow with a Suburban.....
Tedd Ill
AIR#3788, WBCCI#4028 Membership discontinued
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 07-22-2008, 12:22 PM   #12
ebair
Roadtrain O--O~(--ooo--)
ebair's Avatar
Profile:  2000 34' Limited
1979 31' Excella 500
Miamisburg , Ohio
Years ago when we started towing, we had a jeep cherokee for a TV, it we pulled our 25 ft Holiday rambler to Yellowstone and through Utah and Colorado on US40. It wasn't ideal for the job, but we didn't get in a hurry (50mph max) and were careful to keep the brakes cool on the downgrades (35mph) After we traded the Holiday for a 31ft Excella and took a trip to the Grand Canyon (we called that combination the TermiteQueen) we knew we needed to get a bigger TV to increase the safety factor.
Not an ideal setup, but CO to Ark is all downhill, right? Make sure the trailer brake system is in tiptop shape and put some ballast in the TV. Dump all the water from the tanks in the AS and keep it slow and steady
'00 34' Classic Limited (Beauty)
'06 2500HD, 4x4 LBZ chip D/A CC LB (Beast)
AIR #12881
ebair is offline   Reply With Quote
Old 07-22-2008, 01:32 PM   #13
ridgerunner
Lincoln , Arkansas
Thanks for all of the input. The trailer is as empty as it can get. ( i want to leave the fixtures : ) ) There is no hurry getting here so I think it will be ok. Before we leave on our vacation trip we will reassess the Suburban issue.
The Sub (Large Marge as we call her) is a dream to drive. 9 mpg with or without a loaded trailer. I have hauled a stock trailer full of horses and actually forgotten its back there, Marge don't mind!
Carol
Old 07-26-2008, 09:24 PM   #14
ridgerunner
Lincoln , Arkansas
We have decided that Keith will tow the empty trailer here to Arkansas from Colorado with the Blazer and then we will switch to the Suburban for the family trip. We had the air conditioner fixed in the Burb which was a major concern for traveling in August!
Thanks again for the help. I can't wait to be 'streamin down the highway.
Carol
Towing With an Undersized Vehicle Alumatube Tow Vehicles 22 03-31-2008 11:04 AM
Best towing vehicle wayneh Off Topic Forum 23 05-19-2006 06:58 PM
Towing Vehicle Advice BeachBum2B Tow Vehicles 1 07-22-2004 04:46 PM
Possible towing vehicle? darin Tow Vehicles 6 01-27-2004 05:01 AM
Towing Vehicle SurgiMed Tow Vehicles 6 11-20-2003 07:14 PM
