Old 07-03-2015, 12:20 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Towing: Short vs. long bed?
All other things being equal, would a long bed pick up be any more stabile than a short bed for towing?
Old 07-03-2015, 12:31 PM   #2
Gainesville , Florida
I have a short bed and think as far as towing goes a long bed would be better. Now in a campground or parking I prefer the short bed. I bought used and I would buy a long bed if one were available at the time, so I bought the next best. Longer wheelbase is the key.
Old 07-03-2015, 12:38 PM   #3
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
We have a 6'6" bed on our Ford F350 Crew Cab, would not want a bed any longer which would be 8'. Too long for grocery stores, camping ie backing up. etc. We have plenty of stability.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 07-03-2015, 12:46 PM   #4
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
I am also glad I did not get the 8foot bed with our F250 for the reasons mentioned above
urnmor is online now   Reply With Quote
Old 07-03-2015, 01:14 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
A long bed does afford a bit more capacity for backing. Think of it this way: The distance between the hitch ball and the middle of the back axle of the truck determines how much "swing" the truck will provide as you turn the steering wheel while backing. The larger that distance is, the more swing you get.
By the same token, by the way, the near complete lack of distance between the middle of the axle on the truck and the hitch head on a fifth wheel is what makes those things rather challenging to park. You turn the steering wheel to get some swing, and ... nothing happens, at least right away.
By yet again the same token, that same distance is what also makes very short trailers -- especially rigs like pop-ups -- rather challenging to park. You turn the steering wheel to get some swing, and the thing swings waaaay too fast!
Oh, how do I know about this stuff? Through no fault or plan of my own, I wind up backing in about half of the rigs that come into the park. In the end, though, it's turned out to be enlightened self interest: When I back rigs into sites for the guests, I don't hit electric posts, barriers, faucets, people, or anything else. (If I did, my wife would just kill me.)
Lynn
WBCCI 21043
Old 07-03-2015, 01:19 PM   #6
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
8 ft box
I will not go back to a little box.I drive a 2015 F350 Supercrew 4x4 8ft box single rear wheel everyday.This is my second one,previously had four F150 Supercrews with the little box and a supercharged Ford Lightning Regular cab swb..
I have no trouble with parking or maneuvering and the long wheelbase is a plus when towing (more stable).
Nice to have a truck that you can put things in without dropping the tailgate.For me a 8ft box is the only way to go.They ride smoother loaded and unloaded due to the longer wheelbase(my wheelbase is 176 inches).
Old 07-03-2015, 01:30 PM   #7
2016 30' International
Scottsdale , Arizona
The 6'6" bed, with a full crew cab, seems to me a good compromise. I wouldn't want a shorter one, nor the 8'. So for us, we went with the Sierra Denali HD Duramax/Allison with crew cab and 6'6" bed.
DHart is offline   Reply With Quote
Old 07-03-2015, 01:46 PM   #8
JimGolden's Avatar
1977 31' Excella 500
To answer your orignal question...
Yes. All else being equal, the longer the wheelbase, the more stable the towing platform. So for two identical trucks, the long bed version will be more stable than the short bed.
If you want to look at physics, you have a longer "Moment Arm" from the back wheels to the front wheels. The trailer is attached to the hitch and it will try to turn the truck. The longer that Moment Arm, the less effect the trailer will have on the side to side on the truck.
This being said, if you have an extended cab truck with a short bed, it is probably fine, as it's just as long a regular cab truck with a long bed.
I tow a 36' Avion with a Dodge 2500 4-door long bed. It works great.
Oh, one other thing to mention, at least with the 2500 Dodges....what I found with a 4-door shortbed was that every time I ran over a shadow on the road, I felt the bump. The extra 18" of wheelbase in the long bed made a huge difference in ride quality. Much moreso than I would have thought. They're sprung pretty heavily though.
If you decide to use a Chevy Citation instead, make sure you really crank in the weight distribution before you take the back wheels off
(it's actually been done, Citation pulled the Airstream with the back end completely off the ground....)
- Jim
JimGolden is offline   Reply With Quote
Old 07-03-2015, 02:04 PM   #9
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Over 130" WB becomes meaningless. The curve flattens out at that point. It just makes maneuvering more difficult.
Same for TV weight above 4000#. Up to that is stability increased. After that isn't helpful. Rollover tendencies heighten and worse braking distances.
Yet again, as with tongue weight. Up to 15% is helpful. After that the curve flattens. Places more burden on the tow vehicle without corresponding benefit.
Using these numbers as givens for maximum size, it is sophistication that then edges aside mass in the better tow vehicles.
Old 07-04-2015, 10:17 AM   #10
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Generally speaking the long box will give you a better ride. As far as the F250 and 350 you will need an 8' box to get the larger fuel tank. The 6.5 box will also give you a nice ride but with a smaller fuel tank.
TinCan
graysailor is offline   Reply With Quote
Old 07-04-2015, 10:49 AM   #11
SKP46015's Avatar
All other things being equal... I prefer the long 8" foot box. Yes... parking in the city is harder and sometimes you have to park further out... but for all the other reasons cited above... towing stabilty, ease of backing... ride comfort...storage space under the cap... etc... I would never have a short box
Ed
94 30 Ft. Front Kitchen Excella
99 GMC 2500 6.0L Ext.Cab. 8ft Bed
ARE Shell Topper
SKP46015 is offline   Reply With Quote
Old 07-04-2015, 11:04 AM   #12
2015 30' Classic
Hollandale , Wisconsin
long or short box
When we ordered our 2015 Classic, we decided to get a new truck. My husband is a mechanic and he was very determined to have the long box so his tool box could still be in the bed. We also pull a 5th wheel horse trailer and that takes up space in the box also. We started looking for a crew cab, 250, with a long box. It was not easy to find one. We ended up driving around and looking at the few we found. We finally found one like he wanted and we are so happy with it. He even modified the 5th wheel ball to carry a bike rack in the box. We love it and it pulls and ride beautifully!
bjmiess is offline   Reply With Quote
Old 07-04-2015, 11:19 AM   #13
2011 30' Flying Cloud
Arvada , Colorado
We own a Silverado crew cab with a standard bed. I would not want to have a long bed because this truck can be a challenge when parking, etc.
Jack46 is offline   Reply With Quote
Old 07-04-2015, 11:23 AM   #14
San Leandro , California
I moved from a short bed Dodge Ram to a long bed F350 dually for a large cabover camper. The Ram I thought was perfect for towing the AS. Until I towed with the F350. The ride is smoother with the long wheel base and I haven't noticed any problems backing. I'm sure that will come and I'll deal with when I have to. Once in a while I have problems in tight parking lots, but most of the time a long bed isn't an issue. I can park a little farther out if needed. I use this truck as a daily driver and would never go back to a short bed because of the ride alone.
bhales is offline   Reply With Quote
2013 2500 Ram: Short bed vs Long bed? Zigidachs Towing, Tow Vehicles & Hitches 26 04-25-2013 04:24 PM
F-250 Long or Short Bed takeachance Tow Vehicles 29 07-22-2007 07:25 PM
The Short, Short Trailer - Spamboree flamingo-kid1 On The Road... 2 04-14-2005 01:41 PM
long bed vs short bed towing 8400 lbs. longears Tow Vehicles 24 08-09-2004 03:32 PM
