Old 09-17-2010, 11:08 PM   #1
Wayward's Avatar
Cary , North Carolina
Towing Report. 2011 F250, 6.2L gas, 6spd TorqShift
Heres a (rather long) report our new tow vehicle. It is a 2011 F250 2WD with the new Ford engine/tranny combination: 6.2L gas engine coupled to the 6-speed TorqShift automatic. I admit to buying this truck after researching and shopping for a manual diesel but bought it on the spot primarily because of a really great deal. So, what Ive learned about it has come mostly on this initial trip.
Ive not had a late model truck in a while, so some of the power and features I think are novel on this truck, may be old news to some readers here. My previous heavy duty TV was a clunky Chevy diesel automatic and, the truck we mostly use to tow the Airstream is an 11 year old 4.2L F250 manual.
After a break in of about 500 miles, Ive put another 3500 miles on it - about 2500 miles towing the 25 Safari. First part of the trip was on flat, east coast Interstate. The majority of the trip was returning through the Appalachians, a little interstate but mostly highways and back roads. The truck makes for an effortless tow that is stable and nimble in all conditions.
Power: My initial impression breaking in the truck was that it had a good, fairly flat torque curve that needs to wind up a bit. That was indeed the case towing. It accelerates well from a stop with a trailer. The 3.97 first gear gives it good usable power at low speeds. But the engine really kicks in at about 2000 rpm and it keeps pulling strong over 5000 rpm where it is time to shift. While towing, I had absolutely no problem accelerating to any speed needed in any situation: at high speeds, on flat roads, and in the mountains both interstate and steep backroad inclines. It is no 6.7L diesel, but the 6.2L provides more than enough usable power with the 25 Safari in tow. Mine has 3.73 gears. Id say 4.10 gears are not necessary, but probably a good option for a heavier trailer. I suspect the transmission and its tow/haul computer programming has a lot to do with my sense of the trucks towing power, so lots more on that..
Transmission: I far prefer a manual to an automatic for towing and left the dealer convinced the automatic was a compromise Id made to get a great deal on the truck. Im now convinced otherwise.
First, a bit about the 6R140 shift modes. In addition to the usual Tow/Haul button at the tip of the column mounted shifter, there is also thumb operated up/down rocker switch.
Tap the rocker switch while in Drive, and a gear indicator pops up on the dash and puts the transmission in what I call NHT mode (No Higher Than). The first tap just turns on the numeric gear display. Below it is in Drive, 6th gear.
Once in NHT mode, pressing the rocker switch down (-) limits the top gear. In the picture below the truck is in first gear but will shift no higher than 4th.
Putting the shifter lever into Manual lets you use the +/- rocker switch to shift up and down through the gears like a manual. The torque converter locks up in each gear, so the truck feels like a true manual tranny.
I tried the NHT and Manual modes and they work very well. However for this trip with the Airstream, I simply kept it in Drive with Tow/Haul on. Id hit the rocker switch only to turn on the gear indicator (as in the first indicator picture) so I could see what gear the tranny was choosing.
I have agree that that Ford designed this automatic transmission and integrated it with the engine and transmission controller software, specifically for towing. The integrated brake controller works flawlessly. I set the gain at 9.0. The truck lets you save multiple settings in case you tow different trailers. First and reverse gears are a comfortably high ratio. Here are the 6R140 Gear Ratios (note two overdives):
First - 3.97:1
Second - 2.32:1
Third - 1.52:1
Fourth - 1.15:1
Fifth - 0.86:1
Sixth - 0.67:1
The 6 speeds are well spaced. Without a load it acts like most modern automatics although it does seem a bit eager to get into 6th - maybe for mileage/emissions reasons. It will however downshift to 5th or 4th smoothly when accelerating at highway speeds.
With the trailer plugged in and the tranny set for Tow/Haul mode, it is a whole different machine. In all situations, it found the same gear Id have slapped around for with a manual transmission, and usually sooner . Of course it cannot anticipate a hill or steep descent, but with the trailer plugged (and in tow/haul) the transmission reacts immediately to the amount of throttle or brake given. In tow/haul, it seems to adjust its downshift/upshift behavior based not just on speed, throttle position, and presence of a trailer, but also by sensing if the truck is pointed uphill or downhill. For example, hitting an incline at highway speed, just a small amount of throttle drops it quickly to 5th. A bit more throttle as the truck begins to slow and it drops without protest to 4th. And so on. It has no qualms about downshifting and revving upwards of 5k if that is what you right foot is telling it. I found no need to floor it to get a downshift just give it the amount of throttle needed and it finds a good gear. Even when towing with the cruise control, if the truck slows rapidly, it downshifts and accelerates accordingly.
This was all most noticeable and useful in Tow/Haul mode during downhill mountain towing, where a manual transmission really comes in handy for engine braking. On the first downhill interstate mountain grade where the rig started accelerating at highway speed with no throttle or brake applied, the transmission stayed in 6th. With very light pressure on the brake, the transmission downshifted to 5th so no additional brake pressure was needed. On long grades where the rig kept accelerating, a bit more brake pressure resulted in another downshift to 4th. The engine braking was strong enough that Id have to say the torque converter stayed locked on the downshifts. Very little braking is needed. Because the rig seems to know when it is going downhill, the left pedal feels as much like a down shift control as it does a brake pedal. Hats off to the Ford engineers on this one. I have to admit, it downshifted on downhill grades pretty much as I would have with a stick shift, with no attention needed on my part. It gives maximum engine braking using nothing but the brake pedal. No worries about missing that one downshift and having to ride the brakes to get it back.
We found our way over to a short but steep 2 lane white knuckle descent. It has 6 or 7 hairpin switchbacks that get increasingly tighter on the way down. I used a lot of brake entering at the top in 6th, Drive, Tow/Haul set, at about 45mph. The truck immediately downshifted to 4th and I was able to ease off on the brakes. More brake pressure as the turns got tighter resulted in more downshifting. When we exited at the bottom, calm and collected, with just minimum brake pedal pressure, the transmission had found its way to first gear, the engine howling sweetly at about 5000 rpm. I was impressed. The engine/tranny/controller combination makes mountain towing a breeze.
During the entire trip with typical summer weather, I never saw the transmission temperature gauge budge. We spent some time on gravel mountain roads and found the electronic locking differential an improvement over the LSD. It disengages automatically if you forget to turn it off after hitting the pavement (so they tell me ).
Fuel Mileage: We set out on the trip right after break-in. I kept track of gas mileage most of the trip and for a few tanks since we got back, but did nothing to optimize mileage. I drive to keep up with traffic especially in the mountains, so folks may report better mileage than I got. There are 2 trip meters so I was able to check overall and individual runs. I used the trip meters and actual gallons of Regular gas pumped, usually around tank.. The on-board fuel mileage reading turned out not very accurate but I was not very careful about resetting it.
Best unloaded mileage during careful break-in was 16.2 mpg. Best since returning was 16.8 mostly highway. Best unloaded city/highway commuting was right at 14mpg, worst 11.2. The first run towing the 25 Safari was flat interstate at a steady 75mph which returned 10.8mpg. Another relatively flat interstate run at 60 mph was 12.2 mpg. Most of the trip was towing in the mountains, 50-60mph highway and 45mph rural roads. The motor was a pleasure to drive aggressively in these conditions and I got varied mileage between 10 and 12 mpg. These are reasonable towing numbers for a gas automatic, and are better than what my f150 4.2L manual gives, so I am not complaining.
Ive run 4 or 5 tanks of E85 ethanol fuel and cannot say Ive noticed any performance difference but the price makes me smile. Where we were camped in NY, E85 was $0.90 less than regular and $1.20 cheaper than diesel! My local station sells E85 at $0.45 less than regular and $0.75 less than diesel.
The new Super Duty is a nice towing machine and Ford has nailed the engine/tranny package. Ive not had a chance to pull anything heavy with it yet but I suspect it will do quite well.
ID:	110985   Click image for larger version
ID:	110987   Click image for larger version
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 09-17-2010, 11:17 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Great in-depth report. Thank you for taking the time and making the effort to do this. It's reports like this that give us the "no sales pitch" real skinny on these new products.
This is why Airforums is such a great place.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
Old 09-18-2010, 12:19 AM   #3
_
very nice report and post wayward.
thanks for the pix and confirming the particulars.
it looks like this is gonna be a very good gas mota,
all the other bits really are ON the sweet spot for towing.
it really is clear ford has targeted the 2/3/450 for towing without compromises are the need to purchase extra bits.
cheers
2air'
Old 09-18-2010, 12:35 AM   #4
lucca53
lucca53's Avatar
1973 31' Excella 500
2004 22' Safari
2006 25' Safari
napa , California
Thanks Wayward for the report im waiting for the 2011 F150 5.0 360hp which can tow 9500# coming in Oct I am in line thanks again Luca
lucca53 is offline   Reply With Quote
Old 09-18-2010, 06:58 AM   #5
Wayward's Avatar
np - glad you found it useful!
moose, I tried to keep it informative but am admitting to liking the way the tranny behaves
2air, yeah that makes sense - most people buying a HD truck are probably towing.
luca - I gotta believe they have the same software algorithms in the F150 engine/tranny controllers. Should be nice!
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 10-08-2010, 09:32 AM   #6
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Wayward
Thanks for the excellent writeup on your new truck. I had a similar experience when I got my Tundra 5.7L 2 years ago. The 6 speed tranny is wonderful. I got the bucket seats, so the shifter is on the floor. I am glad I did this as I think that it is easier to use here and I tend to use it a lot when descending the mountain roads. When I shift out of D into the shift mode (M), it drops to 4th gear. I then immediatly shift to 3rd then 2nd to drop my speed and save my brakes. I hardly ever use manual mode unless I am braking. My transmission downshifts automatically when I tap the brakes, but I feel more in control when I downshift manually and I believe I can do it quicker.
When I bought my Tundra in 08, it was a no brainer compared to the competition- it had the powerful 5.7L, 6 speed tranny, 18" wheels, etc.
For 2011, it looks like the competition has caught up with new powerful V8 motors, 6 speed trannys and larger 17 and 18" tires and wheels. If I were buying a new TV today to tow a heavy AS (over 25 ft), I would look at the all the big 3 3/4 ton trucks. That said I am extremely happy with my Tundra for towing my TW. If I need to tow a heavier AS, I will probably install some air bags to help the rear suspension.
I see that you bought a 2wd. I did also to save about 3k and improve reliability. I had to go to Charlotte to find a 2wd. The only Tundras locally in Lynchburg were all 4x4. I wish I had a real limited slip differential. Mine works through application of the brakes. I don't like it; I am not sure if it is working correctly also. My truck has not been back to the dealer yet, but I will certainly take it in to have this looked at before my warrenty runs out next July.
So how good of a deal did you get? Did you get the SuperCab and which model did you buy? Did you get the back up camera?' I hope that your TV continues to do well for you.
Dan
Old 10-08-2010, 10:26 AM   #7
dznf0g's Avatar
Oswego , Illinois
Just a note on E85. Mileage drops between 15% - 20%, as Ethanol contains less BTUs than gasoline. It does have higher octane, though, which allows the Powrtrain Control Modue to advance timing for a smidge more power. (probably not noticable by most drivers though). So, the mileage bogey breaks even with E85 at a price of 20% less than gasoline. Some states have adjusted the tax rate to allow for this energy density differential and make cost conscious buyers more apt to buy. Of course, there are , arguably, environmental/geo-political reasons to use/not use also.
OH BOY....I am sure I have opened a Huge can of worms on this one! Perhaps a different thread???
Old 10-08-2010, 09:39 PM   #8
Vintage Kin
Fort Worth , Texas
Very nicely done with the illustrative pics. Hope you'll add more info in the future. 30,000 miles on a tight gasoline engine is, IMO, the end of the break-in period. Scale it for us someday, too, please.
Old 10-09-2010, 12:34 AM   #9
tpi
Trabuco Canyon , California
Thanks for the nice write up. As owner of '99 F250 and 25' Safari, I read it all very carefully. I would be thrilled with a new gas pickup at 12 MPG going 60 MPH.
tpi is offline   Reply With Quote
Old 10-09-2010, 07:01 AM   #10
Wayward's Avatar
Dan, your point about shifter location reminded me to mention to Ford: put the +/- manual rocker switch on right side of the steering wheel so it can thumb operated! Not that I use it that much, but it is exactly the sort of thing one would like to use with both hands on the wheel. The truck is a XLT (mid level trim package), Supercab, short bed. It came with a few options like the elect mirrors & seats, elect differential and backup sensor, but no rearview camera. I had no option choices actually (including color) because the dealer had just one at this price. I paid 27K (70% of the sticker).
dzn, I have noticed a fillup on E85 does not seem to go as far, but have not checked mileage on a few tanks of E85-only yet. I suspect you are right about it being break-even cost wise.
rednax, 6k on it now so I've a while to go
tpi - I was pleasantly surprised with the mileage. Mileage beats my 2000 F150 stick shift while towing (f150 mileage is better not towing). At this link 5 Star Tuning already has tunes for better mileage and performance for the 6.2 V8.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 10-10-2010, 11:06 PM   #11
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Wayward
27k for a 3/4 ton state of the art TV pickup with a fine gas 6.2L motor is definately a bargain. I hope that it continues to do well for you. I hope that your electronic LSD works better than mine does. That is my only complaint with my Tundra and the fact that it is HUGE. I figured that I would have to order my Tundra to get it equipped just the way I wanted it, but I found one on the lot (Charlotte, NC) already equipped the way I wanted it- 5.7L motor, double cab, 6.5' bed, bucket seats and console with floor shifter, SR-5 trim package, power towing mirrors, back-up camera, alloy wheels, bedliner, opening rear glass, towing package and fog lights.
Dan
Dan
Old 10-10-2010, 11:19 PM   #12
wbrownrr's Avatar
2002 22' International CCD
San Luis Obispo , California
Wow! Thanks for the report, Wayward. You've given me a lot to think about as I plan for a new tow vehicle in a couple of years. It will be interesting to see what's available then!
Wayne
2002 22' CCD
2008 Dodge Ram 1500 5.7L Hemi
wbrownrr is offline   Reply With Quote
Old 01-17-2011, 10:30 PM   #13
Dover's Avatar
2006 25' Classic
Livingston , Terry
Smile Just bought a 2011 F-250 with the 6.2 gas engine
Thanks for the great post Wayward. I just bought the same truck as you in the XLT pkg and also got a great deal. I'm still in the break in period (750 miles) and will be towing my 06' 25' Classic. The Classic is similar to your rig so your post is very helpful to me while thinking of my time towing. I had the 06' 6.0 liter PSD and had a dismal experience and was ready to 'leave the diesel fold'. Thanks for such a non-biased and thoughtful review. While I do tow mostly in the Southern region of the US, I do get to the mountains when I can and up into rural NY to enjoy the cooler temps in the Summer. The information you provided on your E-85 experience is helpful as I had thought I wouldn't bother using it, now I will.
Dover is offline   Reply With Quote
Old 01-18-2011, 07:29 AM   #14
Wayward's Avatar
congratulations on the new truck Dover. I am glad my report was useful.
I've not much to update as I've only made a few short trips and used it for some construction and short commutes. My right foot seems to be getting heavier however
Truck does fine in snow/ice and I like being able to lock the axle before it starts slipping. Locker did not help much in wet NC red clay (not much does) but the ole F150 was able to pull me out fine .
I did check the mileage on a few tanks of e85 using the truck's display values (not calculating it myself any more). Indeed I seem to get about 10-15% worse fuel mileage with e85. Since the gas prices have gone up, not only has the Ethanol gone up (go fig'r) but there is now only a 30 cents/gal price difference locally so it is pretty much break even. I am still using e85 though as there is a station close by. Now, if they would only make it e100, I could get a siphon hose and skip the trips to the ABC store!
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 01-31-2011, 12:31 PM   #15
Dover's Avatar
2006 25' Classic
Livingston , Terry
First Oil Change
Hey Wayward,
I'm still lovin' the new rig and have passed the initial break-in period. I'm beginning to think about what oil I will use (and stay with), for the duration of the life of the truck. Have you given any thought to a synthic oil, and have you considered Mobile 1 ? I know the cost is higher, but I'm determined to make this truck last a long time, so it would be worth the extra $$ to me.
Thanks for your input,
Old 02-01-2011, 09:32 AM   #16
Wayward's Avatar
small incremental costs for the long run IMO
Dover, I have always used full synthetics and OEM oil filters that I get at the dealer. My F150 sees a lot of heavy towing and has gone over 130K miles with only repairing an alternator, balljoints and a new clutch.
The tranny and differential get only Redline lubricants. Debate is endless here as expected, but Redline is heads above the rest and has the data to prove it on the Technical section of their website. The price is high but these fluids do not get changed as frequently. You can buy it on line.
I try and use Redline motor oil when I change it myself but shops do not carry it, so I have used Motorcraft, Mobil1, Pennzoil and Rotella synthetics when I cannot do it myself. I trust shops to charge me for synthetic but not to actually put it in. The fast lube at my local Ford dealer charges a little more for full synthetic but actually pulls the quart bottles from the back room and I can watch them through the glass pouring it in
On other major maintenance. I have the brake fluid flushed every 2 years with synthetic fluid - brake fluid absorbs moisture from the air which plays havoc with brake parts and leads to brake fade when hot brakes turn it to steam.
Adaptive One brake pads from NAPA paired with Brembo rotors - excellent brake feel, zero problems and no wheel corrosion.
After watching the tech, it looks like I am going to start getting tire rotations at the dealer now. The tire pressure sensors need to be "retrained" for front vs rear pressure when the wheels are swapped. Procedure is in the owners manual and looks like a PITA.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 02-02-2011, 01:46 PM   #17
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Extra Preventive Maintenance
Wayward
I agree with all the extra preventative maintenance that you are doing. It will keep your truck out of the shop and will save you money and headaches in the long run.
Dan
Old 07-26-2011, 06:56 AM   #18
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
Any updates on the performance of these trucks? I am about ready to pull the trigger and get one. I'm going to look at the ECO Boost but I am leaning towards the 6.2
Joe
Annette
AirHeadsRus is offline   Reply With Quote
Old 07-27-2011, 09:59 AM   #19
Dover's Avatar
2006 25' Classic
Livingston , Terry
Hey Joe
I have 14,000+ miles on my 2011 6.2 F-250 and no problems to report. I get between 10.0 mpg and 11.2 mpg and am satisfied with the truck. After all the maintaince issues I had with the 6.0 diesel, this is a refreshing change.
Old 07-27-2011, 10:25 AM   #20
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Hey Terry. How do you like the urea injection. I was at the NY car show and was looking at it. Right now it's pretty expensive but the price of the stuff should come down, eventually. They are beginning to use it on the BIG trucks too. So far Cummins is only using it on the larger chassis. The 4500's and up I think. When I checked they were not yet using it on the 3500's and 2500's. I hear good reports from the new Ford built diesel. I hope they continue. Good luck with your's.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
2011 Ford F250 Diesel - Don't Drive One Unless.. ShinyRoad Tow Vehicles 119 01-20-2012 09:06 PM
Ford 2011 F250 Diesel Aquabud Tow Vehicles 31 01-08-2011 07:59 AM
3/4 Ton Test Drives (8.1L Sub Gas, Exc Diesel, F250 Diesel) big_john Tow Vehicles 7 02-21-2010 01:02 PM
F150 or F250 Gas J Goertzen Tow Vehicles 28 05-15-2006 07:18 PM
looking for F250 gas mileage examples 2PNPOD Our Community 12 04-19-2003 10:18 PM
